Question about Linksys Wireless-G WRT54G Router
Cannot connect linksys wireless broadband router with at & t dsl modem to connect to internet ?
  • 4,281 Answers
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Then check
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Jun 05, 2010
No interent connection
Your Linksys wireless router needs to be connected to a DSL or cable modem which needs to configured with the settings that your Internet Service Provider gave you.
To test your Internet connection connect a LAN cable fron your conputer to the DSL/cable modem. If you cannot connect to the Internet using this methos, you need to contact your ISP and the can check the connection to your DSL/cable modem.
Apr 12, 2012 | Linksys Computers & Internet
Not able to connect with internet using my router
Had this work before?
If yes, and you're using Cable modem then just Power cycle the Linksys router by unplugging / plugging the power cord.
If not, then you have to configure it with the correct settings for Cable and DSL ISP connection.
Check you physical connections; Modem (cable or dsl) - to Linksys (WAN or Internet port) - then plug (wired) your PC to check internet connection.
Good Luck!
Angel
Jul 09, 2010 | Linksys Wireless-G Broadband Router
How do I get my Wireless-G Broadband Router WRT54G to work with my Verizon Westell 2200 modem. I can get internet with the modem but not with the router
HI,
Your ISP is verizon DSL.
It is very easy to set up the router with DSL.
first check if you are ale to go online when connected only to the modem.
There are 2 types of connection for DSL.
For More information Click Here
Oct 07, 2009 | Linksys Wireless-G WRT54G Router
I went from a ATT dsl modem to a net gear modem and i cannot get the net ger mode and linksys mode to talk to the computer
Most DSL providers use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections for end-users. To set up a Linksys router, you need to enable PPPoE on the router’s web-based setup page.
To setup a Linksys router with a DSL connection you need to perform four steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the LEDs
  4. Setting-up a DSL ISP on a Linksys Router
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If not, contact your Internet Service Provider.
Aug 01, 2009 | Linksys Wireless-G Broadband Router
Computer repair tech said Linskey wireless caused internet prob
If you are using DSL as your internet connection there is a timeout period that could be setup in the linksys.
In order to change this you need to log into your router and on check on the setup page. You see the timeout option.
Check with your linksys manual for detailed instructions for logging into the unit. If you dont have it, you can always get it from their website.
Jul 31, 2009 | Linksys Wireless-G Broadband Router
Wireless router isn't getting internet connection
I am running DSL, but I am sure the method would be the same. The BNC connection (cable) should first enter the cable modem, then ethernet from the modem to the wireless router.
Jun 12, 2009 | Linksys Wireless-G Broadband Router
My DSL was installed. I am trying to hook up my linksys wireless router, when I do the internet does not work. What am I doing wrong?
modem type ? make sure it is on modem-only mode if it is a home-gateway type.
connect modem ethernet to router internet port (located next to the power port).
press & hold for 10 secs. the routers reset switch (until all lights blink).
launch the internet connection wizard & select "computer is connected to a gateway / internet connection is always ON"
Jan 14, 2009 | Linksys Wireless-G Broadband Router
Connection
Hi Susie
With related to your particular issue it seems like that your broadband modem is not configured for the router. There are basically 2 types of connection. DSL and Cable modem. Verizon, ATT are DSL and comcast other providers give you a normal cable broadband connection. If its comcast make sure the cable from the comcast modem is going to the internet port in the linksys router and also make sure that there is a system connection the linksys router and the cable from the system goes to any of LAN 1, 2, 3 and 4 ports. Then reset your cable modem by using a pin and inserting to the reset hole in the modem. You could use the same step to reset your linksys router as well .If its a verizon or dsl connection you need to put normally your username and password in the router page. here is the link to how to configure linksys for your internet modem.
Here is a video as well on it?
http://in.youtube.com/watch?v=vSAXMO7aNzg
http://tinyurl.com/5tqqhl
Also post the linksys router model. your ISP modem model number and also information on how many systems are wired to the router and wireless and let me know if you need more help.
Thank you
Rakesh
Dell Laptop Expert
Jan 09, 2009 | Linksys Wireless-G Broadband Router
Trying to install Linksys wrt54gx2 srx200 on my vista computer
who is your broadband provider? Is this cable or DSL connection? Setting up the router is done via http://192.168.1.1. Leave username blank, password is admin. If you have Cable ISP, then make sure you have "Automatic Configuration-DHCP" selected and MAC address Clone is enabled on Setup > MAC address Clone (click Clone, and Apply). If it's a DSL connection and your broadband provider gave you a username and password, select "PPPoE" for Internet Connecton Type, and enter in your DSL username and password. Next verify if your modem is communicating with the router by going to the Status page and by verifying that you have an Internet IP address. If none, wait for a few minutes and power cycle your modem and router.
Dec 11, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Wireless router installation
Please see my response to this question. Your university's connection is most probably a LAN connection, so you'd need to follow the instructions as if you had a cable internet connection (unlike DSL, a LAN connection and cable internet connection don't require authentication with the ISP).
Jan 07, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
148 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
