Question about JVC RX-888V Receiver
Rear speakers are dead, never got them to work. Changed front to back and rears work so speakers and wireing are good. Is it possible that because I did not hook up a center speaker this is the problem?
    Problem Solver:
  • 10 Answers
If its a 5.1 channels it means 2 front speakers,2 rear speakers or either the center speaker or the subwoofer.try to hook up either center speaker or subwoofer.
Posted on Jun 07, 2010
    Problem Solver:
  • 13 Answers
Also adjust A/B switch or listening mode on the amplifier. You may need to turn down the front and center speakers also and increase the rears. The listening mode may need to be in Pro - Logic or virtual surround mode and not on stereo when these adjustments are made.
Posted on Oct 20, 2012
My rear speakers won't work in my 2001 Malibu. Stock system and wires to speaker okay. fader set Correct. Could it be speakers are junk?
Get a known good speaker an hook it up in place of the old ones an see if it works , if it does the old one is no good . Now if it doesn't work the radio isn't set correctly or that channel of the radio is blown .
Oct 23, 2016 | 2001 Chevrolet Malibu
No sound from rear speakers Kia Sedona 2005 Front work fine with full sound but nothing from back speakers
Assuming the radio has an output for rear speakers and it is connected to them and you have selected the front/rear fader and attempted to adjust it to the rear, you can't do much more without removing the radio and checking the connections and the wiring to the rear speakers.
When I am faced with this problem I disconnect the speaker wiring from the radio and using a 9 volt battery and two lengths of wire I test the speakers and the wiring by connecting to each speaker in turn. A good speaker with good wiring will produce noise when the 9 volt battery is touched to the terminals. If there is no noise the speaker or the wiring is defective.
If all tests ok then the radio is probably faulty. This can further be tested by connecting temporarily to alternative speakers.
Jun 13, 2016 | 2005 Kia Sedona
Do you have a wiring diagram for a 2000 pontiac bonniville
Check this on 1999 Pontiac Bonneville Car Stereo Wiring Diagram, could help...
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4" x 6" Speakers
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6" x 9" Speakers
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 21, 2012 | 2000 Pontiac Bonneville
Need wireing diagram to hook up stereo 1994 grand ltd
Its possible that you find this information in the ZJ-Secc-8W-Wiring-Diagrams Repair Manual.
Good luck (remember comment and rated this).
Jul 16, 2010 | 1994 Jeep Grand Cherokee
2002 4x4 tacoma replaced radio now door chime and stereo doesnt work
2002 Toyota Tacoma Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: 6 1/2′
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Rear Corners
Left Rear Speaker Positive Wire (+): Black
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Recheck your wire connections, good luck.
Thank you for using Fixya
Mar 19, 2010 | 2002 Toyota Tacoma
Rear speaker wire-which is positive which is negative?
1990 to 2008 Chevrolet Silverado C1500 Car Stereo Wiring Guide
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Good luck and this should help
Dec 26, 2009 | Chevrolet 1500 Cars & Trucks
91 Ford Tempo - New stereo won't work ... Please HELP
here is the radio's wire color diagram, u should be able to fix the problem with this info.Fuse box is on drivers side under the dash.
1991 Ford Tempo Car Radio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 5′ x 7′
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Apr 12, 2009 | 1991 Ford Tempo 4 Door
Install a cd player
HERE YOU GO ALL WIRES U NEED PLEASE RATE ME GOOD LUCK WILL WORK GOOD!!!!!!!!
2003 Ford Focus Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Orange/Black (Thick Wire)
Radio Switched 12V+ Wire: Yellow/Green
Radio Ground Wire: Black/Yellow and Black/Green
Radio Illumination Wire: Orange/Black (Thin Wire)
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amp Trigger Wire: None
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): White/Black
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Gray/Red
Left Rear Speaker Wire (+): White/Purple
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): White
Right Rear Speaker Wire (-): Gray
Aug 14, 2008 | 2003 Ford Focus
Need wiring diagram for 1997 ranger stereo
1997 Ford Ranger Pickup Truck Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Purple
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Amp Trigger Wire: Blue
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Orange/Light Green
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
This was originally posted here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Jul 31, 2008 | 1986 Ford Ranger 2WD
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
JVC RX-888V Receiver Logo
336 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
