Question about Hitachi C12FDH 15 Amp 12Inch Dual Bevel Miter Saw with Laser
Where is the reset button on chop saw model c12fch
Macallister chop saw blade problem, the motor runs but when half way through cutting wood the blade stops ?
I'm not sure if you have a chop saw or circular saw. Either way, it sounds like the nut and washer are not tight enough to hold the blade. If you have a circular saw clockwise will tighten the nut and washer onto the blade and hold it in place. Most chop saws are a left hand thread and then you would turn the nut counter clockwise to hold the blade tighter. The blade wobbles because it is not tight.
Feb 23, 2015 | Saws
How do I unlock the saw when trying to use as a chop saw? ty
Not enough info to answer the question. What kind of saw? What do you mean buy 'use as a chop saw"?
Aug 15, 2014 | Saws
New hitachi miter saw can't loosen the clamp lever
Any answer to this question? We are having the same issue.im sure it's something I'm not realizing but need to get this thing unstuck
Apr 14, 2013 | Hitachi 12" Compound Miter Saw with Laser...
Cannot get saw to lift up on toedo chop saw
If your handle has two buttons, they are usually a power swtich and safety button so the saw isn't accidently started. No, power should not matter in the function of the swing arm. Most chop saws lock down by way of a small chain from the base to the end of the handle. Most miter saws and some chop saws lock down by way of a pin located on the pivot point of the swing arm. The pin locks the swing arm down by passing through a hole in the base pivot bearing.
Aug 17, 2012 | Saws
The laser marker quit working - which parts to buy?
Hello. The C12FCH laser unit is housed in the base of the saw housing and has a part No. 323-647. Just a quick check though, are you sure it's the laser module itself and not the laser switch? And have you checked that the lens is free of obstruction? Here's a link to the parts list (blown up, not in fine print like in the manual): http://www.hitachipowertools.ca/upload/fmproduct_filec/C12FCH_BD_6745.pdf
Hope this helps, don't forget to rate us for assistance.
Thank You.
Richard
Mar 20, 2011 | Hitachi 12" Compound Miter Saw with Laser...
Does Hitachi C12FCH cut Aluminium?
Hello. A muli-answer for this I'm afraid. The quick answer is yes depending.
Depending On:
  • Thickness of material
  • type of blade
If you are simply wanting to cut aluminum siding/soffit, then install a paneling blade backwards and chop down slowly
If you are referring to bar stock, you will - but not well. You will need a special quick-cut abrasive blade, and you may find you need to change the blades often.
If you wish to cut screen door trim, curtain rod, draft stop, Jolie Edging for ceramic tile, or other thin hollow/extruded materials - then the abrasive blade will do nicely for short/small jobs.
The main problem with cutting aluminum in a high speed rotary device is that the friction of the blade heats the metal fast enough that you get a coating on/in the blade. (In layman's terms - bunged up) The devices in machine shops are set considerably slower, and are usually cooled mainly with liquid.
Hope this answers your question satisfactorily. Good Luck and don't forget to rate this answer.
Thank You,
Richard
May 27, 2010 | Hitachi 12" Compound Miter Saw with Laser...
12" Compound Miter Saw with Laser Marker - C12FCH: Electronics including the laser marker do not func...
Some lasers work off batteries. If yours does, you might want to change the battery/batteries.
May 17, 2010 | Hitachi 12" Compound Miter Saw with Laser...
Saw quick working suddenly, maybe blown fuse
Your saw will have a reset button that may be black in color but should not have a fuse
With the power off push down in the reset button you may or may not hear a small "click" plug it back in a give it a try
Pushing them to hard will cause an overload and they will quit
give it 5 minutes to cool of and resetting should do it
Mar 08, 2010 | Hitachi 12" Compound Miter Saw with Laser...
Where can I find a blade bolt for a Chicago Electric Power Tool Chop saw?
Take the model number and serial number to Ace Hardware. They should be able to look it up for you and get the correct bolt in.
Jan 16, 2010 | Ace Hardware Ace Chop Saw Cut - Off Blade
Hitachi C12FDH 15 Amp 12Inch Dual Bevel Miter Saw with Laser Logo
87 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
