Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a Kenmore series 90 washer that is not spin drying the cloths. There is not water left in the tub,however the clothes are extremely wet
  • 15,935 Answers
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
Clothes are to wet after spin cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 24, 2010 | Kenmore Washing Machines
Kenmore 90 Series, year 2000 Came back to put clothes in dryer and found that the clothes were still wet, not spun wet, but wet where I could wring water out of them. I hear the motor running, and the...
Jan 21, 2010 | Kenmore 22422 Top Load Washer
My 90 series kenmore wount spin fast enough to get all the water out
Jan 16, 2010 | Kenmore 15864/15862 Top Load Washer
Wet Clothes and some sandy crud left at spin cycle end
Make sure you plugged the wires back in that you unplugged to take the case off. The plug located under the panel. This is you lid switch and if it's unplugged it will not spin clothes out. If it is plugged in, you might want to go back and take the pump off. Once you have, check inside the drain tube that connects from the pump to the tub. Make sure there is nothing inside it. Sometimes lint will build up inside it, clogging it.
Please rate solution
Oct 02, 2009 | Kenmore 22422 Top Load Washer
Kenmore series 90 washer spins but the clothes are still very wet
you probably need a new clutch (Whirlpool Washer Clutch Kit 285785 fits kenmore too) , or your gear case is shot.
Feb 13, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series washer needs two spins to remove water
We have exact same washer. It is 11 years old. We are at a point where we have to spin it 7 times and then still isn't too dry. It dies yesterday a very loud death. Mentioning this here because it could be a foreshadowing of your Kenmore 90's future.
Dec 29, 2008 | Washing Machines
Kenmore 90 series washer will only spin with a couple of pieces of clothing in it, when I add more wet clothing it will not spin. If I take some cloths out it will then spin. When washer spins the water is...
Hi!
looks like you have a defective motor or a leaked load capacitor .....you need to get the motor rewired....or get a new motor for your washer..... have the capacitor checked....
but ya the issue is 1 of the 2....faulty cap/motor
Cheers!
Nov 12, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 90 Series, clothes wet after spin
First thing you need to check is the speed of the spin cycle. As long as you are not overloading the machine, it should spin the clothes pretty dry. the basket drive may need to be replaced. If it is spinning very fast, then check the drain hose, make sure the water is coming out nice and fast. If not you may have a water pump problem even lint clogged inside it.
Nov 29, 2007 | Kenmore 22422 Top Load Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
120 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
