We just replaced the batteries in our Honeywell CT3400 thermostat, and for a moment or two, the display came on, but the thermostat was not responsive to the touchpad. Now, the there is no display, and we tried cleaning the contacts, then resetting the thermostat. Is there a replacement compatible with the CT3400?
    Guru:
  • 588 Answers
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Posted on Jun 07, 2010
My Honeywell programmable thermostat's display is blank and I do not have any heat?
The thermostat, depending on the model, normally does not get powered by batteries, they are for backup power. You might be losing 24 volt from the furnace, causing the thermostat to run on batteries.
Apr 09, 2014 | Honeywell Programmable Thermostat Heater
Honeywell CT3400. New batteries but touch pad has become unresponsive
Turn the furnace power off for 10 minutes (the control wiring up to your thermostat is powered from a transformer in the furnace) & turn it back on. Make sure you have 24 volts to the Red wire on the thermostat.
Nov 21, 2013 | Honeywell Programmable Thermostat Heater
How can I unlock this th
Remove the thermostat from its base and replace the batteries. To remove the thermostat, grasp it at the edges and pull toward you. The batteries are on the back of the thermostat housing.
Read more: How do I Unlock the Digital Display on a Honeywell RTH8500 Thermostat? ' eHow.com http://www.ehow.com/how_7267447_do-display-honeywell-rth8500-thermostat_.html#ixzz17KTxLwBU
Dec 05, 2010 | Honeywell Heating & Cooling
The display on my honeywell thermostat is blank, what do I do
Hi, Check the batteries and replace as needed or check for power from the air handler/ furnace...
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Sep 18, 2010 | Honeywell Programmable Thermostat Heater
How do I open the Honeywell programmable thermostat Model CT3400? I've never done it before and don't know how to open it.
Go to myhome.honeywell.com and search for a manual for your model number thermostat on the right hand side of the page.
Oct 04, 2009 | Honeywell Programmable Thermostat Heater
EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
Oct 01, 2009 | Honeywell Electronic Programmable...
Honeywell Programmable Thermostat Display issues
there are currently 60 honeywell thermostats made i have no idea witch one you have , but a lot of the new ones run on batterys you might be seeing a low battery signal . look for a door where batterys might be and replace them
Jan 14, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
534 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
