Question about Sony Playstation 3 (PS3) Console
Playstation 3 yellow light comes on and then shuts off.
    President:
  • 1,139 Answers
This is what is known as the Yellow Light of Death (YLOD). This indicates a general hardware failure normally due to overheating. When these PS3's were produced Sony decided to use lead free solder. The problem with lead free solder is that it is not as flexible as leaded solder but it is cheaper and more environmentally friendly. When the console gets hot and cools down hairline cracks appear within these solder joints and a good electrical contact cannot be made. This then causes the console to fail. It could be on a number of different components including the CPU, GPU or memory. There is a temporary cure that may or may not work but ultimately the console will need to be repaired professionally or replaced. If it is out of warranty Sony will not replace it but will offer a refurbished unit for around £130. If you look on Youtube for Yellow light of death fix there is a way that you can re-heat the solder joints using a heat gun but if you are not confident taking apart electrical items then this really may not be something you want to try.
I am sorry I cant give you any better news but unfortunately it is a very common problem with the PS3.
Hope this helps and thank you for using FixYa
Posted on Sep 25, 2010
My ps3 turns off a couple of seconds after it is turned on then the red power light blinks
If your PS3 console attempts to turn on, then beeps and a yellow light comes on and then your Sony PlayStation 3 shuts down or does not power on at all or shows no video means YLOD or Yellow Light Of death has occurred! A guy had same problem with His console 6 months back, He was able to fix it for 15 bucks ! without sending it to Sony for costly repair.
Jun 07, 2012 | Sony Playstation 3 (PS3) Console
Turn power on to playstation 3 and it beebs light turns green then yellow then shuts off.
It's called the "yellow light of death". I can help you fix this issue just email me jamesjmohney.gmail.com, if you still need help.
Feb 08, 2011 | Sony Playstation 3 (PS3) Console
Playstation 3 yellow light comes on machine then shuts down
If the unit is blinking a red light when it turns off this is known as the Yellow Light Of Death (ironic i know because the light is red). This can be caused by the unit overheating. Causing solder on the board to melt and bridge (connect). Contact Sony to see if the unit is still under warranty with this site: https://service1.us.playstation.com/rma.htm?_flowExecutionKey=_c8D233658-C9EE-F99B-B3AD-09E41844DADF_kAD127BCB-D56D-512B-E365-E2C580E820BD
If the unit is not under warranty go to www.wiredextreme.com. We are a console repair company based out of Dallas, Tx. We can get your console up and running. All of our repairs come with a 90day warranty for the whole console, not just what we repair. We also offer extended warranties for up to 4 years at an additional cost.
Jan 05, 2010 | Sony PlayStation® 3 (60 GB) Console
Ps3 won't turn on just beeps then switches off
Please check if you get a yellow or red light flash and how many times does the ps3 beep before it shuts down.
If you get a Yellow Light, reason below:
If the hard-drive fails on the PS3 you may get a solid yellow led, The yellow light will show if the console is overheating as well, but the console shuts down so you don't it for long.
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work, then it is suggested to send your PS3 for repairs to Sony Customer Support
Let me know of this helped and please take time to rate my solution.
Wishing you Happy Holidays and Happy Gaming
Regards
Kreative Geek
Dec 23, 2009 | Sony Playstation 3 (PS3) Console
When i try to turn my playstation on a yellow light comes on then it shuts down
This is called the yellow light of death, warped motherboard. While I would not suggest just anyone to try this. You can repair in home, send in fro repair or buy a new one. here is the link for the DIY repair.
Dec 07, 2009 | Sony Playstation 3 (PS3) Console
Yellow light on console unable to start console.
First the Reason for Yellow Light
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
I just tried to turn my PS3 on it turned on but shut off about 5 seconds after booting up
This could be any of a number of problems try these solutions one of which may work. If they all fail to work you can contact sony directly at:
http://www.uk.playstation.com/help-support/PS3
or
http://www.us.playstation.com/support/PS3
  • Remove any obstructions from the vents.
  • Allow at least 4 inches of clearance on all sides for the PLAYSTATION 3.
  • Remove the PLAYSTATION 3 from any cabinets so it is out in the open.
  • Shut the PLAYSTATION 3 down completely and let it cool down to room temperature, then try running it again.
  • If the fan cannot be heard before the system shut down, the PLAYSTATION 3 may need to be sent in for service.
  • If there is no airflow from any of the vents, the system may need to be sent in for service
Hope this helps. Be sure to rate if it helped or not.
Jun 26, 2009 | Sony Playstation 3 (PS3) Console
I was playing online when the console shut down and the light on the front started blinking red. when i try to turn the console on the green light comes on and then turns yellow and then goes back to...
http://www.uk.playstation.com/Support/PS3
or
http://www.us.playstation.com/help-support/PS3
Hope this helps. Also be sure to rate whether this helped or not.
Jun 24, 2009 | Sony Playstation 3 (PS3) Console
PS3 Quit
Alot of the playstation 3 systems are having problems overheating. this would be the cause of the system shutting off. not to much u can do unless u know how to replace the fan or if you bought the warranty. other then that you would have to take it to get fixed or buy a new one. hope this helps sorry if it dont
Nov 24, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
