We have an armstrong funace/ac package unit model 64hwc303a-2b. The repair contract i have on this system (my gas and elec co.) can't find the nozzles to recharge the system with the coolant, and don't have a manual on this unit. do you know where the service nozzles are located? do you know how i can get a copy of the manual besides the mfgr?
  • 1,284 Answers
Hi, you have to contact Armstrong on 1-800-448-5872 : 8am-5pm EST directly to request for a copy of the manual and ask for any other information you need pertaining to the product, because you cannot get access to the manual anywhere online except from Armstrong..
Take care
Posted on Jun 05, 2010
Need part number for dual run capacitor for Armstrong Concept 10 air conditioner
The armstrong concept 10 comes in 7 different sizes. We need the model number off the outdoor unit.
Aug 08, 2017 | Heating & Cooling
I have a Armstrong air ac unit and need a capacitor. the one installed has no label. model number SCU10B36A-7
Take it with you to the ac parts store along with the model number. They should be able to match it. Most units use the same caps.
Jul 26, 2016 | Heating & Cooling
How many pounds of reon do you put In 2011 Rheem Classic packaged ac unit
look on the mane plate on outside unit... has voltage ratings model serial type of freon factory charge etc.
Jul 21, 2014 | Rheem Prestige 14 Series 4.0 ton 14.5 SEER...
I need to replace the air filter on this unit and I can't find the right size filter. What size do I need? I ave an Armstrong model # 64HWC303a-2B Serial # 8401H12194
If it's a plastic mesh filter, you can buy an uncut kit at most home centers and hardware stores. That you can cut to fit your unit.You'll probably have enough left over to make 2 filters.
Jul 06, 2011 | Heating & Cooling
I have an Armstrong package unit gas heat and air unit and the fan started blowing all the time and it will not shut off
Does your heater work otherwise or is it just the blower going non stop? I have worked on a few armstrong brands but they weren't a big seller in this area. However general electric units had a fuseible link located close to burner compartment. This link looks some what like a resistor without the strips. If you can locate it,bare a small section of wire on either side of it and test for continuity with an ohm meter. If it showes an open circuit,temporairly put jumper wire across it. If this shuts off your blower replace link and look for any other problems you might have. I have replaced several of these that apparently got to hot and opened. This may not be your problem but when I saw your question this was one of the first things that came to mind. I hope this helps you. Thanks
Nov 23, 2010 | Heating & Cooling
We have an armstrong funace/ac package unit model 64hwc303a-2b. The repair contract i have on this system (my gas and elec co.) can't find the nozzles to recharge the system with the coolant, and don't...
If there are no service ports on this unit, have them put the in! Alot of package units come from the factory charged and the system sealed. They should have access to quick-taps. Follow this link and look at catalog page 231.http://www.diversitech.com/literature/inline_components_catalog.pdf
These will give them access to the refrigerant circuit and refill the unit. Hopefully they are not trying to take advantage of you by wanting you to buy a new unit. Package units are not to bad to work on and finding a leak should be pretty easy with either a good refrigerant leak detector or uv dye injection. Let me know what you find out.
Jun 05, 2010 | Heating & Cooling
Armstrong Heat pump Package Unit, Model#1B36DA-9B,
Hi, the outdoor unit will start to freeze when it is cold outside, but also it should go into a defrost mode to melt this ice either by the defrost board or defrost thermostat. You will know as steam will rise like smoke and some folks think it is on fire. If it never goes into defrost, get back to us and we can go through some things to check. Merry Christmas,
Shastalaker7
Dec 24, 2009 | Heating & Cooling
Looking for elec. wiring diagram Armstrong unit pge10a42d100a-3a
Google Lenox and you will get armstrong also. The have tech site for diagrams and instructions.
Nov 28, 2009 | Heating & Cooling
We have an armstrong 125GRTC601a-2a package unit. The burners have rusted out. We are trying to find replacement burners. Do you know how or where we can purchase these burners. We have contacted...
did you check the heat exchanger? If the burners rusted out you may have holes in it and could get CO in the building. You might be replacing this unit.
Aug 05, 2009 | Heating & Cooling
I have a problem with an Armstrong SX90 gas furnace. model GUK100D14-2B serial number 8497G26541 The ignitor is not 'glowing' and therefore the pilot won't light. Everything seems to be sequencing...
Buy a new ignitor either from the ignitor store online, or your local distributer, Contracter, dealer.. they usually run from 15 dollars to 35. Their simple to change out and deffinite do it yourselfer... Oh and turn off power at breaker panel, you don't need any unexpected surprises!!
Dec 02, 2008 | Heating & Cooling
Heating & Cooling Logo
100 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
