Question about Acer Aspire 5315 Notebook
Display is not comming
Dear/ms
when switch on my lap top display is not coming just blank screen nothing but keyboard lights remain on dot know what happened my laptop acre is just 1 an half year old what to do? please help
thank-you
    Master:
  • 404 Answers
Yes one more victim! your killer was "dust"
your laptop was getting hot right? fans running loud right? then you have a GPU problem, your graphic chip is dead. it needs a new graphic chip.
www.laptopreballing.co.uk
Posted on Jun 05, 2010
My laptop won't start up it turns on but then nothing
Unplug the power, remove the battery and then hold the power button for 30 to 60 seconds. Then reattach the power and attempt a boot.
If it boots, then shutdown, add battery and restart.
The laptop's screen display may remain black when there is a corrupted graphics driver, or a problem with the LCD display's back light. (Try tilting the screen to 30 degrees and see what happens.)
It could possibly be that your outputting to the wrong screen - most laptops have a "Fn" button that can be pressed in conjunction with a little screen on the keyboard to switch to either internal display or external (say F1 or F2).
Mar 04, 2015 | Computers & Internet
Acer laptop switched on light up on switch but no screen display
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on.
To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard.
Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue.
Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue.
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment.
Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector.
Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place.
Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken.
If the monitor doesn't work, the motherboard or video card might need to be replaced.
hope this helps
Hope this helps
Nov 24, 2012 | MSI P45 Neo3-FR (MS-7514-010) Motherboard
Lap top screen only shows background picture
Does the mouse work? I would Cold-stat the machine: 1) remove AC plug from outlet, 2) remove battery, 3) hold down on/off button for 10 seconds, 4) replace battery, 5) plug into wall outlet 6) push on/off button.let me know if there is any change, if not you can try another procedure.
Nov 01, 2012 | Compaq Computers & Internet
When I turn on my Toshiba laptop the keyboard will not light up and the screen will not come on? What could be the problem?
Hi
have you pressed any of the top keys by mistake as one of them will i believe turn off the monitor/screen
maybe have a look at your top keys and find one that looks like a blank screen and try pressing it or pressing it with the fn key as well
also you could try to start up in safe mode which is probably in the f8 option at start up
and try to do a system restore
or go to device manager
scroll down to find the display and un install it
then restart and hopefully all will be good
or press f8 on start up and try to choose last good know configuration and see if that does anything for you
if you still have a problem please come back to us telling us what operating system your are running
many thanks
Mar 06, 2011 | Toshiba Satellite L500 Series Notebook
I used The FN and F5 key and it worked
Go to the point where you have a stable picture even if it is huge. Right click on an empty space on the desktop and scroll down to properties. Click on settings and increase the resolution a little at a time hitting apply and checking the display as you go. Keep hitting ok to the display settings if you like them. Find the resolution and display size that suites you.
Sep 07, 2009 | Acer Aspire 5500 5570-2609 Laptop
Blank screen when i turn on my pesario 2500 lap top
Sounds like a bad motherboard. Do you hear anything else happening at all?
Feb 12, 2009 | HP Compaq Business Notebook NX9010
Blank screen on start up on Acer Extensa 4620
Did you switch displays to the external video? Try hitting the Fn key and whichever function key at the top of the keyboard has a little TV screen icon over it at the same time.
Jan 04, 2009 | Acer Extensa 4620 Notebook
Help to repair ACER Travelmate 290LCi
this is normally motherboard or powe side problem check your motherboard
Oct 19, 2007 | Acer TravelMate 290LCi Notebook
LCD screen is blank when lap top is on
My soultion may be costly. The reason I say that is taking apart a lap top is no walk in the park. In many cases you will need special tools plus if you pull one part to far you might rip the delicate cable that sends the signal to your lcd screen. When it comes to lap tops and hardware problems its better to leave it to the manufacture to fix. I know this is not a solution but I just want to give you a heads up of what kind of problems you will run into if you try to fix it yourself. I would call manufacture see if there is a recall or somekind of tech service. Then you will be rest assured that it will be repaired properly and there will not be more problems that you caused when you opened it up.
Sep 23, 2007 | Toshiba Satellite A15-S129 Notebook
Acer Aspire 5315 Notebook Logo
107 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
