Question about Lexicon Lambda Usb Desktop Recording Interface Sound Card
Recording I have been trying to record my bass using my new lambda but its just not working I can however get sound from the output of the interface? Is there anything i'm missing or what do i do?
  • atthesource May 10, 2008
    same problem but with a condenser mic with phantom power
  • 4 Answers
In audio properties make sure its the default recording device.
Posted on Jul 11, 2008
Lexicom Lambda is not working! New user
right click my computer goto properties-harware-device manager then right click the lambda click update driver browse it with ur cd driver...hope this help
Jan 21, 2008 | Lexicon Lambda Usb Desktop Recording...
No Power to the lambda
Make sure the usb socket is working ,the lamda takes current from your computer.Don't use a usb hub.Make sure you are using xp service pack 2 or higher.Try another usb socket.
Jul 14, 2009 | Lexicon Lambda Usb Desktop Recording...
Lexicon Lamda Problem
I have a Sterling st-51 condenser mic and purchased a Behringer xenyx 1002b mixer. Similar problem, dynamic mics work in low impedence with or without phantom pwr on. My Washburn acoustic bass with preamp in line input section. So I tried it on my Omega Lexicon interface. The condenser mic and everything else works on the Omega. This unit has a wall wart ( your Lambda is USB powered). I checked the voltages with a meter and found 23 volts from the mixer and 48 volts from the Omega. Further, I have two Shure SM-82 line mics which work on the mixer with the inputs turned all the way down but do not work on the Omega nor on my Spirit SX mixer which has 48 volts phantom power. The SM-82s are old line mics that have a 9.6 volt battery in the sleeve. They overload badly in all but the 1002B mixer. Their voltage should run btwn the 9.6 battery or a 22 volt phantom power.
Check your Lambda voltage, It could be way less than needed by the st-51. I will check with a friend who has the Lambda and check its voltage. Bet it is too low.
Again, My St-51 and 1002B mixer combo barely works at 23volts, the Mic gain is all the way up as is the channel slider and the main output slider. I cant get any reading on my led meters, occasional bump on the first light, no possible way to clip the input or the output and have to turn the high eq off and the mid way back due to hiss noise. Hope this helps,couldn't find minimum voltages on the ST-51 as yet.
Dec 27, 2008 | Lexicon Lambda Usb Desktop Recording...
Lambda lexicon sound problems: is vista the cause?
I have had the same problems with the lambda driver ...they just posted a new installer on the lexicon website which fixed me up...try it.
Jul 16, 2008 | Lexicon Lambda Usb Desktop Recording...
Lexicon lambda no sound during playback
AFTER you open a new poject go to "Devices" then "Device Setup" click on "VST Audio System" then on he right side where it says "ASIO DRIVER" make the selection say "Lambda ASIO" then click OK
Jun 05, 2008 | Lexicon Lambda Usb Desktop Recording...
Distortion
It's because when you recording your get sound from Lambda!!! But PC can't reproduce that quality! Try to download driver or update which will allow you to achieve what you want.
My Lexicon Lambda is not working
Go to your devices tab click on the ASIO driver Lambda and when you get that message click reset and try again it should work.
Lambda doesn't record, though it seems ready to go
you need to go to the "control panel" on your computer.....click on sounds and audio devices, then hit the "audio" tab...make sure the lambda is selected on the recording and playback device....then apply...this should take care of it
Jan 16, 2008 | Lexicon Lambda Usb Desktop Recording...
Lexicon Lambda Usb Desktop Recording Interface Sound Card Logo
73 people viewed this question
Top Lexicon Computers & Internet Experts
Tony
aftab Nawaz
aftab Nawaz
Alun Cox
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
