Question about Nintendo DS Lite
I can't find a compaible access point on my ds I'm playing animal crossing wild world I try to connect but it says Error code: 51099
    Genius:
  • 1,234 Answers
Error Code: 51099 This error code can occur for two different reasons:
  • You are trying to agree to the User Agreement of the Nintendo DSi or Nintendo DSi XL, but are receiving error code 51099. This can occur if the Nintendo DSi or Nintendo DSi XL tries to connect to Nintendo's servers to download the User Agreement, but there is no existing Internet connection setup on the system. To connect your Nintendo DSi or Nintendo DSi XL to the Internet, please click here.
  • You are trying to play a Nintendo DS game online with a Nintendo DSi or Nintendo DSi XL, but your home Internet is set to WPA security. Please read the following:
There appears to be a compatibility issue with the security settings on your router:
Are you using WPA security?
    No, I am using WEP security
If you are using a Nintendo DSi or Nintendo DSi XL, you will be able to connect online and use many online features with WPA security. However, you will not be able to play original Nintendo DS games that are Wi-Fi compatible, as they are only programmed to work with WEP security. In order to play these games online, you will need to do the following (If you are not receiving this error when attempting to connect games online, click here):
  • Change your wireless security to WEP or temporarily disable wireless security if you wish to connect to the Nintendo Wi-Fi Connection.
  • If you are unable to log into your router or do not know how, you can check our router look-up page (link) to see if it is listed. If your model number is not listed, check any similar models from the same manufacturer for default information. If you are still unable to log into your router, please refer to the router manufacturer or the company that provided it.
  • Make sure your router is not on our list of incompatible routers. If it is, we recommended using a router that is compatible or co nnecting from a hotspot location.
  • The wireless security settings are typically found under sections labeled 'Wireless', 'Basic Wireless' or 'Wireless Security'.
  • Change the security mode to WEP, and chose your encryption type. The 64-bit encryption type typically uses a 10 character key while the 128-bit encryption type uses a 26 character key. Hexadecimal keys consist of letters A-F and 0-9, whereas ASCII keys have no limitations and are case sensitive. Be sure to use the key that is listed in 'key slot 1' and make sure you are not using a 'passphrase'. For specific information about changing your security type please see your router's manual or contact the manufacturer.
  • Important Note: it is recommended that any changes made to the router are performed from a computer that is wired via Ethernet cable to the router. In addition, any changes made to wireless security must also be adjusted on other wireless devices in the home that use the router (e.g. laptops, other game systems, etc). For instructions on how to change these devices, refer to the user manuals for these devices or contact the manufacturer.
  • Establish a connection in connection files 1-3 on the Nintendo DSi or Nintendo DSi XL. Make sure you are putting the WEP key into the Nintendo DSi exactly as it appears on your router page.
If the error persists while using WEP (or if you are receiving this error with other Wi-Fi features), follow these steps:
  • Keep trying, as there may be a temporary network issue. If the problem persists, or has been consistent over a period of time, move on to the next step.
  • Configure the Nintendo DSi or Nintendo DSi XL manually
      Please note: if your router is set to broadcast the network but the Nintendo DSi or Nintendo DSi XL is not finding the access point then a manual setup will not resolve the error. There may be another problem, such as interference, or a basic setting in your router that is causing compatibility issues. Be sure that your router is set to 'Enable SSID broadcast' or 'Enable Wireless broadcast'. If you prefer to keep your network name hidden, verify the correct spelling and case of your router's SSID.
Posted on Aug 26, 2010
Im trying to get animal crossing wild world
ok... first you need both ds(es) haha..... close to each other ( 3-30 ft away). then go to the gate and one of you needs to invite someone and the other needs to go out.. once in the other town. one person needs to go to the menu/ pocket. and go the the friend tab and select "add friend" (not sure if that's the actual option) and it should be smooth sailing from there. if you both want the friend on the list. you have to repeat the process with the other person. I may not have the full process because I'm typing it by memory ( i havn't played in a while and I don't remember where I put the game case.... :D ) I hope that this helped. the best of luck to you.
Feb 19, 2010 | Nintendo Animal Crossing for DS
My animal crossing wild world game does not work with my AR
If you use more than 2 or 3 codes at a time it will hurt your ds i dont know why but it just does
Aug 07, 2009 | Datel Action Replay for Nintendo DS
My animal crossing: Wild world wont load.
You need the master code.
Get the Master code for your version, and then put it on (dont activate it tho).
Jul 01, 2009 | Nintendo Animal Crossing for DS
No wifi connection for ds lite
Did you try to set up your Wi-fi connection settings or your not in a good Wi-fi connection zone.If that doesn't work mabey not made by or for nintendo.
Dec 26, 2008 | Nintendo DS Lite Console
Getting a friend code
well u need to go on there website and speek to the costemer servis and the will sort it out.
can u help me on mine.ta
Nov 16, 2008 | Nintendo Animal Crossing for DS
Nintendo DS Lite Logo
443 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
