Question about Swisher T14560 T - 60" Trailmower with 14 - 1/2 - Horsepower Briggs & Stratton I/C12 Volt Starter
Intake valve & exhause clearance
I am trying to find out what the clearance on intake valve and exhaust on a 14 1/2 horse briggs and stratton motor
  • 36 Answers
3000 or 4000 is your clearance, get the piston up top dead center make sure piston is to the top of the cylinder rocker arms should be level with each other before you set them
Posted on Jun 05, 2010
Valve clearance Briggs model# 331877 1371b1
Danny, I set lash at .004" / intake and exhaust clearance. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
briggs and stratton 21HP backfires like cannon
YTS3000 Craftsman model 917 289213 valve gap setting 331877 1371 B1 Briggs...
Lawn Mower Repair Valve Adjustment
Jul 08, 2016 | Garden
Valve adj. B&S gen. Model 030246 10 hp. OHV
Briggs and Stratton Valve Clearances
outdoorpowerinfo.com/engine_specs/briggs_valve_gaps.asp
Briggs & Stratton Intake and Exhaust Valve Clearances. Model Series, Engine Type, Intake Valve Clearance ( in. ) Exhaust Valve Clearance ( in. ).
Briggs and Stratton 10hp Generator Carburetor Repair ...
? 6:17
https://www.youtube.com/watch?v=O-fROtibEvE
Jun 5, 2010 - Uploaded by IFIXIT4U
In this video I will show you how to clean the carb on a Briggs10hp. This is a Nikki carb.
Nov 03, 2015 | Measuring Tools & Sensors
I need to know the over head vave setting for the intake and exhaust on a 17.5hp Briggs & Stratton vertical shaft, single stroke lawn mower.
hi pauly46 here
set piston to tdc compression stroke then run it down the bore a 1/4 inch
set the tappetts to inlet the bottom valve ( alloy push rod ) to a tightish 0.004" and set the
ex valve the top one ( steel push rod ) to 0.005"
setting at 1/4 pst tdc eliminates decompressor from upsetting valve clearance seting
cheers pauly46
Mar 26, 2011 | Briggs & Stratton Garden
I have a 2010 MTD Yard machine 21 inch snow thrower {123cc} and it broke a valve tappet bolt.I need to no were to set the intake and egzaust valves clearance.Thanks!
I can give you Briggs and Stratton figures for valve clearances of an engine this size. You may have to experiment a little till it runs right. ...you can adjust the intake valve (when it is closed) while the exhaust is open and adjust the exhaust valve (when it is closed) while the intake is open if you can tell...or ya can adjust them when the piston is at TDC on compression stroke (both valves closed). Intake: .004"-.006" Exhaust .004"-.006" (Vertical crankshaft)....for horizontal crank .004"-.006" Intake.....Exhaust is .006"-.011" Hope this helps . Here is a briggs engine specs chart..can';t find the Chinese engine listed anywhere http://www.briggsandstratton.com/engines/support/frequently-asked-questions/~/media/71BB9DA0BD4D4C19A0DA611923A0B80A.ashx
Jan 21, 2011 | Garden
Need valve lash adjustmentstats
Briggs & Stratton engines have a designated clearance adjustment that is dependent upon the MODEL number of the engine and are different between intake and exhaust valves. The measurements vary between .002 and .019 depending on your model number and which valve you are adjusting. If you want to post a MODEL AND TYPE I can be more specific with an answer
Oct 17, 2009 | Briggs & Stratton Garden
Swisher T14560 T - 60" Trailmower with 14 - 1/2 - Horsepower Briggs & Stratton I/C12 Volt Starter Logo
325 people viewed this question
Top Swisher Garden Experts
lnbn1975
Tim Whalen
dannydoesita
Are you a Swisher Garden Expert? Answer questions, earn points and help others
