Question about Sony DVP-FX810 Portable DVD Player
Line in What does line in mean on the screen of the DVD player.  How can I get it off?
  • Anonymous Apr 10, 2008
    I've had this player less than a month and am experiencing problems with the player showing the "line in" error (upper left hand corner" and the unit not player. I don't know what to do other than sending the unit back to sony.
On your right hand side ,where you plug the ac adapter there is a switch for LINE IN/OUT,have you check might just hit that by accident.
Posted on Apr 12, 2008
Power ON DVD, horizontal lines running on the TV screen. How do I get the horizontal lines to stop running and for me to view the screen to possible reset the DVD player.
Check video plugin to see if connect good on both tv and dvd player. You might try unplugging and re plug. If that doesn't help you might try another plug wire not sure if you have rca or HDMI plugs.
May 14, 2015 | Jwin Electronics JD-VD138 DVD Player
Dvd black screen tv
i guess there is some problem with line selection, please try to get the correct line input on tv, also dvd must provide correct line output signal, press input button on remote few times for example, please refer to user manual for detailed information.
Oct 19, 2011 | Sony Televison & Video
What does "line in" mean? I can't get anything on the screen except for those two words. It worked fine until we recently traveled and was checked at security. Could this have anything to do with it?
Line In means you can hook any other video source with this player to watch it on its screen.
There is switch at side of player, turn it to other side to watch dvd picture in this player.
Hope this info will help you.
Feb 17, 2010 | Sony DVP-FX810 Portable DVD Player
The dvd is set to aux line in, which means it is set to receive a signal from an outside source, like a console or somthing, on the remote you should have a button that you can adjust this so you can use the player properly, also you could just unplug for a couple of minutes and then try it again.
Feb 17, 2010 | Televison & Video
Screen is off to the side and has lines running through it
Usually when you have a million lines running through the screen it means the screen is cracked and you have to replace the whole screen. This usually happens when you drop the product or maybe you put it under something that applied alot of force on to the screen. Try to think back and remember if you placed it under alot of pressure at any point. This may have bent the screen enough that it became permanently damaged. Another theory is if you moved the player around alot that the cable that connects the screen to the rest of the player may have come loose. I know that this is a portable device but it can still happen. If you decide to open the player up to check the wire be very careful because the cable is usually paper thin and can break very easily. Lastly it could be that the screen just failed though this is extremely unlikely because they usually test the screen very extensively before it leaves the factory and if it worked there it would most likely work for a long time provided no external factors such as dropping the player occur.
Hope this helps!
May 01, 2008 | Polaroid PDM-0711
Are those line on the desktop / screen itself or within a program to play a movie. If those lines apear on th screen itself than the probem can be related to backlightes (laps around your screen) or inverter ( a part of backlights system). More possible those lapms needs to be exchanged. Please give more details.
Oct 22, 2007 | Panasonic DVD-LS91 Portable DVD Player...
Red lines taking up half of screen
call a tech near you they will be able to help you.look up a tech in your phone book.good luck.
Apr 03, 2007 | Jwin JD-VD765 Portable DVD Player with...
Multiple vertical colored lines on DVD player screen
check this out
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
DVD screen has coloured line going all the way though it
what comes to mind that u droped it... not enough info to know take it to a pro
Jan 06, 2006 | Samsung DVD-L70 Portable DVD Player
Sony DVP-FX810 Portable DVD Player Logo
166 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
