Question about Garden
If I am able to start the trimmer it won't continue to run. I have tried to adjust idle and mixture controls to no avail. This is a sudden problem. Thanks
    Problem Solver:
  • 10 Answers
First thing to check is the screen (spark arrestor) on the muffler if it has one. When these get clogged units often will idle fine, but not be able to rev up much or at all.
If the screen is clogged, clean it and reinstall it, should work fine then.
Posted on Jun 09, 2010
Ryobi s430 will idle but will stall out when throttle opens. This carburetor has one idle adjustment screw and one fuel mixture screw.
Those carbs are a pain. Try arousing the idle screw, turun it to the right, then try to see if it will idle. You will have to tinker with the adjustment screw and the idle screw. Eventually you're gonna need a new carburetor. You can rebuild it, BUT , chances are those cheap carburetors never are the same.
Sep 13, 2015 | Ryobi Garden
I have a 2 cycle Troy-Bilt TB90BC line trimmer. Won't idle. I've had the carburetor dipped, installed a new carb kit, replace the gas lines, but will only run at full speeds. Dies out easily....
One of three things is occuring here. The IDLE SPEED SCREW (Phillips head) on the throttle plate is screwed in way too far. The L and H mixture screws are open way too much allowing the carb to use excessive fuel, even on startup. Those 2 screws may need adjusting. The metering lever in your carb is not adjusted flush with the carb body flange and is holding the gas needle open constantly. Check these things and post back.
Sep 09, 2011 | Troy Garden
Homelite string gas trimmer Model ut20811A: 1. Will start with full choke and run with full choke for a while but will not maintain speed when choke is released. 2. String feed will not feed when taped....
If it only runs with choke on, then mixture is too lean or idle set to low.
Adjust mixture initially at 1.5 turns, then move in or out as needed for highest idle when warm.
Make sure no leaks or clogged filter when adjusting.
Hard to say with string feed, but are you sure you are not putting the spool in backwards?
Mar 12, 2011 | Homelite Garden
I have a Briggs and STatton 24 OHV intek motor on a craftsman lawn tractor. I got it on sale and when I got home it ran rough. The fuel line had collapsed or was plugged with some white powder. I took off...
It sounds like the fuel mixture is running very Lean..There are usually two adjusting screw screws on the carburettor that control the mixture. A Larger one is for the Main Jet and a smaller one for the Idle Jet. There is also an adjusting screw on the throttle butterfly to control the idle speed.
To adjust setup, start with at least a half tank of fuel, and have engine at operating tempurature (That is warm but not overly Hot). As a starting point, loosen (anticlockwise) Main Jet screw about half a turn, to richen mixture,so that engine will run without choke. Run engine at full speed and adjust main jet for highest smooth speed without engine missing due to mixture being too lean or rich.
Allow engine to idle and the adjust Idle Jet Screw for smoothest idle. Idle Speed screw may have to be adjusted if idle speed is too high/low.
Sequence above may have to be repeated to get best running. If engine hesitates sometime when sudden load is applied but then picks up, try adjusting Main Jet by 1/8 to 1/4 turn richer until it handles the load without faltering.
Aug 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Lawn Trimmer wont reach full revs.
you might want to check the magnito for rust build up.
it also wouldn't hurt to check the float or maybe even the valves.
since you adjusted the idle and mixture ur probly gonna have to adjust them again to get them back where they should be especially if rust build up on the magnito is the cause of your problem.
it wouldn't hurt to check the fuel filter either.
Jul 27, 2009 | Troy Bilt Tb70ss Gas Trimmer
Ryobi 720r trimmer starts ok but stalls when the
The carburator needs to be adjusted a little, thin our your mixture screw when the trimmer is warmed up and idling. Well how do you get it to idle? I usually have to play with the choke lever with the throttle wide open going from choke to partial choke as needed to keep it running. Adjusting can be tricky, you need a small screwdriver. Screw all the way in then back out 3 to 3.5 turns. this should get you close. Adjust idle as needed.
Jul 05, 2009 | Garden
Mighty lite 26ss starts fine, but needs half choke for a long time. Runs for 10-15 mins. and seems to starve out. Acts like an air leak at carb or downstream. Any ideas?
I fixed one of these with the same problem yesterday. Theonly thing I've found wrong with this little saw is the carbs are terriblyadjusted from the factory and the mixture screws have a 'proprietary' head.they're a flat-topped cylinder with a notch in the side.
fortunately, there is a way to turn them. The insulation on a blue solderlesselectrical terminal will grip the outside of the mixture screws enough to movethem. you use the big end of the insulation you stick the wire into. doesn'tmatter what kind of terminal it is. splices work the best because theinsulation is long enough that you can grab on to it, but I just pulled theinsulation off a spade terminal and used pliers to turn it, as I didn't haveany splices.
I pulled both mixture screws out and cut a slot across the top with a smallfile so I can turn them with a flat head screwdriver. if you do this, only pullout one at a time, they need to go back in the respective seat they came fromor they won't seat properly.
I also took a file and cut an access notch in the air cleaner housing so Icould adjust the high mix while the trimmer was running. takes 10 seconds witha coarse round file, but a chainsaw file takes forever.
To set your mixtures, screw both mixture screws all the way in until theylightly seat. DON'T tighten them way down, just lightly seated.
now, look at where the notch is pointed and turn them out 1 1/4 turns. turningthem out (counterclockwise) makes the mixture richer. turning them in(clockwise) makes the mixture leaner.
now, screw the idle in a full turn so it idles very high (you'll turn this backout later, but this takes some of the frustration out of tuning the carb). You maywant to take the string head off, as it will 'run' at idle now.prime the trimmer (10 pushes if you haven't tried to startit earlier, 2-3 if you did. you can't over-prime, though, you're just removingair bubbles from the fuel pump)
put it on full choke, grab the throttle with your left hand and pull the recoiluntil it tries to start. if this takes 10+ pulls, turn the low speed jetout(richer, counterclockwise) 1/16 to 1/8 turn. you want to work in smallincrements, or you'll waste a bunch of time overshooting where you want to be.
once you get it to bump over full choke, back the choke off a bit. if you'requick you can usually do this while thetrimmer is trying to run fully choked. most likely you're still going to belean on the high mixture, so having the throttle pulled may kill the saw. if itseems like it's dying when the throttle is pulled, but not at idle, then you needto turn out the high speed mixture screw.Concentrate on getting the low speed jet set so it will idlewith the choke off and the throttle off first. Once you get it so it will idle unattended, you can startbacking the idle speed down. From there, you can adjust the low speed jet whilethe saw is idling. Start by turning it leaner in small 1/16 turn incrementsuntil the speed picks up. If this kills the saw before the idle picks up, youhad it a bit too lean to start. if you get the idle to pick up, richen up themixture 1/16 turn. You want to be just richer than where the speed picks up. Ifthe saw died before it picked up, richen it up 1/2 a turn and start it again. Leanit out as before until the speed picks up, then richen it up a bit. This may sound time consuming, but you can stick ascrewdriver on the idle screw and gently turn it in continuously, so itactually goes pretty quickly once you get the saw to idle.Now that you have it idling nicely, you can adjust the highspeed jet. Start by 'blipping' the throttle. If the trimmer bogs down, richenthe high mixture. Now, if you're WAY rich, it will behave similarly, but with thistrimmer, that's pretty unlikely if you're starting at 1 1/4 turns. One way youcan tell if you're way lean or way rich is with the choke. If it will run fullthrottle with the choke part way on or if it picks up faster with the choke partway on, you know it's too lean. The choke richens the mixture up to compensatefor the gas condensating in the throttle bore when the saw is cold. If thechoke kills it, you're too rich.if it will run, then you can adjust the high speed similarlyto the idle. A leaner mixture will have more power and spin a higher RPM to apoint, but it will also run MUCH hotter and an excessively lean mixture willseize the piston. So, you're going to want to err on the rich side. You'lldefinitely be able to hear the rpm change, a way rich mixture will be almost 1/2the speed of the proper mixture, and a too lean mixture will sound like thetrimmer is going to fly apart at the seams. Once you get the high mixture to the point that you can grabthe throttle and the saw will pick up to max speed in less than a second, thenyou're ready to cut something. You may need to adjust the mixture leaner for abit more power if it bogs down in normal grass trimming, or if it is running througheverything including big weeds without changing speed, you should probablyrichen it up. This is NOT a big trimmer, it SHOULD bog down a bit if you loadit up.A final note about this trimmer, I never could get it to acceleratesmoothly from idle to high speed. It lags for about 1/4 second just above idlethen it picks up as it should. It runs fine once it gets past that hesitation,you can vary the throttle to be delicate around things, ect, but if you let itidle, it does hesitate when you pull the throttle again.I was pretty surprised how well it ran once I tuned itthough, this one is my boss's and he's got a 3-blade cutting head on it that'sa lot heavier than the string head and it will spin it just fine. It will cutdown saplings to maybe 5/8".Good luck!
Jun 26, 2009 | Homelite Mighty Lite Lawn Trimmer
Need to adjust fuel and air mix to start trimmer.
Hello gwturley201:
I am Including the Carburetor Adjustment File Also.
From your Description it Sounds like the Exhaust Port or Muffler is Restricted with Carbon Deposits, the Carburetor Metering Pump Actuator Gap is Incorrect.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
Is the Fuel Line from the Fuel Filter Staying Full of Fuel?
The Carburetor Metering Jet Actuator is Set so the Pump Diaphram Dowl is Just Touching the Actuator Arm. These Components are Located Under the Cover with 4 Small Screws Holding it to the Carburetor Body.
>>The Following is the Instruction File for Setting the Air Mixture Screws. Any Input is Appreciated. The Procedure is the Same for 1 or 2 Mixture Screws, Just Use the Instruction File and Skip Over the Section with the Missing Mixture Screw ( Usually the H Mixture Screw).
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air (L) and Main Air (H) Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Set the Throttle Full Open, Start the Engine.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade or for Chainsaws and Trimmers; they Operate without Bogging Down. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
>>Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air (L) Mixture Screw so there is No Hesitation when Rapidly Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Craftsman Garden
Carb adjustment
Hello:
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
Apr 21, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 31cc lawn trimmer carb adjustment
As with all 2 strokes if you have compression and a reasonable spark, you only need fresh fuel with correct oil ratio) and they must go !(as long as you haven't fiddled first and all gaskets are sealing) I start mine by(1) pumping the primer till it is firm,(2) full choke,(3) pull till it kicks ONCE,(4) half choke, pull till it runs,allow to warm up and(5) switch to run (you may need to apply a bit of throttle while pulling as in (4)(or give it a few more pumps if it dies) If all is ok, check that when properly warmed up there is a smooth transition from idle to full revs, if it hesitates it may need the LOW SPEED mixture leaning (clockwise) SLIGHTLY.If it dies the LOW SPEED mixture may need richening(anti-clockwise)(adjust 1/8 turn at a time) Make sure that motor is just peaking at full revs and is on the RICH side of peaking (HIGH SPEED mixture)(this will avoid seizing it Adjust both till it revs cleanly and is JUST rich at full, and idleing nicely and it should start without too much trouble.(If you have fiddled and are lost,-about 2 1/2 turns out from closed on both needles should get you started)
Nov 23, 2008 | Garden
Garden Logo
137 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
