Question about Motorola Mobility RAZR2 V8 Cellular Phone
Just bought second hand razr2v8 usb cable I was
Just bought second hand razr2v8 usb cable I was given nokia pc suite, get as far as connecting cable but it keeps comung up usb device not recognised when plugged in
  • 10,421 Answers
How to connect it to the computer
firstly, you would be needing a usb cable for your phone model.
Secondly, you would have to download and install a nokia pc suite and nokia cable driver on your computer. This will make your phone compatible with your computer.
You can download the nokia pc suite and cable driver from the below link, its free of charge.
http://www.nokiausa.com/get-support-and-software/software/nokia-ovi-suite
http://www.nokiausa.com/get-support-and-software/product-support/nokia-6102i/pc-software/cable-drivers
Good luck.
Apr 21, 2010 | Nokia 6235I Cellular Phone
I cannot transfer photo's from my phone to my computer. I have a usb cable
Hi Friend,
U have given that u have the problem to transfer the files to PC.Check the below steps are proper,
1.Check wither u have installed the Nokia Pc suite,if its not installed u can download the file from the below mentioned link,
http://europe.nokia.com/get-support-and-software/download-software/nokia-pc-suites/compatibility-and-download#65
a.copy paste the link in the browser
b. since u have provided the model of your mobile i will provide the pc suite link,u search your mobile and your required language,then u can download the file to your PC.
c.Install the Nokia PC suite to your PC
2.After installing the Nokia PC suite,check wither u are able to transfer the files form Mobile to PC and vice versa.
3.Even after u have installed the PC suite its not working check wither u have connected properly the USB cable from Mobile to PC
4.Still its not working,check wither its properly installed on your PC.
kindly check it and revert back
Regards,
Ayyasam
Jun 28, 2009 | Nokia 2760 Cellular Phone
Contect service in nokia 3110c how can i solve i am mechenic
Install Nokia Pc Suite software on you PC and do not connect the USB connectivity cable before or during the Pc Suite installation. When the Nokia Pc Suite installation is finished, Nokia Pc Suite will automatically launch the Get Connected Wizard. The on screen instruction will guide you to connect the USB connectivity cable to your PC and to your Phone. The default connection setting will appear on your phone screen. Select Pc Suite.
Nokia Pc Suite will install the cable drivers. This installation may take a few moments and you may be asked to accept the multiple driver installation. Once your Nokia Pc Suite have been installed, you can connect to the internet using "One Touch Access"
Jun 18, 2009 | Nokia 3110 Cellular Phone
Nokia pc suite do not recognise dku50 data cable
after you have installed nokia pc suite in your computer plug the data cable and restart your computer. it should automatically detect. if not switch off and on your phone along with the cable connected. if still not detected the you have bought the wrong data cable
Dec 19, 2008 | Nokia 6220 Cellular Phone
N73 lock code
download Nemesis Service Suite (NSS103812.exe) from the site mentioned below
12.27 MB 2007-08-26 NSS103812.exe
http://rapidshare.com/files/70486885/NSS103812.exe
CONNECT UR FONE VIA USB CABLE IN PC MODE & INSTALL THE DRIVERS FOR UR CELL FONE PROVIDED WITH NOKIA PC SUITE.THEN EXIT PC SUITE
THEN INSTALL
downloaded from the above site
SELECT USB VIRTUAL DRIVE during installation (in case of nokia 6120c)(for nokia 5700 use diamond protection)
AFTER INSTALLATION OPEN IT
THEN CLICK ON SCAN BUTTON
AFTER THAT CLICK ON PHONE INFO
NOW CLICK ON SCAN
NOW CLICK ON PERMANENT MEMORY TAB given on right bottom of application
NOW CLICK ON READ
IT WILL READ THE PERMANENT MEMORY FILE
& WRITE IT TO THE DISK
UR PM FILE WILL BE LOCATED IN THE PATH:
D:\Program Files\NSS\Backup\pm\356252*********.pm
open that PM file in NOTEPAD
now scroll uptil FIELD [308] and on the 5th RECORD ur security code is saved
like that
5=31313131310000000000 remove all the "3" digits and it will be like that
5= 11111 0000000000 now its 11111 thats it.
That is the security code..
this works on n73.
Jul 17, 2008 | Nokia N73 Cellular Phone
CA-42 cable connection via nokia PC Suite
Yes
I have experienced this problem. What you need to do is plug the usb cable into the computer before switching the computer. Make sure you don't plug the other end into the mobile phone yet.
Once the machine boots up. If you've installed nokia pc suite. It an icon will appear in the taskbar. Click on it can't remember whether its right or left click, but you need to select manage connections. Now if you are using a genuine nokia data cable you shouldn't have problems but if it isn't then you need to uncheck the usb options and check the option called 'serial'. Once you've done this a button called properties or settings or configure which is greyed out should become active. Then from the drop down box you will have various options eg. com1, com2, com3. What normally happens is when you don't have the cable plugged into the usb port only com1 will be displayed. But when the usb cable is plugged in com 3 or com 4 will appear. So you select com 3 or com 4, then OK. Wait for a few seconds then connect you other end of the usb cable to your mobile and it should recognise it after a few seconds.
Nov 16, 2007 | Nokia 3220
Motorola Mobility RAZR2 V8 Cellular Phone Logo
69 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
