Question about Zenith DVD2381 DVD Player
When playing a DVD, we experience frequent stops and starts..
We cannot watch a DVD without many pauses. It seems to get stuck. This happens on any DVD we play at this point.
    Scholar:
  • 121 Answers
It may be a dirty lens, or perhaps the drive is getting stuck.
The first thing to try, if you feel up to it, is to clean the lens. First, you'll need rubbing alcohol (peroxide isn't the same thing) and a Q-tip. Add a tiny amount of alcohol to the Q-tip and gently rub it against the lens of the laser. After a few times around the lens, use the dry end of the Q-tip to pick up any excess alcohol lying around. Put the player back together and try playing a disc.
If it still doesn't fix the issue, then the following steps can be taken.
Have a disc in the drive and while it's off, open it up. Start the drive and see if it's spinning freely. If not, then onto the next part.
Use some WD40 on the shaft of the drive motor that makes the disc spin. Just use a little bit at a time and work it in by manually spinning the spindle (what the disc rests on). Once that's finished, put the disc back in and reassemble the drive, plug it in, turn it on, and see if it spins better.
Posted on Jun 05, 2010
The sound goes on and of when watching a movie
see the cause and fix it: God bless you
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Jul 21, 2012 | Wharfedale DVD-M3 DVD Player
Paused a disc ,when i hit play,the play light came on but nothing happened. I cannot turn off the dvd play manually. it seems to be frozen.have chaned batteries
Hi:
Try disconnecting the unit from any power source and waiting for at least 10 mins before restoring power. This should reset the units microprocessor so you can resume playing.
May 01, 2011 | Samsung DVD-1080P7 DVD Player
Hello, my SanyoDVD/VCR player is pausing then playing my DVDs. It's impossible to watch a DVD without it starting and then stopping. What should I do instead of buying a new DVD player? The VCR works...
Hi, a cleanning disk never make a good cleaning,you will have to do it manually whit a qtips and alchool (wood) and gently wipe the laser lens.
hope that will help you
regards Alan
Oct 09, 2010 | Sanyo DVW-6100 DVD Player/VCR
When I try to watch a video it will play a few seconds then stop then will play again for a few seconds what can i do
this happens if you have a slow internet connection...
There is a high demand for the video
your video card is not up to snuff...
cheap fix... pause the video and wait till the red bar is all the way to the right or full...
then play...
if that still doesn't work then
upgrade memory... and do the pause trick
still doesn't work... upgrade video card and try pause trick...
still doesn't work... get a new computer...
Feb 06, 2010 | YouTube Videos
Dvd get stuck 1 hour into film
There MAY be contamination of dust on the lead screw that moves the head. Be VERY careful cleaning as the head is suspended on flexures that are moved for the fine movement necessary to follow the tracks on the disk.
You might want to take this in to a repair shop and see if they can clean it.
Replacing the drive would likely cost the better part of the original cost of the whole unit.
Dec 13, 2009 | Sony RDR-VX555
Screen says loading and after a while, says disk error.Then eject
hi try first to insert a clean up CD, and test your DVD player with an original DVD, if the problem persist , your laser sense is defficient you have to go to fix it to a specialist.
hope this helps you
sserpentio
Apr 12, 2009 | Televison & Video
My DVD player is not working properly
It sounds like the player is defective, try to get a RMA ,or it or bring it back to where you got it from.
Apr 20, 2008 | Philips DVP3140
Onkyo TX-SR702 keeps going into speaker setup mode
Los amplificadores de audio del aparato estan a punto de danarse,checa las bocinas una por una a ver si no hay alguna mala.
Apr 14, 2008 | Onkyo TX-SR602 Receiver
IVE GOT A TOSHIBA RD-XV45KB VCR to DVD RECODER.
i too have the same error 03-56 the only way i have found around it is to use the really cheap basic -r discs from tesco
Feb 14, 2008 | Panasonic DVD-RV41 DVD Player
Zenith DVD2381 DVD Player Logo
163 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
