Question about Hannspree XM-S Boston Monitor
No signal input on Hannspree XM-S monitor with screen going black and power light orange. This has happened on a number of occasions sporadically and we have never discovered how we were able to fix it. Can anyone suggest what to do in this situation as it has arisen once again
  • 43 Answers
SOURCE: error on monitor: Input signal out of range.
Hello mcarsten,
Your monitor may not be configured to the correct resolution for the second monitor. If you right click on an empty space on the desktop and then select properties, the display properties will appear. Click on the last tab on the top right. It should be settings or something like that. You should see two boxes with the numbers 1 and 2 in them. Next click on box number 2 and try using the slider below and changing it to different resolutions for your monitor.
Hopefully one of these should work for you.
Posted on Jul 10, 2009
  • 1481 Answers
SOURCE: I have a Hannspree 25 lcd monitor and I can't get
the monitor is not properly connected to the back of the PC box, check the cable that goes from the monitor to the PC box, (first unplug the PC/monitors from the power socket)
check if the cable is loose from the monitor jack point on the back of the PC box, remove it and blow air in it may be some dust is there.
fix it back and tighten the two screwes with a screw driver.
power it back ON
Posted on Dec 07, 2009
  • 732 Answers
SOURCE: We bought a new Hannspree in November, now all at
chummel36, Find your warranty and then yell and scream at them about poor quality and premature failure, but only after you connect to a different known good pc and see if your monitor still acts crazy. Learn to do the flashlight test to determine partial or full shutdown state of monitors "switch-mode-power-supply" when screen goes black or blank n black!!! Spend some time in my fixya profile reading about black screen problems before you do anything else. 12fixlouie
Posted on Feb 20, 2010
  • 358 Answers
SOURCE: Hannspree 20" Monitor HF205 - What is its' power
Max Resolution 1600 x 900 • 15000:1 Image Contrast Ratio • 5 ms Response Time • 34 Watt Power Consumption
techbelkin
Posted on Dec 13, 2010
Testimonial: "I received an Instant Answer. "These guys are truly experts.""
SOURCE: I have a monitor hannspree Xm model M19W1, I need
you must install driver of motherboard sound card because monitor have only speaker not sound card to generate a sound if you want send the motherboard model so i try to help you
Posted on Dec 16, 2010
Need manual for Hannspree Monitor Xm-S
When you say the picture keeps dropping, is it going to the black or blue screen where it says it cannot detect an input/source?
If so that could be a faulty cable, if you have a spare cable to connect to whatever the input you're using is it would be worth trying that.
Aug 16, 2016 | Hannspree Computers & Internet
How to solve Acer monitor black screen and orange light problem?
This doesn't really sound like a monitor issue, although it has been known to happen that some monitors develop a fault that causes the inputs to stop working.
IT sounds like an issue with the computer or the cable.
Apr 30, 2014 | Computers & Internet
The monitor is black with a error message :input signal out of range We are connected to a Mac Mini This problem seemed to happen after the monitor was accidently disconnected and then when it was...
Can you please get me the make and model of the monitor? Also did you check to see if the refresh rate of the monitor matches with that of the mac mini?
Nov 21, 2010 | Hannspree Computers & Internet
My hannspree monitor wont turn on
You should ensure that 1) the monitor is plugged in, 2) it is set to the proper input (VGA, HDMI, etc), and 3) the monitor power light is green instead of orange.
Good Luck,
NOLA Tech
Mar 17, 2010 | Hannspree HF207AP 23" LCD TV
I have a new DELLS2209W Monitor. On occasion my
I want you to try something next time this happens, instead of rebooting the computer, just cut power to the monitor. Then switch it back on.
Does the screen come back up?
Comment back and let me know
Mike
Dec 19, 2009 | Dell Computers & Internet
Monitor will be on and working fine and then screen will suddenly go black. says no input signal and that a cable has been unplugged. normally have to turn the monitor off and reboot computer to get...
oh no i have same monitor well the only thing i know to do is take it apart and wiggle stuff maybe a culprit will show up if noting then i would just replace on mine the power plug on the back came loose now i cant take out the plug else itll be useless
Nov 03, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
THE MONITER QUIT WORKING AND THE LIGHT IS BLINKING WITH A BLACK SCREEN
The light is blinking can indicate two things, one- it see short circuit such as short circuit in the backlight inverter board, this board consume most of the power and runs hot, so it trying to shut itself off, two- the power supply is bad, look for bad filter capacitors, which is more likely, for bulging top, learn more here:
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 01, 2009 | Hannspree XM-S Boston Monitor
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
No Input Signal
Dont Panic it is Nothing...
Your Monitor is safe...
If it say "no Input signal" - "Check VGA cable"
it means that the Monitor is finding signals from the computer,and the cable is either not connected or unsecurely connected.
Jul 18, 2008 | Chi Mei Corporation 221A Monitor
No display
if your monitor is not connected to a pc, then it cannot find a vga signal input and therefore go into power saving mode, which is indicated by the orange light, but as soon as you connect to the pc and power on the light will go green and the monitor will power up.
May 07, 2007 | BenQ T701 TFT 17" LCD Monitor
Hannspree XM-S Boston Monitor Logo
234 people viewed this question
Top Hannspree Computers & Internet Experts
justwinwin
Computer Links
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
