Maytag Dishwasher Logo
Posted on Jun 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It will not drain water
I have checked the drain line and drain pluming all is clear
Michael Thomas
Level 3:
  • Maytag Master 3,056 Answers
  • Posted on Jun 05, 2010
Michael Thomas
Maytag Master
Level 3:
Answers
3056
Questions
52
Helped
1307393
Points
10935
Hello there:
Please read the solution that i have provided for you CAREFULLY THERE IS A LOT OF INFORMATION IN HERE
t won't drain If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
I have a water leak in bathroom not from toilet. How can I check the pluming in that area?
Your idea may correct. But majority of cases it is floor/ground seepage....leaks through your tiles or waterproofing layers and so on..To chk...keep on pouring water to the ground of the bathroom, near wetting areas, and close the freshwater line leading to the bathroom taps
2answers
How do I winterize a 22r minnie winnie?
find water tank under bed or seats turn knob on tank drain go out side behind rear wheel turn knob on water lines and let drain. turn on pump for a little to clear line. put pluming anti-freeze in sinks ,tube traps 2 liters in each.
Whirlpool dishwasher F8 E1 error
You have a blockage in the drain line someplace. If you have a garbage disposer, check to see that it is clear where the dishwasher connects to it. Also check and make sure that the drain hose is higher then the inlet to the disposer to prevent water draining back into the drain line from the disposer. If that's clear you have a blockage somewhere in the drainline. Best to unit from cabinet and check it
JENN AIRE LEAKING WATER ON FLOOR. NOT SUPPLY LINE PROBLEM. HELP
Open freezer, remove lower crisper & look for solid ice on freezer floor & area at rear of freezer. If present, defrost drain is restricted. Depending on make & model remove ice, remove rear wall and clear defrost drain trough and drain path. Verify by removing kick panel, pour a cup of near boiling water through drain and watch as it drains into pan. Once clear, pour one ounce of bleach into drain tube. Also check as water is draining into pan that the pan is not leaking due to pan cracks. This solution is based on the fact that you are stating no hoses are bad.
Mar 27, 2012 • Freezers
I need to clear the drain line on my Amana ARB1917 bottom freezer refrigerator. I've accessed the short tube that is supposed to move the water from the fridge/freezer to the drain pan ... it's...
The way to check that everything is clear pour some water over the evaperator coil in the freezer and see that the water drains very quickly. Also you could use a can of compressed air that you would use to clean the keyboadr and what not on your computer and blow it in drain and clear anything remaining
Gene
Hi, We have Tecnik Dishwasher TKD 795/3 it wont seem to drain the water, we have tried to clear the pipes but they seem to be clear, Can you give us any tips on how to sort this problem out? Thank you
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Water does not drain
Hi, if you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump.
Take care
May 31, 2010 • Dishwashers
1helpful
Just plumed in my hotpoint ultima it has done a
when you start the cycle the water will disperse. but check the fillters at the bottom of the dishwasher and make sure the drain pipe end is not crushed if you are enptying into the kitchen sink drain make sure the pipe is not kinked back on its self. try and get it as strait as you can.
18helpful
3answers
GE TCS18 Bottom Freezer
Clogged Freezer Drain it is. To clarify, pull out the fridge, remove the smaller square metal panel (about a third of the way up the fridge in the middle) with 4 screws. Behind it is a black drain pipe system. Remove two screws and remove drain pipe (takes some pulling to detach the seal). There is a silver 3" long pipe that goes into the freezer itself. Remove this, clear it and replace. Take the black pipe and pluming, remove pluming block from the black pipe and blow through it. Run warm water through it (most likely where the clog is) then before reconnecting it to the black pipe, blow through the black pipe to make sure there is no clog there. Reattach pluming, screw it back in, replace the panel and there you have it!
Standing Water in Dishwaaser
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Top Maytag Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
