Question about Dishwashers
Whirlpool adp 8540 - 7 flashes
I have a whirlpool adp 8540 dishwasher, when I start the cycle it runs until it begins to fill, then it empties and the start button flashes in sequences of 7 flashes
I have cleaned the water inlet pipe, but no change
  • 1 more comment
  • jip00 Apr 10, 2008
    I found on another site that the fault code indicates that there is a problem with water flow, so I removed cleaned and tested the water inlet valve - this worked ok, so I removed and cleaned the reed switch on the water flow meter (cockroach gunk), I also bend it closer to the impellor - it has just finished a cycle, so as far as I am concerned it was a problem with the water flow meter
  • jip00 May 04, 2008
    The cycle mentioned above was the only cycle that the dishwasher ran for, so I went to an electronics store and purchased a reed switch (bought 3 since they are so delicate - $1.50 AUD each) and compared this to the one in the dishwasher.  This showed that the one in the dishwasher was always 'on' (closed circuit), and not 'pulsing' on each pass of the magnet in the impellor.  I have replaced the original reed switch with the one purchsed and the diswasher has been working ever since.
  • Anonymous Oct 08, 2008
    it wont spray water, ,,,,it starts puts a bit of water in then goes through the cycles with no water spray? i got heaps of water pressure goin in.
    sometimes is flashes then nothing? so i was told to hold the start button down for a few seconds, it then emptys the water inside then nothing?
    Is the fault a ntc? heat regulator?
    Cheers
    Stu
    Genius:
  • 1,073 Answers
Replace the control board in the console
Posted on Apr 10, 2008
Whirlpool adp 9411
If this is the machine with just a knob for the wash cycles, and one button to start the wash cycle, you will have to replace the timer. There is no reset that I know of.
Dec 16, 2013 | Dishwashers
Whirlpool adp 6600 will not function start light is just flashing
Whirlpool adp 6600 will not function start light is just flashing. Waht di I do?
Sep 17, 2009 | Whirlpool 24 in. ADP6940 Dishwasher
Doesnt empty completely, a pump is running when
it is normal to have some water come back in from drain hose(not to worry)
Aug 23, 2009 | Whirlpool 18 in. ADP530 Free-standing...
My Whirlpool dishwasher stutters loudly during wash cycle. It's an intermittent thing, in the sense that sometimes when i run the dishwasher it doesn't do it at all. But also in the sense that when it does...
A symptom like this is commonly caused by a failing wash pump motor. If you are having this problem and the dishes are not getting as clean as they used to, the motor is most likely the problem.
Jul 29, 2009 | Dishwashers
Dishwasher (Whirlpool ADP 952) not working
I have a whirlpool ADP 952 and the start button is flashing and it won't work
May 25, 2009 | Dishwashers
My dishwasher model adp 941 won't start - start led flashes
exactly the same problem today with an AD9520
Don't know the cause but from reading other posts re dishwasher problems I tried holding start but on for 5 - 10 seconds and it seemed to clear the symptoms at least. It ran for a short while and stopped but the flashing had stopped and I could start a wash cycle which is now running!
Dec 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
WHIRLPOOL ADP 8540 dishwasher has blinking light on all the time (blinking in cycles of 4). When you turn it on (by holding the button down for around 4 seconds) it wont complete the cycle and you need to...
WHIRLPOOL ADP 8540 dishwasher has blinking light on all the time (blinking in cycles of 4). When you turn it on (by holding the button down for around 4 seconds) it wont complete the cycle and you need to keep restarting it. can anyone let us know what the problem may be. Thank you
Jul 17, 2008 | Whirlpool Dishwashers
Whirlpool adp 5540
My dishwasher isnt working anymore after i cleaned the filters? i took out and cleaned the filters in it and now it doesnt seem to be working properly. it goes thru the cycle but its not cleaning. the dishwashing tablet falls to the bottom and isnt even dissolved completetly after the cycle has finished. is it possible that its blocked somewhere?
It is a Whirlpool ADP 5540
thanks for your help
**** the walls are still dirty after the cycle but there is steam in there as if its done its normal cycle
May 13, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Dishwashers Logo
3,614 people viewed this question
Top Dishwashers Experts
