Question about Hitachi Televison & Video
We purchaced a 55''projection T-V March 19,2007. from the Brick. We took a 5yr LTD IN-HOME WTY. The Brick picked up for repair Jauary 4th. and we never got it back.Transglobal told us to pick out another T-v. We have to wait for an authoration from Hitatchi though.Every time I phone Transglobal they always tell me they still never heard from the Hitatchi dealer yet for their authoration to pick out another T-v. Ou sales order/invoice is 03197111013001 the name is Raymond Klotz. Address is 5924-134 avenue.Edmonton,Alberta. area code T5A0L5.phone no. (780) 4755599.Can you please contact Trans GLOBAL at 1 800 3602742 and find out why we never received their authoration number. Thank you kindly, hope you can help us.
  • 77 Answers
SOURCE: Epson Aculaser CX11NF won't receive faxes
Change your incoming mode from "autoswitching" to "TAM" (TAM is short for telephone answering machine" Press the "Setup" button on the control panel Use down arrow twice to select "FAX SETTINGS" Press the right arrow once The FAX SETTINGS menu appears Press the down arrow twice to select RECEPTION SETTINGS Press the right arrow once Press the down arrow unit INCOMING MODE appears in display Press the right arrow once Press the down arrow until TAM appears in display Press the right arrow once. That should do it for you If I got lost somewhere, it is in your Operator's manual - look in the index for TAM Hope it helped Ed
Posted on May 23, 2007
Bajanguru
  • 7752 Answers
SOURCE: caller ID
if you are putting 1 then the area code , just put in the area then the number and nt the 1 digit this should help
Posted on Feb 05, 2008
welcomejee
  • 10594 Answers
SOURCE: Hitachi 55FX20B 55 in. Rear Projection - no picture or sound
TV always has high voltage shock risk while repair. As you said you are not familiar with TV repair so better to handle repair person this issue.
Posted on Oct 01, 2008
  • 41 Answers
SOURCE: panisonic projection tv pt-53wx52f
There is a mechanical adjustment on the tubes themselves when it was dropped it could have knocked it out of alignment, or the Convergence ICs are bad with is a common problem with CRT projection tvs.
Mechanically adjusting the tubes can be tricky I wouldn't suggest working on it unless you have some kind of experence with tvs. But if you do adjust the red and blue to the green.
Posted on Oct 06, 2008
SOURCE: Samsung 55" TV does not turn on
CHECK YOUR RED ,GREEN AND BLUE CRT'S THERE MAY BE A SMALL CRACK ON THEM.MAKE SURE TO TAKE THE YOKE OFF AND INSPECT THE ENTIRE TUBE IF THER IS A CRACK IT IS CAUSING YOUR TV TO GO INTO SAFE MODE. ALSO CHECK THAT NONE OF THE COOLING FLUID HAS DRAINED OUT OF THE TUBES ON TO THE CRT BOARDS IF SO REPLACE THE BOARDS AND CRT IF CRACKED. YOU CAN FIND ALL THE PARTS AT PARTSTORE.COM HOPE THIS HELPS.
Posted on Nov 09, 2008
Http://www.geethy.com who know this website?
Shandong Geethy Machinery Manufacture Co.,Ltd. , mainly engage in the manufacture and export of concrete machinery equipment ,concurrently running machine design , technical labor dispatching , overseas project-contracting ,and become a group corporation which has realized cross-industry operation . The company has three fully owned subsidiaries, Shandong Geethy Machinery Manufacture Co.,Ltd., Linyi Geethy concrete machinery equipment institute, and Geethy group(Hong Kong ).
Our factory , founded in 1994 , is located at Yinan , Linyi ,one of the two biggest building machine manufacturing bases in china ,which is one of the earliest enterprises in China to manufacture burning free brick machine,hollow brick machine . The company owns 46 technical senior engineers , 128 engineers ,1300 manufacturing workers
May 21, 2012 | Computers & Internet
I hav a hp nx6120 but doesnt switch and wen you plug in the charger its no lighting
Take a look at the back of the laptop. Is the gold power pin still there or is it now stuck in in the end of the power brick cord?
HP actually extended the wty on these machines because of the
power pin issues. If the power pin is missing you will need to have the machine serviced. Out of wty, replacement power pins are easy to solder on the board if this is the issue.
If your pin is still there... Your AC cord or power brick may be the next things to check. Connecting them to a meter will tell you if there is power. Try moving the cords to check for shorts in the wires.
If your AC cord and brick are good, try pulling the battery. Your laptop can run off AC only. Batteries with bad cells can sometimes prevent the machine from powering up.
If its still not powering up after all of that, there may be an issue with the motherboard in the machine.
Feb 27, 2010 | HP Compaq nc6120 Notebook
I have a 55 in. rear projection the tv just keeps blinking won;t stop
The bulbs in the unit are actually going out. Some DLP tvs use specific bulbs that can only be picked up by the manufacture. Some mom and pop shops carry DLP bulbs. Your best bet is to call the manufacture or search for the model online using WWW.GOOGLE.COM to purchase these bulbs. These bulbs should always be installed by a certified repair specilaist. Hope this helps.
Oct 10, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Samsung 55" model hcm5525w
its the convergence problem in your power supply board
please check out this links
for convergence board ics reparing it your self
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
and for convergence settings
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
thanks.
Oct 05, 2008 | Samsung HCM5525W 55" Rear Projection...
Mitsubishi 55 inch Rear Projection w/ Green tint
C.V.G ADJ AND SERVICE MODE ? GREEN C.V.G BAR ADJ POPARLY?
YES , SO POPARLY NOT SAVE 50HZ & 60HZ
NO, SO CVG I.C DEF, ITHER PRT LANCE LOOSE
Jun 13, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Light engine
where are you getting your parts from? sounds like someone may be selling you used parts to get more business.
Apr 15, 2008 | Toshiba 62HM95 62" HDTV
Tv wont turn on
I paid to have one of the experts on this page help me with my Hitachi 55 in, and all they would recommend was to replace the Convergence Amplifiers. I read elsewhere, that this TV has a habitual problem with fuse E994 and a capacitor c707. I just replaced both for a little more than $5.00, and the TV came back to life!!!! I'll try to find the web page that I referenced for the repair, and let you know.
Dec 23, 2007 | Hitachi 55UX58B 55" Rear Projection...
Toshiba 55" 55H70 model. Turns OFF, but won't turn ON until I unplug it from the wall first.
sounds like loose connections on the convergance amps ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Aug 22, 2007 | Toshiba 55H70 55" Rear Projection...
Green tint screen
Took mine to a repair shop and they said there was an issue with the line something? circuit board. Quoted me 225 parts 450 parts+labor. Mine was a red tinted screen.
Jan 17, 2007 | Philips 55PP9701 55" Rear Projection...
Problem with Projection TV
This set is very common for the str typr power regulator to go out on it. Its not a consumer replaceable part. Please find a trained tech to assist you with this repair. Good Luck
Aug 09, 2006 | Toshiba TZ55V61 55" Rear Projection...
Televison & Video Logo
56 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
