Question about Garden
Hozelock 1313-0000 pond filter, clips won't clamp
I have a Hozelock 1313-0000 pond filter. Works fine EXCEPT... I can no longer get all the clips to clamp down, resulting in the watert pouring out where the two open clips are. Can't figure out what to do. Have tried cleaning the top, checking the O-ring... nothing is working. Any suggestions?
I have exactly the same unit as you and also suffered the seized clip problem. I found this was due to debris (fine grit) getting lodged under the clip hinges ands the easiest way to get rid was to flush it out with a high pressure water jet. also you need to make sure that the large "O" ring is seated properly. The clips latch easier when a downward force is placed on the top.
Hope this helps.
Posted on Sep 17, 2011
Hozelock bioforce revolution filter
yes you can buy them
http://www.hozelock.com/our-products/aquatics/bioforce-revolution/
May 19, 2016 | Hozelock Garden
Filter works fine, except one side where it clamps down is leaking. Other than that it works great and I don't want to replace it. Any ideas?
Is there a gasket or o-ring that is damaged or bad? IF not you can run a bead of silicon around it where the surfaces join and let it dry before you put it together. This would make a gasket.
Apr 18, 2015 | Tetra Pond Bp4000-uv Koi Pond Bead...
Need instructions on how to install hozelock cyprio filter & pump
need instructions on how to set up filter, hazelock cyprio please
May 21, 2011 | Hozelock Cyprio Prima Xl 3400 Gph Pump
Hi, I have a Hozelock Cyprio 1313 filter I inherited with my pond and new house. I Cant seem to get it working without water pouring out the two holes on the top and elsewhere. I'm not sure if I am putting...
Hi - I'm Simon from Hozelock. There should be a big o ring that goes between the lid and the tank to make a seal - is that missing ? Also there should be clips that hold the lid to the tank. Both pieces are available as spares, at www.hozelockservice.com - any probs contact info@hozelock.com or @hozelock (twitter) or Hozelock on Facebook. Best wishes.
Feb 25, 2011 | Sport & Outdoor - Others
I have a hozelock bioforce filter that i have
Sounds like the the bypass valve may have been disturbed and so water is coming out of the air bleed hole.
I suggest you turn off the pump, remove the bypass valve cover (clear part that quater turns off bayonet style), extract the red valve (careful not to lose spring), rub some pertoleum jelly (vaseline) around the seal of the red valve, replace spring, red valve, press the red valve a few times to ensure it returns, replace clear cover and turn pump back on.
This should ensure the valve is working.
May 23, 2010 | Hozelock Garden
Hozelock Bioforce 9000UVC pond filter. Do I put the coarse filter in first?
Yes usually one goes from the Coarsest, first and out to finest on top.
May 06, 2010 | Garden
How do you assemble 2in1 hozelock wall mounted compact reel
how do you assembly the 2in1 hozelock compact reel
Mar 10, 2010 | Hozelock Garden
Garden Logo
462 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
