Question about Fedders AED24E7F Wall/Window Air Conditioner
Our Fedders through-wall unit (A2T10F2B) turns on, and the fan works at various speeds, but the unit does not cool. What should we do?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The cause of not cooling can be Drain, Sensor or Electric Control might have gone bad. First of all you’ll need to check that the condensation drain is not clogged and is working fine. Also check that the thermostat sensor behind the control panel has not gone bad. The sensor should not be touching the coil but instead it should be near to it. Please check and adjust it. The thermostat sensor measures the temperature of incoming air into the evaporative coil. Due to malfunction of the sensor the AC will not cool normally. As the ACs are turned on and off frequently the fan controls and compressor may also go bad. Please also check that there is no corroded wire. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 05, 2010
  • meredith_gor Jun 05, 2010
    Thanks for the response. What you're suggesting sounds like something only a professional can do. What is the ballpark estimate of having this kind of problem repaired by a professional?
  • Rylee Smith
    Rylee Smith Jun 05, 2010
    Yes you
    are right. The cost of repair by professional might run from $60-170 if the
    compressor is fine and the parts to be replaced. In addition, the cost of labor
    just to showing at your place might be $70 or more. Please do accept the
    Thanks
    Rylee
This is a wall unit and it works, but it does not blow cool air it blows air like a fan. That is the only issue I detect. sounds fine.
Make sure that the temperature SP is low so that the compressor should run. If everything that should work appears to be working except for the actual cooling part, then perhaps you had a refrigerant leak. Could you open up the unit and check the refrigerant pipe connections to see if there's anything that look like corrosion.
Jul 19, 2011 | Fedders A1A10W2B Air Conditioner
Purchased a fedders a/c 18000 unit still under warranty. called the 800# they said company had filed bankruptcy and were not responsible for repairs. 350$ mistake. Fan runs too slow for unit to kick in....
Check the capacitor for the fan motor. You can do that with a multimeter with the capacitor test function or if the capacitor looks swollen then it is probably bad. Also, make sure the fan rotates freely by hand. Let me know if you need more help.
Jun 08, 2010 | Fedders 12,000/10,200 BTU Heat/Cool Room...
Maytag M6Y18F7A Air Conditioner troble light turns off
you have to open the unit up or atleast see if the fan is failing. The blower motor is usually a double shaft and cool the compressor and also blows the air across the evaporator. Look for the air to stop blowing then the compressor to shake from overheating.
Aug 12, 2009 | Fedders AEY08F2FCOM Wall/Window Air...
We have a Fedders window unit and we do not have an owners manual. When we plug it in it beaps and then blows air for 2sec and then it goes off with the signal E3 showing in the digital box. We need to...
Without the model number, I can't point you to the exact manual for your particular unit. However, here's a link to a web site that has about 38 manuals for various Fedders models. You can download a manual and/or users guide for free and look at the operation and troubleshooting sections to see what you need to do to get your unit working properly.
Just scroll down the page once you get to the web page to locate your particular model number, then click on it.
http://www.retrevo.com/samples/Fedders-Air-Conditioner-manuals.html
Hope you found this helpful and best regards!
Aug 06, 2009 | Fedders Appliance Air Conditioner Wall
Fedders wall air conditioner
If the compressor only turns on after the units it's shut off then it is a control board problem (stuck relay)
Jun 19, 2009 | Fedders AEY12F7F Wall/Window Air...
Heat doesn't work on ac
You need to check if the heat strip is still good on it or that it is receiving power. If its getting power, then the strip is bad.
Apr 01, 2009 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
I have a thru the wall fedders ac unit. The heat stopped working when you turn it on it just hums.
no blower !!! or heating element is bad or switch try putting the fan on only if it works than it is probaly the switch not letting the blower on only heat
Apr 01, 2009 | Fedders Y Chassis AEY12F7E Air Conditioner
I have an older unit need to know what the top knob does
One of the knobs controls fan speeds, cooling speeds and an off position. Center knob controls temperature and bottom knob more than likely controls air exchange. As for the front cover it would depend on the units age as to if it would be available.
Jul 05, 2008 | Fedders AEQ07FBG Air Conditioner
FAN NOT WORKING*
If the fan will no run at all iit may have a capacitor bad, swelling around the top, or you may just need to replace the motor.
Aug 25, 2007 | Fedders A6X05F2D Air Conditioner
Fedders AED24E7F Wall/Window Air Conditioner Logo
204 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
