Question about Boating
My volvo penta sail drive has an intermittent fault in that it wont engage in forward. I've disconnected the cable from the controls to rule out a cable problem - I can enage the gearbox in astern but occassionally (particularly when I want to get power on quickly!) it won't properly enage in forward. I'm assuming it's a clutch problem but was wondering if there is any adjustment on the S drive? The engine is an MD2040 (2002) and as far as I'm aware the boat has never beenused for chartering. She is a Hanse 411.
Operators of Volvo Penta's S-drives have been experiencing faulty clutch engagement problems reporting slipping, no forward power and a few other undesirables.
It has been found that the problems lie with the transmission discs & the type of oil that is currently being used.
It is important to use high grade friction transmission discs with better specifications than the originals i.e higher coefficient of friction for greater grip, higher durability to take the high intensity of the engine, and higher wear rate for longer lasting friction discs. The part numbers for these are as follows:
3582571 - Thrust Washer
3582578 - Friction Plates
3582579 - Steel Mating Plates
These discs are available from Industrial Friction Materials Ltd with over 37 years of technical friction experience.
The current oil being used in the Volvo Penta's S-drives is the ATF Fluid which has a viscosity of 6.1 at 100C and 30.1 at 40C this oil is too light and doesn't give much protection to the clutch plates.
It is recommended that the operator switches to SAE 15W40 which is a heavier engine oil and has a viscosity of 15 at 100C and 101 at 40C.
It is possible to replace oil without laying up the boat but using this method will leave some ATF oil in the stern drive.
Contact details:
Unit 7,
East Moors Business Park,
East Moors Road,
Ocean Park,
Cardiff
South Glamorgan
CF245JX
Web: www.industrialfriction.com
Email: info@industrialfriction.com
Tel: 02920 499111
Alt: 02920 499121
Fax: 02920 490011
Posted on Aug 20, 2012
2 Suggested Answers
  • 677 Answers
SOURCE: my gearbox is slipping on my boat the gearbox is a
If you mean that the g/box is slipping when you give it power,there may be 2 things.If you give it power and it slips and you cannot get drive,the propeller hubs need fixing.They are between the driveshaft and the prop.Its a rubber bush that stops major driveline damage if you hit something.2nd.If you hear grinding when you use the gears,it needs adjusting.If you dont hear grinding,its the bushes in you prop hubs.Hope this helps
Posted on Jun 09, 2010
How do I find where the hydraulic pumppower trim is on a Volvo penta ad31 boat motor
Mounted to the inside transom. Usually on the starboard side.
Oct 16, 2016 | Volvo Cars & Trucks
Replaced gimbal bearing and can not get the alingnment tool to go in.
Check the factory tool with the shaft. Count the splines/teeth. I doubt they are balanced , but make sure there isn't set place the shaft has to go into. I would most likely say you received the wrong part. Factory, doesn't mean right. Especially dealing with a 98.
May 23, 2016 | Volvo Cars & Trucks
The drive cable came off as i was engaging it & i can't figure how to replace it
TRACTION DRIVE CLUTCH CONTROL
CABLE
6.1. The drive control is on the right side of the handle bars
6.2. Stop engine and allow it to cool disconnect disconnect
the spark plug and ground it to the engine.
6.3. Confirm that the fuel level is low enough to prevent spillage through the gas cap vent with a plastic bag between the cap and the filler neck.
6.4. Carefully tip the snow thrower forward so it rests on the auger housing.
6.5. Mark the bracket to the frame as demonstrated in figure 5.2
6.6. Detach the z-fitting end of the cable from the engagement handle.
NOTE: The cable routes down to the cable guide pulley that is mounted on the drive cable adjustment bracket.
6.7. Remove the bottom access panel.
6.8. Detach the spring end from the friction wheel support bracket.
6.9. Examine the removed cable: If the cable failed because of something other than normal wear, identify and correct the cause before returning the snow thrower to service.
6.10. Install new cable by reversing the removal proceedure.
6.11. Run/test/adjust the tension on the traction drive
clutch control cable.
Feb 15, 2016 | Craftsman Snow Blower / Snowblower Bottom...
Please direct me to a link for Volvo Penta Sail drive 130S. Kind regards. Wim van Pelt.
http://www.volvopenta.com/volvopenta/na/en-us/marine_leisure_engines/drives/130_s_saildrive/pages/130_s_saildrive.aspx
Apr 10, 2011 | Computers & Internet
I need to find a free repair manual online for a volvo penta motor 1979
i have a fivehorese penta outboread engine is it water cooled or air cooled
Apr 01, 2011 | Volvo Boating
Volvo penta 740 lower unit will not go down.
Kind of sounds like the trailer switch is in control. Many of these switches have lockouts and if you move the outdrive past the trip point the other solenoids are dead. Watch fingers. There may be a tilt switch on the water side of the transom in the pivot housing.
Jun 26, 2009 | Boating
Volvo penta boat manual
Thank, but I have managed to get manual on engine
Aug 20, 2008 | Boating
Boating Logo
551 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
