Question about Kenmore Washing Machines
Th belt on my kenmore wash machine broke and I am trying to replace it
  • kellylynnae Jun 05, 2010
    Rylee--
    The model number is 72870110 serial number is c83084839---it is very old we know...if we could see exactly how the belt goes on it would help...
    Brigadier General:
  • 8,619 Answers
Please let me know the model number of your Unit so that I can provide you with model specific information.
Thanks Rylee
Posted on Jun 05, 2010
  • Rylee Smith
    Rylee Smith Jun 05, 2010
    Unplug
    the washer from the power socket and mains and lay it on its side to get
    underneath it. Now rotate the pulleys and pull the belt off from them. Attach
    the new belt by placing it over the pulleys while slowly rotating them. Put the
    washer to its normal position and plug it back in the power socket and mains
    and switch it on. Now run a cycle to check whether the belt is working properly.
    Please do accept the solution if the issue is resolved or post a comment
    for further assistance.
    Thanks
    Rylee
Kenmore 110.27841600 sounds like screeching belt
The is is a belt. Open it up and look for th eproblem or just replace the belt.
www.searspartsdirect.com/partsdirect/brands/kenmore-parts
Jul 08, 2014 | Kenmore Washing Machines
I have a top load Kenmore 110.27731600, purchased in 2007. It will no longer agitate for any cycle. Previously the agitator seemed to "slip" like a belt was getting loose, altho in reference...
There has to be a belt. Must be broke, or motor could be burnt up, too many heavy loads will do that. Will be on bottom of unit naturly. Check to see if it is broke.
Feb 22, 2011 | Kenmore 27731 Top Load Washer
Hey bud, i replaced my kenmore washer with a new coupler, but still it will not spin??
inspect under the washer. look at springs for broken or one that may have come loose. inspect drive belt for broken or off pulleys. the drive belt is not turning pulleys, belt maybe broke or outa pulley grooves. or belt tension springs are broken or unhooked. good luck!!
Jan 09, 2010 | Kenmore 24032\24036 Top Load Washer
TOP LOADER KENMORE WASHER FILLS UP BUT DOES NOTHING ELSE.
Sounds like belt is broken. Open front cover and look at belt, if broke replace. If not broke try unplugging for 2 minutes, plug back in then open and close lid 7 times slowly, this should reset the electronic motor.
Jun 05, 2009 | GE WBSR3140DW Top Load Washer
Won't spin after the wash cycle. is there a belt that needs fixing or something else causing the problem?
kenmore has a motor coupling that woill break to protect the motor. if it wont spin you need to replace that. take off the cabinet, then pull th pump and motor to ge to the coupler. 2 plastic pieces with rubber in the center
Feb 17, 2009 | Kenmore 24032\24036 Top Load Washer
PLASTIC SECTION BROKE-
I know this image may be hard too see. If you can give me th number on the diagram of the part , I can get you a part #. The part# 136948, isnt a valid part #, hope this helps, Dave www.washermd.com
Dec 17, 2008 | Kenmore 98702 Stacked Washer/Dryer
Older Style Top Loader Washing Machines
if the image on your posting is correct and model number 2 there is no belt washer is driven by coupler between motor and transmission it could be broke if washer drains but won't agitate or spin ..remove end caps on console by pulling up remove screws on each end of console lift console up and roll back remove clips on each corner and lift cabinet forward and off remove pump clips remove motor clips by removing screws first drop motor remove coupling and replace
Aug 06, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
42 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
