I have a 3 speed ac motor to replace a single speed motor. How do I wire it? connect the white (N) and the Black (H) wires only and cap the other speeds yellow and red? or do I group all three speeds together knowing capacitor connections are brown.?
    Scholar:
  • 45 Answers
Do not connect all the speed together. Do you have an RPM of the old and new motor. I think I can help you out if I had that info. Let me know.
Posted on Jun 05, 2010
I have a sears whole house fan.The replacement motor has 2 poles ,the original has 3.The wire coming to the motor has 3 wires:black,red,white.The fan is 2-speed.This is the right motor.How should the...
The white wire is neutral which is how the current makes a complete path through the fan then back to the panel and operates the motor. the replacement switch you have is a two speed black(high) red (low) switch. If you had 3 speeds before and wish to continue getting all 3 you will need to get a compatible switch. Otherwise eliminate the medium speed (blue) wire and use the switch you have. If the fan has a wire connector system just cut the copper tip even and place a orange cap of wire cap the size that fits tightly to provide good protection.
Apr 07, 2013 | Dryers
Im replacing a 2 speed Hayward motor with a AO smith 1 speed motor. I need to no how to wire the 1 speed
to wire a single speed motor you use only the black, white and green wire. there is usually a wiring diagram on the side of the motor to show how this is done.
no wiring diagram then put the black wire on the L1 or H1 post and the white wire to the common and of course the green to ground
Aug 21, 2011 | AO Smith A O Smith Motors Century 1hp 115v...
I have a 3 speed fan with a red, blue, black an white wires, how are the supposed to be wired with power. the wires go to a little black box that appears to just be wires with no circuit board
The BOX is a GE splicer - with 6 wires - 2 grey power wires, then the red, blue, black, and white from the fan motor. I have the same problem and cannot find another GE SPLICER 3 SPEED SWITCH for the fan. All switches that I have tried have 4 connections.........so a WIRING DIAGRAM would be GREAT!
Can anyone offer any help? I have tried every electrical store in the area!
Thanks
May 29, 2011 | Patton U2-1887HO Floor / Box Fan
My pool originally had a 2 speed AO Smith pump motor. Several years back it was replaced with an AO Smith single speed motor. I am replacing that motor with a new AO Smith single speed Centurion Switchless...
Is it going to run on 230V then? If so you would normally use red and black. The white wire should be a neutral and the ground wire is obviously ground.
Do you have a meter you can use to confirm the voltage between the wires? If you do you'll want to start with red and white since you seem to think black was not being used before. If the voltage reads 230 and the motor is set up for 230 then attach one wire to L1 and the other to L2...it will not matter which is connected where as long as one is on each terminal. Insulate the black and ground the ground lead to the motor ground screw.
If the voltage is not 230 between those two check between red and black. If that is the 230 then insulate white and put red and black to L1 and L2.
John
May 23, 2011 | AO Smith 2 hp 3450rpm 56C Frame 230 Volts...
I have a rheem ac. the fan motor quit. the replacement has 2 xtra wires. howm do i hook it up
Without knowing what was there and what you are trying to install exactly it is impossible to give a definite answer...
My feeling that you are replacing a single speed motor with a multispeed motor and that the wires are just extra speeds... if so hook up the black wire, white, and browns,and tape of the other colored wires...
heatman101
Sep 20, 2010 | Heating & Cooling
Attic fan motor replacement
It sounds like you are replacing a two speed motor with a single speed. Check the side of the old motor and see if it has high and low speed wiring schematics. If so you need to replace with same model number. Good luck!
Jul 05, 2009 | Heating & Cooling
Trying to install a fan motor for my outside ac unit replacement motor has 5 wires on it. my old on had only 3 driving me nuts
Your old moter had three wires. Common High and brown for capacitor. This one sounds like a two speed. Dont worry Now you have two brown wires for you capacitor instead of one. Tape off brown wire with white strip. Connect other brown to cap. You should have a white or yellow for common wire and black for high. Tape of the other extra wire and wire in like the three wire. Rusty
Jun 03, 2009 | Continental CE-PAC1163 Air Conditioner
Told motor was bad, replaced motor, new motor does not run
Black to Black, Purple to White and the new motor requires a run capacitor which brown goes to one side of capacitor and brown/white goes to the othe side of the capacitor. This is providing the old motor is a single speed. If the old motor is a two speed you have an incorrect replacement motor.
May 02, 2009 | Heating & Cooling
Replacing blower motor in furnace w/Fasco brand #D727
Some one missed the wiring diagram. I believe its like this:
L1 = Line 1 = (Hot all are same thing)
Black Hi
Blue Med
Red LO
Now usually the black is for AC and connects to a normally Open (NO) contact on the blower relay.
The heater speed (either red or blue) go the the normally Closed (NC) on the blower relay and on one side of this wire or contact on the relay it goes to the heating blower thermostat on the furnace.
The remaining wire (blue or red) you tape off.
L1 also feeds the Run Capacitor on 1 side and the Brown wire feeds the opposite side
The white wire is Neutral and goes to the neutral on the main line.
If this helps you please rate me accordingly and good luck.
Mar 13, 2009 | Kitchen Appliances - Others
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
