Question about Jenn-Air JED8430 Electric Cooktop
Clean stainless stove top
Browned spots. don't want to scratch
  • 2,272 Answers
Tips:
    1. When cleaning control knobs and control panels on cooktops and ranges, be careful that you don't scrub off the markings. Treat these components and their markings gently.
What You Need:
1)Manufacturer's instructions.2) Plastic scrubbing pad.3) Dish soap 4) Cleaning cloth 5)Abrasive cleaner (optional) 6)Smooth cooktop commercial cleaners
1. Clean an enamel surface:--Use a plastic scrubber and mild detergent or dish soap and water. Don't use abrasive items that can scratch your enamel. Enamel can stain, so it's important to wipe up spills right away. Be especially careful of acidic spills like vinegar, tomato products, lemon juice, and other citrus products.Pull off the knobs and clean them and the area around them with dish soap and water. Raise the cooktop to wipe up spills that may have accumulated beneath the cooktop surface.
2. Clean the coils:---Electric coils don't need to be cleaned because of their self-cleaning nature, but gas burners tend to accumulate layers of thick grease and spills that turn into burned on junk. You may need to soak the parts in hot water and dish soap or even scrub with a plastic scrubber. Occasionally only an abrasive cleaner will do the trick. Don't forget to wipe down the drip pans and bowls underneath the coils with a mild abrasive, or soak them to remove stubborn spills.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jun 05, 2010
What kind of cookware is recommended for glass top stoves
Glass ones work best, but any heavy metal will also work. Heavy gauge not heavy weight. The lighter metal tends to bend and warp after a lot of use. If the bottom of the pans are not absolutely flat, these stoves will not heat the pan very well, which is why the glass cookware is the best to use, since it will not warp.
Feb 27, 2015 | Maytag 6.2 cu. ft. capacity electric range...
Fix scratches on stainless steel appliance
The professionals in order to remove the scratches from st. steel they use special metal wire meshes like soft scotch bride attached on special rotary milling machine. They brush it in the direction of the grooves on the st. steel surface. They start with a hard brush and they reduce the strength until they finalise it as the original finish. If it a brush surface this is more easy than a polished mirror surface. These procedure need experience and care so you will not end up with more damage than the original one.
Dec 29, 2012 | Electrolux 30" Electric Hybrid...
I cannot get my burners on my stainless steel gas stove top clean
What I would try. Assuming the "burners" means the cast iron assemblies on top of the stainless steel, remove them to an area outside. Perhaps on a piece of plywood, and clean them with oven cleaner. Grease may drip off them, so a deck or driveway are unacceptable. Wear gloves and watch splatters. Wash thoroughly with fresh water before reusing. Beware. Caustic chemicals can discolor stainless
spencer
Aug 20, 2010 | Thermador 37 in. SGSX365 Gas Cooktop
How to remove brown scorch mark on stainless steel cooktop cover
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Mar 26, 2010 | Jenn-Air JGC8536 Gas Cooktop
Scratches on New Wolf Gas Cooktop
The good news is you have a great product! You just need technique and the "Green" cleaner DeBruce Polish. Use DeBruce Polish and a cloth for clean ups. DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. We buy Debruce Polish at debrucepolish.com
  • Firstly clean with DeBruce Polish to clarify area.
  • you may have to "re-grain" those finely scratched areas.
  • Blend or "scratch out" the misdirection scratch's with new "controlled" scratching, useing a 3M scotch brite #7447 you get at auto parts store (Nappa). Use medium very firm pressure.
  • -Re-clean with DeBruce Polish. Touch ups are now a breeze.
Feb 13, 2010 | Wolf Range 18 in. SPR-100 Gas Cooktop
Black spot on glasstop Kenmore stove
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Jul 23, 2009 | Cooktops
How to remove burnt grease, fix lightly scratched black stovetop?
Hi, I assume we are talking about a flat glass top. First the bad news. using any abrasives will permanently scratch the glass hence the dull spot. You can however make it look a little better. Grease spots and the like can be removed with a flat razor blade scraper which needs to be held flat to avoid the corners making scratches. Use any good glass/ceramic cooktop cleaner ( which is the ONLY cleaner you should ever use ) (available in your local grocery diy store and some hardware stores). The cleaner is a thick liquid, put about a dime size drop on each burner area and use a paper towel to buff out the finish like waxing a car. Once it looks clean flip your paper towel over and shine the top to like new. Good Luck!
Jan 28, 2009 | GE 36 in. Monogram ZEU769 Electric Cooktop
Discoloration of cooking surface (darkened) on Bosch stove
I'm Bruce of DeBruce Polish, our new polish is non-toxic and odorless and non abrasive, should take care of your problem. We designed it for stainless steel, and have faboulous results on ceramic stove tops, and chrome and many other uses. Even removes permanent magic marker. web site will be up soon debrucepolish.com. Phone 612-220-2236.
Jan 02, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Cleaning area around burners
Try regular oven cleaner (not the overnight kind) . This will work if there are no aluminum or painted parts. Don't do this if the instruction manuel says not to.
Jun 12, 2008 | Jenn-Air JGC9430ADS Gas Cooktop
How to clean the stainless steel stove top
try a non abrasive cleaner like bartenders helper. it wont scratch and should help to tone down some scratch marks.
Aug 04, 2007 | Thermador 37 in. SGSX365 Gas Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
119 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
