Question about Garden
Choke lever . Can I fix this myself? broke off and
Choke lever broke off and gas tank inlet line leaks. Can I fix this myself?
    President:
  • 1,545 Answers
According to the model, maybe JB Weld the choke lever back together and fuel lines are completely replaceable....get 'um at a lawnmower parts/repair shop. They are Tygon lines.
Posted on Jun 11, 2010
I have a Ryobi S430 4 stroke Weed Eater Trimmer. How many times do i pump the choke (primer) to start cold?
Page 4 and 14 of the manual. A choke is just a device that reduces air flow to the carburetor by closing a flap. You don't pump it, you just move it to the full choke position. I think you may be confusing the 'primer bulb' which pumps fuel from the tank to the carburetor.
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/s430_ry34441.html
To start a cold engine:
? Slowly press the primer bulb 10 times.
NOTE: After the 7th press, fuel should be visible in the primer bulb. If it is not, continue to press the primer until you see fuel in the bulb.
? Set the choke lever to FULL CHOKE position.
? With the throttle trigger at idle, pull the starter handle sharply until the engine attempts to run. Do not pull the starter handle more than 4 times.
? Set the choke lever to HALF CHOKE position.
ryobi s430 4 cycle weed eater manual Google Search
Mar 20, 2018 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Hard starting craftsman riding 24 hp mower
If your fuel filter has no fuel perhaps you have a leak or loose gas fitting . try tighten all gas fittings from gas tank to carb.
If the gas tank is higher then the engine then it may be gravity fed (no fuel pump).If you do have a fuel pump the make sure it's in working order. Make sure there's no blockage in your fuel line.
Oct 03, 2016 | Craftsman Garden
Mine starts and runs only on choke and it will continue to run on choke but as soon as you try to put it on full it fluds out. I think it might be the needle valves or something? It also leaks gas when...
pull apart the carb,sounds like the float is getting hung up.Also clean out the fuel tank and add new fuel and add a gas stable pruduct,also excersise the unit at least once a month,generators like to run
Jun 12, 2011 | Briggs Stratton H7159 & Stratton® 5500,...
My weed eater will run with the full choke but want in half choke or run mode.
There may be a filter clogged.Check the gas tank for a filter on the gas line in the tank.Also inside the carb is a very small screen.Inspect the gas line and the primer bulb for small leaks.It may be hard to find but the oly reasons for it to act this way is restricted fuel flo or air getting in the fuel system.
May 14, 2011 | Computers & Internet
I have a Ryobi HT26.In the back of the primer under before the gas tank is a choke lever and throttle lever.My choke lever is connected to nothing in the back or front of mygas diaphram.Does'nt it soppose...
If you remove the air filter you should see the choke butterfly valve on the air intake to the carburettor.
The choke lever should be connected to the axle of this valve on the outside of the carburettor.
Apr 13, 2011 | Ryobi 26CC, 22 In. Hedge Trimmer
My 2003 yamaha yz450f will back fire the whole time when i stop giving gas, with choke on or off and if i put choke off it dies
there may be a problem with the exhaust valves first check and adjust the clearances,
another reason can be leaking inlet or exhaust gaskets
Mar 15, 2011 | 2003 Yamaha YZ 450 F
Motor will start on choke setting and then it immediately dies when moving the choke lever to the run position. Cleaned carb, new plug new air cleaner and checked all linkages. the motor has new oil and...
You say you cleaned the carb. If you did that by spraying cleaner in through the choke, that's good, but it doesn't get to the root of the problem. The problem is getting the gas into the carb. Try this. drain the gas. Put a small amount of carb cleaner and gas in the tank (about 1:1) Start it up, but don't run it dry. Let it sit for an hour. Then start it up and run the tank dry. Then try just a little gas to see if that fixed it. If not, repeat. Good luck Al K
Dec 23, 2010 | Honda Garden
Turns over but will not crank. A litle gas on the
sounds like a fuel system problem If the machine has been laid up I sugest you drain the fuel from both the tank & carby remve the fuel line from the tank make sure that there is adequate fuel flow from the tank if this proves to be good you might also want to check the inlet manifold for leaks if it is sucking air this can cause to weak a mixture ie to much air try starting it with the choke closed if it starts on choke it is almost certainly a leaking inlet manifold all the best Geoff
Mar 22, 2010 | 2003 Yamaha V Star 1100 Classic
Will not run unless on choke
carb needs to be rebuilt and fuel filter changed in gas tank
Aug 13, 2009 | Garden
Garden Logo
103 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
