Question about Gateway GT5465E Refurbished Intel Desktop PC - Intel Pentium Dual Core E2140 1.6GHz, 1GB DDR2, 320GB
Computer suddenly shut down and won't restart
I was on the internet and it turned off suddenly and will not turn back on. Power button lights but nothing happens.
    Scholar:
  • 71 Answers
This type of shutdown problem occurs mainly due to following few reasons, 1) SMPS problem 2) RAM failure 3) Over heated mother board chip(s) or seldom over heated CPU 4) Virus or worm problem or OS problem. 5) Over heated power cords
Do the following steps one by one (to detect the exact source of problem) First replace the CMOS battery, change SMPS, check power cord, run the PC directly (without UPS), remove the data cable from hdd. if it runs well then set the data cable with hdd, if it does not work then definitely there is mother board/cpu problem. And if it creates same problem after fitting the data cable - change the hdd or format hdd and reinstall os. your problem would be solved.
Posted on Jun 05, 2010
2 Suggested Answers
SOURCE: Nothing happens when I push the power button
unplug the power cord and give the powersuply a little pressure after plug it and power on
Posted on Dec 15, 2008
The power went out here at work and my acer desktop wouldn't log into anything (ie email, internet) when the power came back on. So I clicked shut down and it turned off but now it won't turn back...
try taking out all peripherals like mouse printer keyboard leave screen pluggged n then press and hold the power button for 2 minutes then plug in your mouse and keyboard and see if it boots hope this helps
Sep 14, 2011 | Acer Aspire™ T180 PC Desktop
The laptop shutdown and won't repower on.
"since then the computer will not turn back on".. (sic) At all? not properly? exactly what do you mean? Can you do this ->> Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 27, 2010 | Computers & Internet
My computer get restarted very often
Perhaps the computer is overheating and shutting down to protect its components. If so, blowing out the inside of the computer and the heatsink fins on the processor could alleviate such a problem.
When a computer shuts down for such protection, it seldom damages the harddrive. If there's a sudden loss of power, a surge of power across the heads could damage the disks as the head drifts across them. Usually a disk check can repair this type of damage. But even with damaged sectors, most data would be recoverable.
May 07, 2017 | Yahoo Messenger
When I press standby button the standby led doesn't turn on
First, make sure you have an internet connection. If so, shut down the modem. Pull out the power cable and Coax cable from the back of the modem. Then first put the power cable in, then the coax cable and then turn on the unit. Restart your computer to verify a connection. Then try to press the standby button. If this doesn't work call your internet provider and they can reset the modem remotely for you.
Good Luck.
Jul 08, 2009 | Arris SURFboard SB5120 Modem
PC will not start-up after sudden crash
try unplugging the power cable, holding down the power button for 10 seconds, then plugging it back in and turning it back on. also, there should be a set of 4 lights on the back of the dell (A, B, C, and D) for diagnostic purposes. Check them and compare them to your model's light diagnostic look-up on Dell's website.
Mar 25, 2009 | Dell OptiPlex GX270 PC Desktop
HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
Jan 14, 2009 | HP Pavilion dv9000z Notebook
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Computer shuts down but does not turn off
    Mchem, you actually have 2 separate issues going on there.
    • Open control panel > open the system control panel
    • in the system properties, click on the advanced tab
    • in the startup and recovery section, click the settings button
    • In the startup and recovery dialog box, under system failure, remove the check from the automatically restart option
    • click ok
    • click ok
    • Open control panel > open power options
    • in the power options properties, select the advanced tab,
    • in the power buttons section,
    • When I press the power button on my computer: click on the drop down menu and select the shut down option
    • click ok
    Sebastien123, you only need to run the first part of this solution.
    Dec 20, 2007 | EliteGroup ECS PF5 EXTREME...
    Ps3 wont turn back on
    if you cant get your disk out of your ps3 turn off in back of console hold down the power button with the eject button at the same time turn on the console in back while holding both buttons keep holding until disk ejects might take few times
    Oct 20, 2007 | Sony Playstation 3 (PS3) Console
    Gateway GT5465E Refurbished Intel Desktop PC - Intel Pentium Dual Core E2140 1.6GHz, 1GB DDR2, 320GB Logo
    250 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Matthew Spark
    Matthew Spark
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
