Question about Canon PIXMA iP3300 InkJet Photo Printer
I HAVE LINES APPEARING ON COLOURED PRINTS
I am printing from a Canon pixma ip3300. I have tried nozzle clean, alignment and deep cleaning, all of which have not resolved the problem. It is not every print, just now and again. I have replaced all ink cartridges too, in case I was running low.
Thanks
Mhairi
Try cleaning the head with window cleaner and dry the head thoroughly
Posted on Jul 30, 2010
Prints pictures faded
On the pixma printer each time you remove a cartridge. you will need to do a clean of the nozles and print head. you can find instructions in your online operators manual. You hold down the wi-fi button and watch the
Home Click Here to Search
MG3500 series > Overview of the Machine > Maintenance > When Printing Becomes Faint or Colors Are Incorrect
Maintenance Procedure
Printing the Nozzle Check Pattern
Examining the Nozzle Check Pattern
Cleaning the Print Head
Cleaning the Print Head Deeply
Aligning the Print Head
Page top
error light flash. 1 flash release prints all saturation levels2 flashes prints the head alignment chart. 3 cleaning 4 flashes deep clean and so on. or its a transfer problem and this case do a transfer belt clean, and a head alignment.
Feb 28, 2014 | Canon Ink Cartridge for Pixma MP252
Canon pixma mp530 not printing colour. The cartridges are new, when I print an alignment, no colour prints, only the black and white. I've performed a clean, deep clean, print head alignment, nozzle...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jun 15, 2011 | Canon PIXMA MP530 All-In-One InkJet...
The prints are coming out distorted and not aligned. Have tried print head, deep cleaning and nozzle check. Cartridges are over 6 months old though.
You must align the printing heads - the option is there, in the same Maintenance window as the cleaning one. Follow the procedure.
May 02, 2011 | Canon PIXMA iP3300 Printer
Canon Pixma MP620 problem. It prints with a thick white lines going horizontally, so that the texts are faded out and not legible.
You probably need to run maintenance on the printer.
On the LCD do the following: (1)Select Settings on the HOME screen, and press the OK button. (2) Select Maintenance, and press the OK button. (3) Select Nozzle check pattern, and press the OK button. (4) Select Yes, and press the OK button. The nozzle check pattern will be printed and two pattern confirmation screens appear on the LCD.
This will tell you if the nozzles are out of alignment or not.Regardless you should not run the deep cleaning on the print heads. From the LCD do the following and make sure you have several sheets of paper in the printer;
(1) Select Settings on the HOME screen, and press the OK button. (2) Select Maintenance, and press the OK button. (3) Select Deep cleaning, and press the OK button. (4) Select Yes, and press the OK button. The machine starts cleaning the Print Head deeply. Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 1 minute 30 seconds. (5) Select Yes, and press the OK button. The nozzle check pattern will be printed. (6) Check the nozzle check pattern. See Examining the Nozzle Check Pattern. - If a particular color is not printed properly, replace the ink tank of that color. See Replacing an Ink Tank. - If the problem is not resolved, turn off the power and clean the Print Head deeply again after 24 hours. - If the problem is still not resolved, the Print Head may be damaged. Contact your Canon service representative.
Mar 05, 2011 | Canon PIXMA MP620 All-In-One InkJet...
My Canon Pixma ip3300 prints on top of an absolutely perfect printing, a sequence of stripes colored in magenta, the stripes are 2,7 mm wide and are 2,7 mm apart from each other. All other functions of...
try to clean the ink print head cartridges also its trailing (belt, pulleys) you can reach. a dirty ead may cause that or better check it to printer solution software, there you can test, align, clean printhead.
Feb 12, 2011 | Canon PIXMA iP3300 InkJet Photo Printer
I have deep cleaned the nozzle jets and I still get lineson print
this isn't a driver problem... your machine is going bad... you need a service tech to look at it... you have done all you can do...
Dec 23, 2009 | Canon Pixma iP4500 InkJet Printer
Will not print blue
clean head cardrige and calibrate color cardriges.
Jun 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon pixma ip500 horizontal bands of non-printing areas
Hi it's Gill again. I've been looking around more on the net and I think the problem is our printers need new printheads which I'm told are spare parts easy to change. Hope this helps. Gill
Mar 18, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
Menu letters in tool button
The letters refer to the following:
A = Prints the nozzle check pattern
H = Cleans the fine cartridge
Y = Fine cartridge deep cleaning
P = prints head alignment sheet
L = prints the fine cartridge alignment sheet
U = Scans and then aligns the sheet you printed under the L option
All in the user manual in Chapter 9. Download a copy here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=13368
Nov 14, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Prints With Gaps/Lines && Bad Quality
Take the cartridge out and stand it on damp tissue in a cool place overnight then have another go Come back and tell up what result is
Apr 15, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA  iP3300 InkJet Photo Printer Logo
122 people viewed this question
old marine
old marine
