Question about Car Audio & Video
My unit security light flashes but the unit will not power on is there anything i can do to fix this issue the unit is a pioneer p-5000dvd
  • twistajay Jun 05, 2010
    there is nothing in the manual about my problem i really need help on this
  • 713 Answers
Hi,the problem is from the control board or the power IC,one of them has either lost its connection with the pcb board,or they are weak and probably needs a replacement,the solution is to take out the radio and check on this components and do the necessary replacement if it applies.
Thanks and take care
Posted on Jun 06, 2010
    Genius:
  • 1,417 Answers
what you need to understand is that it is an indication of a sensor error or low power supply . That there is a loose wire connection on the unit
what you need to do to fix it up properly is firstly put off the system for some minute then put it on again and operate it, but if that does not solve the problem then you will have to unscrew (open) the system and trace the wire down to the device sensor which flash up light when trying to operate it do some clean up on it by using soft brush on it if there is any form of dirty on it for proper indication of the device then couple it back .
please you will have to check on the remote control if the battery is still in good condition it could be the cost of the problem.
thank you and thanks for using fixya.
Posted on Jun 05, 2010
  • 516 Answers
Resistor sensing contacts are located in the ignition key lock cylinder. These contact the key resistor pellet on the key when it is inserted. When the
lock is rotated, battery voltage is applied through a fuse to the PASSkey(R) decoder module. The pellet resistance is then compared against a fixed
resistance in the module.
If the key pellet is the proper resistance, terminal A3 is grounded, energizing the starter enable relay. At the same time, a signal is applied at terminal A2
to enable the Electronic Control Module (ECM). When this signal is received by the Electronic Control Module (ECM), it allows fuel injector pulses to
begin.
If the key resister pellet is the wrong value, the PASSkey(R) decoder module will shut down for 2 to 4 minutes. During this interval there will be no
output at terminals A3 or A2.
If the ignition switch is turned on again during this interval, the timer will remain shut down for another 2 to 4 minutes. The PASSkey(R) decoder
module will continue this process even if a key with the correct pellet is used to turn the ignition back on. The timer is restarted by the ignition switch
voltage at terminal A1 when the ignition switch is turned to RUN.
Once the timer has completed its 2 to 4 minute cycle with the ignition off, the PASSkey(R) decoder module and timer are reset. A key having the correct
code can then be used to start the engine.
The security indicator is controlled directly by the PASSkey(R) decoder module. If there is a PASSkey(R) failure this indicator will be grounded by the
PASSkey(R) decoder module with the ignition in RUN, BULB TEST, or START. When the ignition switch is first placed in RUN, BULB TEST, or
START the indicator lights for about 2 seconds as a bulb check.
  • 1,284 Answers
Hi, you have to go through the instruction manual to find what to do whenever the device flashes security light....
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/AVH-P5000DVD_OperationManual0121.pdf
Take care
  • Shehu Pro
    Shehu Pro Jun 05, 2010
    O.k, i will get you the solution ASAP
The HDMI light on my receiver is flashing. The power button does nothing, and no other inputs do anything. There is nothing on the screen, and neither of the knobs do anything. I unplugged it for a...
For model vsx-523-k with HDMI light flashing.... PLUG THE UNIT IN AND WITH THE HDMI LIGHT FLASHING "PRESS THE POWER AND THE AVANCED SURROUND BUTTON SIMULTANEOUSLY. .. AND HOLD FOR 5 SECONDS this clear the error. .
Aug 22, 2013 | Pioneer VSX-523-K 5.1 Channel AV Receiver...
2yr old Pioneer pdp-506 50" panel with seperate receiver unit
YOUR MAIN CONTROLLER IC (processor) is damaged you cant try ressiting it but I'm sure it wont work you need to get it professionally repaird by a qualified technician
Jan 02, 2008 | Televison & Video
When i plug the reciver in with nothing hooked up no cables no speakers nothing i push the power button and it will flash a few times then it will go back to a solid red light i cant get it to do anything...
I have the same throuble about this >Pioneer VSX-D812 and in Manual exist the next section:
Chapter 10:
Additional information
Troubleshooting
If the STANDBY indicator blinks and the power shuts off
automatically, take the unit to your nearest Pioneer authorized
service center or your dealer for servicing.
Feb 20, 2011 | Pioneer VSX-D812 Receiver
My pioneer avic n2 will not turn on,but when the
sounds like you have blown your acc fuse or your risistor on your red wire on your radio has shorted out you can bypass this wire by choping it off it dose not affect the radio ,dvd at all.
Jan 17, 2010 | Pioneer AVIC-N2 Car DVD Player
My pdp r03u has an error code e01
I have a 50" Unit with this same part, I called Pioneer and told them what was happening, they asked me to count the flashes on the monitor power indicater light and when I told them the problem they told me that it was a dry solder weld, I called a tv repair tech and told him what was going on, he had never worked on Plasma Tv's and was very hesitant to start I told him if I just brought in the Media Box and had him check the solder joints how much would he charge he told me to try he wouldnt charge me anything, I jumped on that! he saw a few issues and fixed them, I brought the unit home plugged it into the tv and the tv works just fine!
Oct 24, 2008 | Televison & Video
Pioneer DEH-1500 installation issues
Get a new unit. The damage was done before the smoke was present.
Jul 28, 2017 | Pioneer DEH-1500 CD Player
Problem turning unit on
have u got both powers correct. u only need 1 to get security light on
Sep 25, 2008 | Pioneer AVIC-N2 Car DVD Player
Pioneer plasma no picture with blinking red light
this requires a replacement of the power supply board. This is per Pioneer tech support whom resolved my issue when I called. Hope this helps!
Oct 28, 2007 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
