HORIZONTAL LINE IN MONITOR SAMSUNG 410NB - Computers & Internet
    Scholar:
  • 67 Answers
Well you can try connecting the monitor with a different video cable to see if that makes a difference but most likely it just needs to be replaced. I recommend calling Samsung to start the replacement process.
Posted on Jun 05, 2010
How to fix white horizontal lines on middle of screen of a PC monitor?
Need to check removing LCD ribbon cable in the monitor. but it is may be a damage of LCD screen ,need to replace the lcd.but in very first check and service the lcd.
Feb 22, 2016 | Samsung Syncmaster S20b300b - Led Monitor...
Samsung syncmaster magic cx 715B my samsung cx715B monitor, have a multiple horizontal line.what is the solution of this?
The multiple horizontal lines are indicative of screen failure. There really is no repair, except to replace the display.
May 05, 2015 | Samsung Computers & Internet
Pink and Green Horizontal lines across screen
Normally, horizontal lines on an LCD or LED monitor indicate a bad control board inside the monitor. However, occasionally the problem can be caused by loose or bad cable connections. The only things that you can really do is to disconnect both ends of the monitor cable and reconnect them firmly. Also, you can disconnect the monitor cable completely and just leave the power cable. With only the power cable attached, you can turn the monitor on and off. The monitor should have a "startup screen" or display a message that says something like "Video Cable Disconnected". If the green and pink lines are still present without your computer connected, then the monitor has gone bad. The good news is that Samsung SyncMaster monitors usually carry a 3 year warranty, whereas most monitors only have a 1 year warranty. You may be able to have the monitor replaced at no cost to you if it's less than 3 years old.
Jul 27, 2013 | Samsung SyncMaster Computers & Internet
Our three year ol Samsung TV has dark horizontal lines across the top of bottom of the screen. It is getting worse
Welcome to fixYa!
When you see lines like these across your LCD, it indicates a problem with your monitor's electrolytic capacitors.A faulty filter capacitor in the power supply board (SMPS board) can cause horizontal lines across your monitor screen.Horizontal screen lines are one of the most visible problems I see in LCD monitors & TV's that are 3-7 years old. It can happen as much from heat, humidity & less-than-ideal operating conditions, as it can from fluctuating current supply or manufacturing defects.
The way to repair horizontal screen lines is by removing the capacitors from the printed circuit board (PCB) and testing them with a LCR meter.
If it shows zero, there's your confirmation that the specific capacitor needs to be replaced.
now if you can replace them your welcome but i wont suggest that , cause you may break it more....!
any ways do comment if it helped you in any manner!
Apr 30, 2011 | Samsung HL-R6168W 61" HDTV
Horizontal lines obscuring images at bottom of screen.
well your prediction is right you just have to replace the monitor or if it is in warranty period just drop in to the samsung service center so they might help you.
Jan 04, 2010 | Samsung SyncMaster 193V 19" Flat Panel LCD...
Monitor disply movable horizontal lines.
yes you first check the supply at vertical ic 12v if present then replace that vertical ic if supply is not present then check the regulator ic in smps if faulty then replace it
Nov 20, 2008 | SAMTRON 55V 15" CRT Monitor
Horizontal lines on my monitor
I have a similar problem with a 2 year old Samsung monitor. I have tried to make a screen dump of it, but the horizontal lines do not show up then. This I have read indicates that the problem is in the monitor and not the video card.
Sep 17, 2007 | Computers & Internet
56 V - faint horizontal lines across the display
u can search problem in vertical section may be sum IC component was dry resold them .
Aug 02, 2006 | SAMTRON 55V 15" CRT Monitor
Brown horizontal lines sporadically appearing on monitor
I have exactly the same problem with the identical monitor, but I have not found any solution. It seems to be the monitor causing it because I can't see the lines, when I make a screen dump.
Jun 07, 2006 | Samsung 793DF 17" CRT Monitor
Computers & Internet Logo
David Payne
David Payne
