Question about Maytag MCD2257HES Side by Side Refrigerator
My ice maker is not working. I do not think water is getting to it.
    Scholar:
  • 44 Answers
Before You replaced the Water Valver - Shut your water off - disconnect the water line to the from the back of the refrigerator at the top where it goes into the icemaker. I used zip tie or something flexable to see if it would go all the way through to the
tube inside the refrig. If you have obstruction - use your hair dryer
to thaw the ice from inside the refrigerator tube. When the flexable goes all the way through. Hook back the water line to the icemaker. You will have ice soon. If Not, Replace the water inlet valve
Read more: http://forum.appliancepartspros.com/refrigerator-freezer-repair/93259-ice-maker-repair.html#post227249#ixzz0pzmjhvPC
Posted on Jun 05, 2010
Whirlpool gss26c5xyy ice maker not making ice, but will dispense ice and also will dispense water.
Andrea, make sure you are getting water to your ice maker. Most common ice maker problems are caused by lack of water. There is a water valve( dual) that feeds your water dispenser and ice maker that could be the culprit. Even if you are getting water out the door the valve can still be bad( separate water lines)..
Second thing to check are your optics( It measures ice level in your bin. If they are defective it will trick your ice maker into thinking its full of ice and not produce anymore.) They are located on the freezer walls just below ice maker..
Good luck
Jul 08, 2017 | Whirlpool Refrigerators
Water not getting to the ice maker kennmore 106.58212400
If you have not water getting to your ice maker than you need to follow the water service to the ice maker box or fridge. My best guess is that the water is still going to the ice maker. it is just froze up. I think you should un-plug it for a little while and see if it works after that. (if its a fridge) Hope this helps. Tim
Jun 14, 2014 | Frigidaire Kenmore Washer Tub to Pump Hose...
Ice maker wont work
The ice maker gets its water from the filter too. If there is NO water getting to the ice maker then look at the solenoid that lets the water into the ice maker. If water seems to be frozen to the underside of the Ice maker, take the unit out and allow it to dry before putting it back in.
Jan 14, 2014 | Samsung RS267TDBP Side by Side...
GE bottom freezer ice maker not working
Remember there are two sides to a dual water control valve, the water to dispenser side and the side that feeds the ice maker. Replace the WR57X10094 Dual Water Control Valve and I think you will be good to go on ice, Thanks Sea Breeze
Jul 02, 2012 | Refrigerators
Whirlpool automatic icemaker not working
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Mar 13, 2010 | Refrigerators
Getting water
I have Kenmore Coldspot refreidgerator and am having a problem with water pooling inside the fridge at the bottom underneath the drawers (mostly the left side). Where is the water coming from and it formed a thin ice.
Thanks
Nov 25, 2009 | Kenmore Refrigerators
GE adora side by side refrigerator DTL181C5RRBS
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water will not dispense to ice maker
The water dispenser in the door of my Kenmore side by side will not work. The ice dispenser does work. What do I need to do to fix it?
Thanks Kel
Sep 06, 2009 | KitchenAid KSCS25FKSS Side by Side...
Water lines i think are ok but cant get water or make ice
Check the following:
See if the fridge has a water filter...it could be plugged and need replacement...check your manual for the location and replacement procedures
Check the inlet water line to the ice maker...it could be frozen...a hair dryer can be used to thaw it out and get the ice make to work again...be careful and don't overheat the ice maker inlet water line.
Make sure the water line is ok and not obstructed or kinked
Check the ice maker water valve to be sure it opens and isn't clogged
Cycle the arm on the ice maker and wait to see if it will make ice again
Jul 05, 2009 | GE Refrigerators
Icemaker
Check the power conection to the ice maker. If that's ok, then I would think the solenoid that controls the water flow has gone bad. Unfortunately, you will likely have to replace the whole ice maker, I don't think they are reparable.
Feb 11, 2007 | Kenmore 53632 / 53634 Side by Side...
Maytag MCD2257HES Side by Side Refrigerator Logo
191 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
