Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch washing machine
Doesn't spin in spin cycle
    President:
  • Bosch Master
  • 662 Answers
You should find the filter located behind a removable plastic panel at the bottom front of washer. Unscrew it anti clockwise to remove and clean it out.
Pl rate me 'very helpful' for the free help, thanks!
Posted on Jun 14, 2010
Testimonial: "Had tried that and turned out to be worn brushes!"
  • prem mathew Jun 14, 2010
    Thanks anyway Brian, you shouldn't have voted.
Bosch Excel 1200 washing machine stops at spin cycle, doesn't seem to be draining properly. If I open front drainage hatch to let water out the machine will start its spin cycle. Happening every wash...
Your filter will be clogged, causing the empty pump not to drain in time (usually they get about 8 minutes and fault out). If the picture I have of your machine is correct, there is a small door at the bottom of the machine on the right. Open the door, unscrew the filter, clean and replace and all should be well. NOTE: It's worth tipping the machine back by 45 degrees when you do this so any water left in the machine doesn't pour out, but having a couple of towels to hand would still be a good idea.
Please add a comment if the above has not fixed your problem and I will try to help further
Aug 23, 2011 | Bosch Washing Machines
Hi our Bosch exxcel washing machine has stopped spinning and doesn't reach the end of its cycle most of the time. If it does the washing is still soaking and needs a new rinse and spin cycle after....
Hi gillsteer,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Bosch Washing Machines
Drum will not spin on any cycle.bosch nexxt 300.
http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/Washer-Parts/Model-WFMC2201UC13/1794/0153200/50033052/00003?blt=06&prst=&shdMod= If the drum is not turning on any cycle then I would suspect either the belt - Item 308; or the motor - Item 327.
If you are saying that it doesn't go into the spin cycle (but the drum turns in other settings) then I would suspect the control board - Item 333
Jun 24, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Fills with water then does not rotate, also does not spin
Check for large items of clothes being tangled if the Bosch washing machine doesn't spin. The weight could not be evenly distributed in the drum and the spin cycle will have been disabled to prevent damage to the clothes..
Load the drum with large and small clothes together and run the entire washing cycle and spin cycle again.
Add more powder and run the entire washing and spin cycle again if you haven't found tangled large items, but the spin cycle still failed. This indicates the amount of cloths was too small.
Add 1 tablespoon of fabric softener to 1 pint of water and pour it into the main detergent dispenser if there's no tangling and the load was a normal size. The cause would have been excessive suds because of too much, or the wrong kind, of detergent. Use HE (High Efficiency) detergent in Bosch washing machines.
Nov 01, 2010 | Bosch Washing Machines
My bosch front loading washer on the small cycles will not spin the water out of the clothes..why?
Does it sound like the machine is spinning as fast as on longer cycles?Some machines run a slower spin speed on small cycles which can leave clothes wetter than normal. I've got this on mine and all I do is when the wash has finished I change over to the fast spin only program which then takes it to it's highest spin speed.
Jan 25, 2010 | Bosch Washing Machines
Bosch 1200 classixx not spinning
bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
Oct 12, 2009 | Bosch Washing Machines
BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
Bosch washing machine won't spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Oct 26, 2008 | Bosch WFK 2401
When I use the spin only cycle on my Bosch WAE20260AU front loader it runs the pump for most of the cycle time. It only spins briefly mid cycle and the clothes are still very wet at the end. I do a lot of...
I have the same problem on a Miele W418 washing machine.
Just will not spin at all although the Pump out motor and the rest of the washing cycle all appear to be working.
Jun 15, 2008 | Bosch Washing Machines
Bosch Axxis WFL 2060 Front Load Washer Logo
422 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
