Question about Dryers
My dyer will not ignite - Dryers
  • yadayada
    yadayada Jun 05, 2010
    DO U HEAR THE IGNITER CLICKING?
  • Dryers Master
  • 43,501 Answers
Hi, If you have a gas dryerMy dyer will not ignite - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jun 08, 2010
Maytag atlantis gas dyer not heating
Can you look inside the door for your model number. I believe the problem is either a defective igniter or defective solenoid coils that open the gas valves=> 279834 Gas Valve Solenoid Set
4391996 Dryer-Igniter
Here is a Manual=> Atlantis_Neptune_Electric_and_Gas_Dryer_Service_Manual
I will be here if you have questions, Thanks Sea Breeze
Feb 28, 2013 | Dryers
Maytag gas dyer model dg312 is on igniting hot surface is turning on but no flame
i am not clear on what you are saying. i think you are saying that the ignighter is comming on. if this is so then there are two coils on the gas safety valve. replace them both.
Nov 22, 2010 | Maytag Dryers
I have a Kenmore gas dyer that has developed a burning smell
check vent line,either check outside to see if flapper is blowing open or disconnect vent line from back of dryer and see if it helps.if not there are two thermostats Number: 660036 Substitution: 279048 and
Number: 3387134 ,this one is on blower wheel housing and the other is in the back,take back wall off and you'll see it on right hand side on heater vent duct
Nov 03, 2009 | Kenmore Dryers
Gas dyer not heating up
Most of the gas dryers have everything accessible by simply releasing the spring clips atop the toe panel and getting it out the way.
Here are some repair pix with manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 05, 2009 | Kenmore 63942 Dryer
Dyer is not heating up.it turns on and runs but it just does not heat up i took off hose and clean . also looked in back of dyer by taking off clover to look for fuse please help .
Kenmore dryers have what we call a thermo fuse, usually on top on the burner area - I would check continuity on this unit and replace if nesessary.
If the thermo fuse is okay and dryer heats up with gas, check your igniter and/or gas unit coils.
If dryer heats up with electric elements check continuity at both element ends and/or high limit thermostat.
GOOD LUCK!
Sep 01, 2009 | Kenmore Dryers
Dyer LSG7804ABE Gas Stackable very little heat
self help is right .first i would try a load with out the ducting.if you have good air flow and still didn't dry[because now youv'e elimanated the house venting as a possiable.replace your coils
Jan 02, 2009 | Maytag LSE7806A Top Load Stacked...
My Whirlpool Duet Dryer is not heating up. Unit is only Two year
If it is a gas dryer. Sounds like thermal fuse. It costs about $12.95. Most appliance part stores carry it all the time. Very easy to replace. Also can be ignition switch (also cheap). If you know someone who is mechancally inclined, after removing fuse,they can run an electrical jumper cord to the two open ends. If the dryer begins drying, then it is definitely the fuse.
Go to Whirpool site and get part number and diagram to fix. Maytag repair can help at a costly figure after they order part since Whirpool bought Maytag.
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dyer
signal level for 10 seconds
Jun 06, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
47 people viewed this question
Top Dryers Experts
