Question about Westinghouse SK-26H590D Television
My Westinghouse SK-26H590D widescreen dvd combo won't play dvds.You can insert one but it will display "no disk".2 disks were jammed in the dvd slot and were removed(kids).I have a feeling it must have been showing the "no disk" icon so another disk was put in.You can insert and eject,it just won't read them.
  • Westinghouse Master
  • 11,800 Answers
Most likely the laser lens was damaged when the 2 disks were jammed in. You must open the tv and check the status of the laser head and its lens, if it's faulty it will have to be replaced. Fortunately this is an unexpensive part.
Posted on Jun 05, 2010
Does sk-26h590d have HD connection
It might have a built-in HDTV tuner or it may require installation of an HD converter box. If you see decimal channels such as 3.1, 29.2, etc. you have an HDTV tuner. If you see channel numbers without decimals such as 3, 29, etc. you will need to install a converter box
Dec 27, 2012 | Westinghouse Electric SK-26H590D 26 in....
Westinghouse sk-32h570d plays cd but not dvd
I THINK YOUR PROBLEM LIES IN THE DISK,IF THEY ARE BLUE RAY IT WON'T PLAY THEM HENCE THE NO DISK,IF THEYARE NOT,TRY TAKING A SHARPENED #2 PENCIL AND RUB THE WOOD BY THE POINT ON THE OUTSIDE IN EDGE OF THE DVD YOU LIKE IF YOU WOULD BE TIRWLLING IT AROUND. IT WORK DISK-CHANGERS ALL THE TIME.
Dec 18, 2012 | Westinghouse Electric SK-32H570D 32 in....
My Westinghouse 26H590D widescreen with DVD combo all of a sudden is messed up on color. It seems like the red is gone so human lips look blue, what I know from other tvs should be red come across yel
Looks like some dry solder, dry or leaky capacitors in board. Anyhow, first of all check and ensure that your input device, cables, connectors and jacks are ok and there are no loose contacts. Try working the TV on a DVD player and see. If problem persists, call in a qualified service technician.
Aug 02, 2012 | Westinghouse SK-26H590D Television
Sk-26h590d dvd player says "no disk" when a disk
No disc error can be a DIY like the following steps.
Assuming that the disc is good.
1.Cleaning the lens. - Sometimes because of dust the lens can't read any disc.
Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replacing the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser.
If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Checked the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.
Good motor - reading should be fairly high and it will spin.
Bad motor - reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If you already cleaned the lens, and confirmed that the ribbon is good as well as the motor then I've advice you to send it to repair shop because the next step should be done with an expert because it is quite technical diagnosing the fault between the pick-up lens and the main board. Have a nice day!
Thanks for using fixya.
Jan 27, 2011 | Westinghouse SK-26H590D Television
Television screen displays production: runin when dvd player is operating
television screen displays production: runin when dvd player is operating
May 07, 2010 | Westinghouse SK-26H590D Television
DVD doesn't play any disk anymore. Displays a message: this can't of disc can't be played ... I tried several different types of disks.
Same here! It would say something along the lines of "this type of disc cannot be played. please insert a different disc." it's the appropriate dvd region, i've tried all types of dvds, and it still won't work. the vhs and cd still works, it's just the dvd player that won't.
Mar 30, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Televison & Video Logo
525 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
