Question about Kitchen Ranges
Following the directions in the use and care book we cannot get the cleaning cycle to start. All works well in set up and after we have set time to clean 3:00hr it is supposed to lock and begin cycle in 5 sec, but nothing happens and the cleaning message goes blank in a minute or two.
  • ehaunz Jun 05, 2010
    Thanks for your response, but this is a problem with a double oven, not a dishwasher. The oven cleaning cycle does not begin after it has been set. The doors are supposed to lock and fan turn on to begin to clean. In our case it does not engage and begin to clean. After a minute of two it simple clears the clean command from the display showing only the digital clock.
    Genius:
  • 1,040 Answers
Dear Ehaunz,
Since your Gadget is not working as per manual, Therefore there could two types of faults viz. software of hardware.
First set your Gadget to factory defaults... still problem persist then sorry you have to get it serviced, because there could be a hardware problem.
Posted on Jun 05, 2010
    Genius:
  • 1,416 Answers
Hello
what this means is that there have been a disconnection of wire indication from it position code indicates that the water or dirty sensor reading is out of range (above 23 degrees F or above 217 degrees F)
what you need to do for fixing up this problem is to allow the ranger to dirty up properly and remove any form of dry around the wire so as to allow the indicator to read properly.
please when doing this you will have to put OFF all source of power supply from the ranger
thank you and thanks for using fixya.
  • Oloyede Monsuru Jun 05, 2010
    hello,
    remember that you were told that the problem is from the wire side
    trace the wire down to the device sensor (screen) then clean up the
    device properly or if there is any form of this disconnection from the
    wire then fix up be position it back jut on the device sensor (screen).
    but if you can not do this your self in other to avoid more damage on
    it contact a technician
    but it a simple work you should be able to do your self .
    thank you .
I have been getting the Sd code and then F21 code during regular wash. I followed directions cleaning out white filter on bottom of machine and it did not help. So I followed directions for resetting the...
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
need to replace the part but dont try it if you dont have idea how to do.
call the technician for your safety and not to waste money.
Oct 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
H E L P !!! My oven made some noises this morning when my husband was wiping down the front of the oven door. Noise sounded like the "oven was going into clean mode"....but then only lasted...
Hello.
Please apply the solution this way!
To close an oven door when it's in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven cools down. When it is sufficiently cool, the door will automatically unlock.
Thanks for using fixya.
Sep 07, 2011 | Dacor Ovens
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Wait 20 seconds.
  • Wait 20 seconds.
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 | Ovens
I have a Tromm Washer and Dryer. Washer cycle time taking twice as long as time on indicator. Mildew smell still there after I have cleaned filter and run wash cycle. Drum vibrates horribly on spin...
You may have a problem with the motor sensor. Replace the motor sensor and it should take care of the problem. As for the mold issue, purchase some washing machine cleaner and follow directions. It should take care of most of the smell issue. Good luck
Jun 21, 2011 | LG Washing Machines
Re: Kenmore Elite Washer 45996-there is mold in detergent and softner container but more on the holes above it when I pull that tray out to clean it--it is very difficult to clean those holes upside down....
The most effective way to clean mold is with bleach. If you have an empty spray bottle, mix a solution of 1 part bleach to 4 parts water. Use the spray bottle to direct the spray at every affected area and let sit for about an hour. Now, put a small amount of bleach in each container (2 ounces) and directly in the tub itself. Run a full wash cycle with (no clothes in the tub) the settings for whites. When the cycle has ended you may want to run another empty cycle if you can still smell bleach to be sure no hidden residue gets on your colored clothes. Be careful when spraying the bleach you don't spray towards yourself.
Nov 30, 2010 | Kenmore 45996 Front Load Washer
Water pump changed. car would noit start afterward.
was the pump timing chain driven!! f so thats probably your problem, timing is off. if all was ok before the job then it is the chain. get a good book, and follow directions carefully if need be. on the nissan it is reccomended to change the timing belt every 60,000 miles.
Nov 12, 2010 | 1990 Nissan Maxima
Hello, I have purchased Jura Impressa F9 about 4 years ago and have been using it a couple times daily since that time. Some time ago, I have started having problems with brewing coffee on each program....
machine is most likely clogged with old coffee grounds and needs a good cleaning cycle malf 8 is problem with the stoke of the piston can not make a complete cycle thur get your book out for machine and read list for cleaning machine follow remove power cord for a few mins. let machine cool down if hot from prior use then plug back in power up and do cleanning cycle with tablet follow book worst case would be oring seals on piston are no good or very dry making machine work to hard to move piston in this case service is needed good luck steve
Sep 15, 2010 | Jura Capresso Impressa F9 Espresso Machine
Jenn Air oven door won't open after clean cycle
Had this EXACT same problem the day before a party where I needed the oven for lots of baking.... Tried all sorts of things, was about to call a repair man- I FINALLY got it to open by following the first two directions for putting it into self clean mode (turned both knobs to CLEAN), then when it said to lock door I tried to move the lock lever and bam it worked! Give it a shot! Good luck! (:
Nov 26, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Whirlpool Flat top Accubake self clean 24 inch
Of course - Empty the oven and clear off around it.
The AUTO-CLEAN cycle time is adjustable, from 2 hours
30 minutes and 4 hours 30 minutes in 15-minute increments.
Suggested clean times are 2 hours 30 minutes for light soil and
4 hours 30 minutes for heavy soil. The last 30 minutes of the
cycle is for cool down.
To Self-Clean Using AUTO-CLEAN
1. Press AUTO-CLEAN.
2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
desired self-clean cycle time.
3. Press START.
The oven door will automatically lock. The “DOOR LOCKED”
and “CLEAN” indicator lights will be displayed. The time
remaining will also be displayed.
4. When the self-clean cycle is complete and the oven cools,
the “DOOR LOCKED” and “CLEAN” indicator lights will turn
off.
5. Once the oven is completely cooled, remove ash with a damp
cloth.
To Delay Start Self-Clean Using AUTO-CLEAN
2. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired self-clean cycle time.
3. Press START TIME.
4. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired start time.
5. Press START.
The oven door will automatically lock. “DOOR LOCKED” and
6. When the self-clean cycle is complete and the oven cools,
off.
7. Once the oven is completely cooled, remove ash with a damp
cloth.
Owner, Warranty, Installation and Parts manuals are here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
Sometimes search links don't work when copied.
Here is the direct link to the Use and Care Guide:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
Page 16 has the above instructions.
God Bless!
-Ptochos
Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Kitchen Ranges Logo
27 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
