Question about Dell XPS M1730 Laptop
How do I remove th Battery on the DellXPS M1730 Laptop
    President:
  • 173 Answers
On the bottom of the laptop you will locate the battery compartment. There should be a release latch which will allow you easy access and removal of the laptop battery. Before you remove the battery, make sure you have the system powered off. I found a owners manual in pdf format so that you can save it to your computer. This manual will provide you with additional information for any future problems or questions you may have about your system.
I hope this helps resolve any issue you may be having locating the battery. If you need further assistance, please feel free to ask.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You
Posted on Jun 05, 2010
Both fans stopped
Hi
make sure the funs are working in another machine or using a battery if it works the problem is the motherboard.
May 05, 2014 | Dell XPS M1730 Laptop Power AC Adapter /...
Adapter not charging correctly?
Does the laptop power on if you remove the battery and just have the AC adapter plugged in? If not then your adapter or charging circuit on the system-board may be defective.
Feb 05, 2013 | Dell Gaming 17 XPS M1730 PC Notebook
Backspace key no working m1730
It is most likely problem with the keypad. contact a good technician.
Dec 01, 2012 | Dell XPS M1730 Laptop
I have both US and Australian purchased DVDs. I need to unlock the region codes so they will work on my laptop
US have a region code 1 and Australia's is 4. For more details about region codes, kindly refer this site:
http://en.wikipedia.org/wiki/DVD_region_code
Hope this helps. If you need any further assistance, please feel free to come back to us. Else, please ACCEPT this solution. Best Wishes. Thanks for using FixYa.
Nov 05, 2010 | Dell XPS M1730 Laptop
Web cam very low fram rate ( regardless of light levels) xps m1730 dell. no one seems to be able to sort this. I am thinking of buying another external web cam. all the rest in the box is superb. the...
It is a 2007 model laptop. It has a 2 megapixel camera and is expected to be outdated and would not be able to compete with today's webcams. Yes, buying an external camera is the best option for you here. Here is the link of an article in 2007 when the laptop was first released. https://www.engadget.com/2007/08/23/dell-m1730-gets-confirmed-specs-and-release-date
Feb 20, 2018 | Dell XPS M1730 Laptop
My dell will not charge> at battery icon says plugged in and not charging
Battery light may sound charging but it is common for batteries to easily loose holding charge.
G
Feb 19, 2010 | Dell XPS M1730 Laptop
Pa-19 power supply for my Dell m1730 is broken
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Sep 08, 2009 | Dell XPS M1730 Laptop Computer PC...
Power issues
Dell laptops use proprietary power supply adapters. Inside the adapter there is a communication device telling the laptop the power supply is a genuine dell product. Which in turn allows the battery to charge. Anyways it appears that your charger is having problems. You should probably try to locate one local (from friend or computer repair shop) to test. if you try a good one with no problems, then just get on Ebay and get you a genuine dell charger. they are about 40-60 dollars. Or try calling dell.
If trying a known good charger doesn't correct the issue, you could have broken solder pins on the power jack inside the laptop.
If this helps you solve you issue please rate my solution.
May 05, 2009 | Dell XPS M1730 Laptop
Dell XPS M1730 Laptop Logo
Alun Cox
