Question about Frigidaire FAM18ER2A Thru-Wall/Window Air Conditioner
My window unit will not come on. I have pushed the reset button and nothing happens. The power is on because the green light on the plug in on.
  • Frigidaire Master
  • 8,220 Answers
From the diagram everything is operated by the control board, unless it has a fuse on it you can replace looks like you gonna need one.
Posted on Jun 05, 2010
Go 730 green light on but nothing happens
Have you tried resetting, either by
(a) holding down the Power ON/OFF button .... a long time ... until the unit shuts down and starts up again, or
(b) pushing a pin into the RESET hole)
after the TomTom has been fully charged ?
Aug 28, 2013 | Tomtom GO 730 Car GPS Receiver
The unit will not turn on after trying the pushing the power button. The green light on the reset button shows that it is on but on the display not lights are on. I tried to inplug and wait and plug the...
You need to bypass the on/off switch by jumping it, thereby taking the switch out of the circuit. If it works you have a bad switch. If it doesn't you have a power to the switch problem. Do you have a multimeter and a wiring diagram for this unit?
Aug 02, 2011 | LG Heating & Cooling
My one year old 8000 BTU GE window unit will not turn on. The electricity was going off and on so I unplugged the air conditioning unit off. Now it will not come back on. The green light on the plug is on...
Is the display panel lit up? If not look for a fuse mounted on the board.Take the fuse to radio shack and get another. Unplug the unit before attempting to service it.
Jul 09, 2011 | Heating & Cooling
The unit worked fine when i last used it in the fall. I plugged it back in today and all the buttons lit up for about 1.5 seconds and then all the buttons went dark again. So I pushed the "on"...
I have had a problem like this in the past you can try taking the electric access panel usually on the side of the equipment. then look inside you will see a wiring harness inside and it literally takes nothing to bump it loose. This happens when people move these units they are pretty fragile and can be tempermental. Make sure the unit is unplugged while you adjust the wiring harness. If that deosnt work your display board is probably bad. Hope that helps
May 10, 2011 | Haier ESA3125 Wall/Window Air Conditioner
My Compaq Presario SR1250nx will not turn on. The power chord is attached and power strip is turned on. I've also tested on a stand alone outlet to ensure it wasn't the power chord. A little green light...
Looks like your power supply's failed. The green light on the back of your power supply is just a neon light that just confirms that the power lead is OK, it does not relate to the status of the power supply! Try powering it up with another power supply, or replacing the power supply.
Oct 14, 2010 | HP Compaq Presario SR1250NX (PJ534AA) PC...
The went out in my condo and I have 3 samsung air
Unplug all the units, and wait for about a minute and plug it back. This is to reset all the units back to the
original condition. Hope this works.
Jan 05, 2010 | Heating & Cooling
Won't turn on or up
If there is a 'lock' button on the heater, push and hold till the green light goes out.
otherwise www.rinnai.co.nz - tradesmart, energysavers.
May 28, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Red then green blinking lights.
push power on at button (no need to hold button)and press proceed button for 2 secounds at the same time you turn on power and it should reset.
Dec 24, 2007 | NEC PlasmaSync 50MP1 50 in. Television
Doesn' t turn on
reset the device by pushing the reset button near the plug on the bottom of the unit , then it will come on i presume you upgraded by the internet you need to use a paper clip to reset the unit
Sep 25, 2007 | Tomtom GO 700 GPS Receiver
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Frigidaire FAM18ER2A Thru-Wall/Window Air Conditioner Logo
234 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
