My Maytag Performa washer, even though it is level, the tub always leans to the right causing a racket especially with jeans and / or sweats (heavy items) but even with light well balanced loads the tub always wants to go to the right.
    Genius:
  • 1,073 Answers
The ending up with the tub leaning to the right is caused by the tub stopping abruptly at the end of the spin cycle. it is normal
Posted on Apr 10, 2008
Maytag performa washer during spin cycle tub is making loud banging noise and continues even when clothes are evenly distributed
This sounds like the transmission is going. Better get another washing machine other than a Performa.
Jan 03, 2010 | Maytag Washing Machines
Maytag washer tub leans to the right
I have a Mayag Washer and dryer The washer someimes spins of balance. the dryer has no heat, this just started. would it be the element?
Oct 23, 2009 | Maytag Performa PAV2200
Maytag Performa washer stopped mid cycle
It will not be either , after emptying tub lean the unit back so you can see under it , remove the belt and turn each pulley/wheel with your hand , the pump is norm. on rear right corner and is usually the problem it will be hard to turn if bad , the pump is an easy fix, the pulley that is stuck is the component that is bad if not the pump. the large tub pulley should turn both ways with some effort , if not it could be the gear case causing this. Let me know if you have any questions.
Phil
Apr 11, 2009 | Washing Machines
Washer walks across floor no matter what problem.
FIRST OF ALL SCREW THE FRONT LEGS ALL THE WAY DOWN THEN TILT THE MACHINE UP FROM THE BACK MEANING THE BACK SIDE UP SET DOWN FIRMLY THIS WILL AUTOMATICLY SELF LEVEL THE BACK LEGS THEN UNSCREW THE FRONT LEGS TO MAKE LEVEL WITH YOUR FLOOR THIS SCHOULD FIX YOUR PROBLEM THANKS GLAD TO BE OF SERVICE
Feb 03, 2009 | Maytag Performa PAV2200
Maytag washer overfilling
Easy fix. Do this: Remove the rubber tube coming from the bottom of the tub up to the water level switch right there at the switch itself. Blow through it to remove the sediment in the bottom of the tub so that air pressure from tub to switch will be kosher. Put the hose back on the water level switch tight and pump out any water in the machine.
Retry
Dec 19, 2008 | Maytag Performa PAV2200
Agitator noise in maytag performa machine
The noise in your washer tub could be caused by some object lodged under the agetator. Lift off agetator and check. Or somthing could have gotten into the sump tub. this could be a major job as you would have to remove the complete inner tub assy. One other problem I can think of it could be worn tub bearings. If the washer is 10 or 15 years old I would replace it,
ljtomega
Dec 03, 2008 | Maytag Performa PAV2200
Maytag Performa water level
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Jul 13, 2008 | Maytag Performa PAV2200
Spin cycle
The washer needs to be leveled with a level first.If it is level than the clothes should float evenly in water.Not level everything floats to the un even side and they will bunch up.
May 23, 2008 | Maytag Performa PAV2200
My washer just keeps trying to fill
check the height of the drain hose. if you aren't seeing a leak on the floor the drain hose might be below the height of the tub. the water always seeks the lowest level and if the hose is too low the water wwill run right out
Jul 27, 2007 | Maytag Performa PAV2200
Washing Machines Logo
193 people viewed this question
Top Washing Machines Experts
