Question about Sears Vacuum Shredder Bagger Replacement Bag.806008
Cord on craftsman wood-chipper is locked, won't pull
I'[ve cleared all the blades of wood ... it was running perfectly, had to shut it off for a moment and the cord locked
3 Suggested Answers
  • 3 Answers
SOURCE: looking for manual for troy-Bilt super tomahawk wood chipper
I have the both the manual and parts catalog for Troy-Built 8hp Tomahawk, can send them to you for the cost of coping and postage if you haven't found them yet.
Ron Bowman, PGYBCK@AOL.COM
Posted on May 02, 2009
  • 640 Answers
SOURCE: Describe your Problem - yard
Remove the spark plug and try again. If still stuck, then you may have a seized engine. You can unseize it with the piston facing up and using penatrating oil in the cylinder and putting the plug in finger tight and let it sit for a day or two, then remove the plug and try to pull it, if free, change oil before running, if not free, look in plug hole and check to see that you have even coverage of penatrating oil on the piston, add more if needed. There are a few real good videos on youtube, search freeing a seized engine and look at the ones for small engines.
I hope this is helpful for you.
Posted on Aug 24, 2011
Why won't the pull cord budge?
My first idea is that the engine was shut off before the chipper or the shredder had not finished. First remove the spark plug. Next remove the covers on the chipper area and the shredder area. Now remove all material from both areas.Replace all covers, put the sparkplug back and try it.
Sep 28, 2015 | Craftsman LEAFWACKER 3-Way Chipper...
Blade on a Craftsman 20 in bushwacker electric hedge trimmer stuck on a vine and will not engage
with engine off ! use a pocket knife to whittle wood branch out of bar , do not yank it off the bush the blade will bend then will become stuck
Mar 10, 2013 | Craftsman 20 in. Hedge Trimmer
Pull cord hard to pull and won't reel back in
should never pull cord unless correct amount of oil is in it !, My advise take back to sears and buy a Toro ! Did you have the blade break lever pulled back ?
Oct 11, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
My mower will start but when I pull the handle back to mow it shuts off. What can be the problem?
Flip it over and make sure that the blade is clear. I've had pieces of wood jammed. The engine starts but I couldn't engage the blade.
Jul 01, 2011 | Garden
Need a leaf bag for a chipper/shredder/vac
That is actually a good price. MTD wants $225.00
Oct 04, 2009 | Craftsman 4 Cycle Blower/Vac
Pull-start rope won't pull
This has happened several times for me and is usually caused by a peice of word jamed in the input hopper and half cut by the blades. Always make sure there is no wood in the input chute before stopping motor. remove the collector bag and use a long pry bar to reverse the flywheel. if this moves backwards you may then be able to remove the peice of wood jammed in the blades thru the input chute. Long Skinny arms is required to reach down the chute. Use a Flashlight to see if this is your problem.
Jun 26, 2009 | Troy-Bilt Chipper Shredder
10 hp Troy Built chipper pull start frozen
If a branch was already being chipped when it ran out of gas...you must clear the hopper of any chunks of wood in it. Pull the plug wire and use a metal pry bar to dislodge any pieces of wood. when the flywheel runs free, put the plug wire back on and the choke on. Try it now!!!
Jun 14, 2009 | Troy-BiltĀ® Briggs and Stratton Chipper
My chipper is throwing long chunks of unchiped
Either your blades are dull or the gap between the intake tray by the blades is too far or is rounded off. Many chippers have a plate on the intake by the blades that can be flipped around when it rounds off. Also some have a edge on the other side of the blade so it can be reversed and give you a fresh edge. Be sure to unplug the sparkplugs and remove the key when going into your chipper to ensure no one can start it when your in it. There is usually a lock bar to keep the blades from moving.
Mar 31, 2009 | Heavy Machinery
Wood Chipper how to
Great input tina783. I have just one thing to add. Try to shred the branches within a reasonable amount of time. I found out that with my shredder, if I put older, dried up branches in, it tends to take a lot more time, as well as tosses chips back out at you. With newly cut branches, this wasn't nearly as much as an issue.
Aug 27, 2008 | AMANA TOOL 658060 PRESTIGE FINE DADO SET...
Sears Vacuum Shredder Bagger Replacement Bag.806008 Logo
210 people viewed this question
Top Sears Heavy Machinery Experts
Roland W VanLue
Roland W VanLue
Matt Olenzek
Matt Olenzek
Are you a Sears Heavy Machinery Expert? Answer questions, earn points and help others
