This video confirms the control is defective based on your findings
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "great help"
My friend bruce at FIXYOURBOARD.COM will repair your board and give a better warranty than a new part for around $130.
Don't know fer sure call Bruce.For any questions, contact us:
Email: [email protected]
Phone: (512) 355-1108
Hi - Typically error code F3 indicates a faulty sensor probe or wiring harness between sensor probe and EOC. Try resetting the range by unplugging it or flipping the circuit breaker off for two minutes (this usually will clear most false error codes). Turn on the range and if resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Hi - Typically error code F30 for Frigidaire range indicates an issue with the sensor probe or the wiring harness between sensor probe and EOC. If you have already changed the sensor, I suggest checking the wiring or contacting a professional to move forward accurately. You can try resetting the unit and see if the error code will clear. You can either unplug the unit or flip the household circuit breaker off. Wait approximately ten minutes and turn on the range. If issue continues, once again contact a professional to properly diagnose the unit.
Then you have a bad oven control most likely Let me ask you this: did you wire in a new probe or use the old plug? Lotta times themconectors get greasy and won't make a good connection. I have seen the old probes work simply with bypassing that corroded quick connect plug..
I tested the probe again at the control panel and got 1180 ohm at room temperature, so I guess it is the control panel.
Thanks for the help
Update. I was told that control is discontinued and there are no replacement.
Ok that is a good idea. My control board number is 318010701. Is board # 318010700 the same?
