Question about Whirlpool ACP102PR Portable Air Conditioner
Leaking terrible.. carpet is a lake... where is the empty pan ??
  • 8,197 Answers
You will find the empty pan on the link below page 10.
http://www.ajmadison.com/ajmadison/itemdocs/1188178.pdf
Good Luck
Posted on Jun 05, 2010
Model 610 - how do I locate the drip tray and how do I remove it? The power was lost after TC Marcia and products dripped in the fridge and freezer causing a terrible smell.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
Plastic holds odors. The smell may not becoming from your drain pan, but more likely the liner.
What to do:
1.) Remove the shelves, ice bucket and crisper drawers and scrub them with a baking soda base cleaner.
2.) Scrub the liner walls.
3 .) There are deodorizers especially made for refrigerators; One for the fresh food section and one especially for the freezer section. You can get these for any appliance store.
4.) Ok, lets check the drain pan.
a.) Unplug your unit or turn the main breaker off.
b.) Raise the two leveling screws in the front to allow you tp pull your unit out.
c.) Having enough room to get behind your unit, unscrew the bottom cover.
d.) Observe. You either have the terrible drain pan design, where the drain pan is fixed on the top of the compressor with hi-temp adhesive. Do not attempt to remove. Over time the adhesive dries out and the drain pan falls off.
The other type of drain pan is almost just as bad. You have to unbolt the compressor and other things to access. Do not attempt this.
What field technicians do when there is a drain pan leak, is repair the leak with duct tape and a high temperature silicone adhesive. In this case if there is an odor, sprinkle 1/2 cup of baking soda around the drain pan.
Feb 26, 2015 | Refrigerators
Why is there water on my furnace when the a/c is running?
Condensate normally drains into a pan that either empties into a floor drain by gravity or empties into a pump inlet for discharge outside. The drain pan may be clogged, preventing it from emptying or, more likely, the drain pan is leaking condensate.
Jun 28, 2014 | Heating & Cooling
I have a 2005 Altima and there is a leak in the front passenger side under the carpet. Terrible mold smell. We've pulled the carpet back and the jute is soaked. Any idea where the water could be coming...
1) Check the pollen filter, its probably in a poor state if its not been changed yet.
2) Check the bulk head drains.
3) Check the sun roof drain pipes (usually run from under the sun roof, down the door pillars to the wheel arches, often covered by an plastic inner wing) clear out all the mud and debris.
Apr 13, 2011 | 2005 Nissan Altima
Unit is leaking all over floor
Can you connect a pipe from the drain pan to a drain? This would get rid of the moisture within the room instead of just recycling it.
Jul 20, 2010 | Haier HPM09XC5 Portable Air Conditioner
Water poring out, carpet is now a lake, cant find where pan to empty is ...please help
On page 11 of link below will tell you how to empty water tank. that is if you have the Kenwood KW85
http://www.sylvane.com/images/productpages/DeLonghi/Air-Conditioners/kw85/KW85.pdf
Good Luck end please rate
Jun 05, 2010 | Kenwood KW85 Air Conditioner
I think my Whirlpool French door (freezer on bottom) is leaking underneath. I have checked the water lines on the outside and looked underneath and nothing. When I moved the fridge there was a film of...
check to make sure that the condensation pan is in its correct position,, somtimes when the unit is moved up steps it causes the pan to sit in there cocked or unlevel and will drain out excessively. or it may be a crack on the fill valve solinod where the water line connects to the fridge.. there will be a blue plasitc cover right where the water line connects to the frig and somtimes they crack and will only leak when the ice maker calls for water... pull out the frig and empty the ice tray and when you here it start to fill up the icemaker check around that solinoed be sure to use a bright flash light because sometimes the leak will be a little stream of water that is really hard to see sometimes you can only feel it with your fingers...I hope this helps......
Nov 11, 2009 | Whirlpool GX5FHDXT French Door...
Where is the condensation pan located on a GE artica?
Look under the unit and replace the condensatin pan back in place. This should stop the leaking onto your carpet.
Sep 04, 2009 | GE GSS25JFM Side by Side Refrigerator
Nor-Lake walk-in cooler water leak
The evaporator drains into pan with a coil from the discharge line. The design is intented to sub-cool the liquid refrigertant as well as evaporate the condensation from the coil. Unfortunately the engineer started as career a shipping clerk and never received any further training.  There isn't enough heat or running time to evaporate the condensation from the coil.
The solution is fairly simple
A plastic tube  drains water out of the evaporator in the pan. You can extend the tube and add a defrost pan handled by your refrigeration wholesaler. Wire it so it is on whenever there is power to the unit.  This should get rid of the excess water. These pans are also used on some self contained coolers and freezers. They come in either 120 volts or 220 volts. kasgirls@tds.net
Jul 12, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Changing transmition filter
The transmission filter is located inside the transmission pan. Should take you around an hour or so to drain and drop pan replace filter and replace pan. Thanks for using FixYa!
Mar 26, 2009 | 1994 Isuzu Trooper
Heating & Cooling Logo
166 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
