Question about Vizio L32 32 in. LCD HDTV
My remote to change channels is not working everything else is working on remote. just the up and down channel. The vol next to it works.
  • Vizio Master
  • 8,457 Answers
Take the remote aparts,clean the plastic film and PCB circuitries with some Q tips with some rubbing alchahol.This should solved the problems.But,take a look at the channels up and down buttons back of the rubbers film little black dots to make contact with the PCB circuitries is it worn out?Yes,sorry ur remote can't be fix.Sometime every things it clean and look good but,still have the same problems,the CPU chip it shorted this can't be fix either.Try website like Remotes.com to buy an exact or very close to the original remotes.
Posted on Jun 05, 2010
I have a toshiba tv 39al900a which was won in a raffle. When you turn it on it says please scan channels.t.
The first step is to make sure you have good batteries in the remote. The ones included tends to be cheap and you have no idea how old they are.
Here is the manual, page 12 explains how to use the remote and the next few pages cover the initial setup and scanning of channels.
http://www.mytoshiba.com.au/file/download/resource/file/23089/39al900a%20owner's%20manual.pdf
If the remote is still not working, get a universal remote to replace it. This link gets you the codes to program the universal to work with your TV. http://codesforuniversalremotes.com/universal-remote-control-codes-toshiba-tvs/
Feb 05, 2017 | Toshiba Televison & Video
Program directv remote to do everything to Proscan 43LA45H
It may not control all functions for tv ,only on,off , vol, not menu auto program... try www.directtv.com .
Sep 26, 2014 | Proscan 42LA45H 42 in. LCD TV
I just received a Coby TFTV992 9" portable TV. I'm trying to tune the TV channels without success.
1st click the "mode" button on the TV or remote then use the vol. up and down buttons to scroll around until you get to DTV mode then press "enter" on the remote you should get a message "please run channel auto scan" . click "Menu" on the remote the "Picture" screen will come up, keep clicking the vol. up button to scroll past "Audio" then "Setup" then to "Channel" then use the CH up or down buttons to scroll to "Air" click OK , then use the CH down button to scroll to "Scan all channels" then click the vol. up button. it then should start scanning, FYI you have to be fast!
Jan 07, 2013 | Coby Usa Coby Electronics TFTV992 9 Inch...
I have a remote control TV. It is an old unit.
Hold in vol.up and vol. down at the same time. OR Channel up and channel down at the same time for 5 seconds. If you still have the same problem.Go into the menu and goto cc or close caption or text and turn it off. One of them should do it.
Sep 25, 2009 | RCA Televison & Video
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
AV input selection without a remote
I had the same problem. I hooked up the DVD player and then got into the set up. I used the add/erase feature to go through all of the channels. At channel 91, I saw the logo for the dvd player. I added that channel and now the dvd player works.
Jan 24, 2009 | Televison & Video
Remote code
1. programed RCVR with code 0314
2. then assigned a key (such as the TV/VCR key) with the EFC number of 300
3. then reprogramed RCVR w/ code 0027
498 "surround mode"
568 "+10"
578 "band"
370 "stereo"
702 "6"
444 "4"
447 "2"
317 "8"
701 "0" (zero)
450 "7"
704 "5"
707 "3"
449 "1"
577 "9"
384 "tape 2"
252 "mute"
255 "vol down"
512 "power"
515 "vol up"
572 "channel down"
257 "channel up"
Try This an see if works
Oct 19, 2008 | Kenwood VR-209 Receiver
Change channel lineup
1.) Press the TiVo button on the remote (at the top)
2.) Scroll down to "Messages & Settings" and press 'Select' on remote
3.) Scroll down to "Settings" and press 'Select'
4.) Scroll down to "Channels" and press 'Select'
5.) Press 'Select' on "Channel List"
6.) Pressing the "ENTER" button on remote will let you change Channel Line-Up
Aug 28, 2008 | Tivo Series2 TCD649080 Video Recorder
RM-AV2100
Either the channel up and down buttons have both broken (unlikely) or everything else is working except the remote is not telling the device you are controlling to change the channel up or down.
Since all the other buttons are working well, that also requires that the receiving end of the pair to be working well, thus ruling out problems on that end.
Solution: Reprogram your remote to support the appropriate channel up/down codes for your TV/Tuner in question.
Dec 14, 2007 | Sony RM-AV2100 LCD Touchscreen Remote...
I don't know the model of my remote but
What source/cable/Sat/etc are you using? Are there stations on those numbers? If so, do you have a VCR powered up that is connected to all this. That could be where you're losing your signal....accordianman
Oct 17, 2007 | RCA RCR860 Remote Control
Vizio L32 32 in. LCD HDTV Logo
101 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
