Question about Kenmore Refrigerators
What is the size of my Kenmore coldspot refrigerator side by side model 106.56376400 and its value (good shape bought new 4-04
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
  • 1073 Answers
SOURCE: My model number 106 59592993
your problem is in the compressor area check the relay on the compressor
Posted on May 07, 2008
SOURCE: Kenmore Coldspot Side by Side Model 51559101
I have a Kennmore side by side model # 522521 it all of a sudden the freezer part stopped freezing, the motor is still running. The Refrigerator part stopped cooling just after that.
Posted on Oct 19, 2008
rogrrabbit
  • 986 Answers
SOURCE: Oue Kenmore Coldspot ice-maker quit working. Any
Wake up one morning and Boom no ice left in the bin. What happened and What can I do to fix it without calling someone? Some ice makers will get a piece of ice in the wrong place and jam the extraction. Get a hair dryer and heat up the ice maker to release the fouled ice cube and that baby will start going. No water in ice mold?Do this easy test: pour some water in the ice maker mold and wait. If it kicks out a batch, but it has no water in it, most likely the water valve is bad. water%20valve%20for%20water%20and%20ice%20through%20the%20door.jpg Watervalve for SxS box Since it is the cheapest part and you can do it yourself replace it. If it turns out you need a new ice maker then you have a new water valve already to go with it. What if the ice maker has ice in it but won't harvest any? One cheap and easy item for the do it yourselfer to replace is the ice mold thermostat. Check for voltage between T and H if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts. ice%20mold%20thermostat%28modular%29.jpg Ice mold thermostat Located in the plastic housing and seated against the ice mold is that thermostat. This looks intimidating but is easily fixed by anybody who could change a spark plug. There is no wiring. One more thing to look for: You can put a jumper between L and V and this will activate the watervalve. Have rags ready! If you are a cheapskate and want to be frugal and not buy a new ice maker or a new head(brain) head1.jpg modular crescent ice maker you may want to remove the main gear and clean the copper plate behind it. That plate gets dirty and won't allow for a good contact with the water valve connection and does not power up the valve...Shhh! They will all be doing it! Modular crescent Icemaker test points: With NO power to the icemaker, and ice ejection fingers in the freeze position: Your ohm meter should read 8800 ohms between L and M, and 72 ohms between L and H. With power ON to the ice maker: If meter reads 0 volts between L and N you have no power to the ice maker. If the meter reads 120 volts then you have power to the ice maker. If you have 0 volts between L and H heater is off if you have 120 between L and H the heater should be ON. If you have 0 power between L and M the motor is off. If you have 120 between L and M then the motor should be ON. If you have 0 volts between T and H the thermostat is closed If the meter reads 120 between T and H then the thermostat is OPEN. If the voltage is 0 between N and V the water valve is closed. If the meter reads 120 water should be filling the mold.
Posted on Nov 11, 2009
SOURCE: cubic feet size of Kenmore refrigerator
Try this site: http://www.kouba-cavallo.com/refmods.htm
Posted on Nov 12, 2009
Where do I find a manual for the kenmore coldspot # 59099990 refridgerator
Model number is not valid check plate inside refrigerator. Usually Sears Kenmore start with 3 digit model number like 590.xxxxxxxx, and usually have characters that tell u what characteristics the model has and what color scheme.
May 10, 2014 | Kenmore Side by Side Refrigerator
My Kenmore Coldspot Refrigerator, Model # 59028991 will stop cooling for no reason. When I turn it off and then turn it back on it starts cooling again. What is the most likely problem and can I fix it.
Hi, Sounds like you need a new thermal switch. Go to your Kenmore dealer and order a new one.
If you have mechanic ability try to install it yourself or have someone help you with it.
Good luck.
Jun 09, 2011 | Kenmore Side by Side Refrigerator
Kenmore Coldspot - both the refrigerator and freeze suddenly stopped blowing cold.
If the fridge is running and you can hear it cycling(click, ~5 sec, click), then pull the fridge away from wall, take cardboard access panel off, 1/4" hex head, attatched to the compressor(black dome shaped bout the size of a volleyball) is a relay, take it off, if it sounds like a baby rattler when you shake it, it's bad. Check this first. If yours doesn't have this, then it has a timer. Timer might be bad. Not telling the heater when to turn off. Which is causing the fridge to not continue cooling, obviously.
Sep 30, 2010 | Kenmore 53652 / 53654 / 53659 Side by Side...
Kenmore coldspot side by side refrigerator - freezer fine. other
Good to see you put your model number down correctly. Do the lights come on inside when you open door? I noticed your refrigerator has a control board inside the fresh food section behind the control panel I want you to unplug the refrigerator and examine that board for burn marks or loose solder connections on both Sides. Then let me know what you find. Thanks, Sea breeze My email is appliancepsrtsse@yahoo.com Web Site http://servicepartstec.blogspot.com/ Part Number for Control board is 8201528
Jun 10, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
What size is this fridge?
there is a sticker some where inside that will tell you cubic feet
Dec 12, 2008 | Kenmore 53542 / 53544 Side by Side...
Kenmore coldspot not making ice, and not cooling in the bottom
Your refrigerator is frosted up. Remove the inside panel of your freezer. Defrost the ice out of the coils and check the heater and bi-metal. If both are good then your defrost timer is bad. If one is bad replace and you have it fixed. Good luck.
Michael Anderson
(865)945-3808
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Fridge side not cooling
the coils are at the bottom but that dose not sound like the problem u need to check the de frost
Nov 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
212 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
