Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Gasoline leaking into air filter on Briggs & Stratton engine
    Brigadier General:
  • 4,088 Answers
The float/needle-valve/seat need to be looked at in the carburetor base. The float is not shutting off fuel flow when bowl is at design fuel level. Look for dirt/varnish or anything that interferes with float free movement or preventing the needle valve to close with the seat--usually, just cleaning these parts with spray carburetor cleaner and wiping with a clean cloth will restore operation. Try not to bend anything on the float assembly. Hope this helps!
Posted on Jun 07, 2010
Where is oil filter on 13.5 briggs
Briggs & Stratton Riding Lawn Mower Engine Oil Filter #696854 ...
? 2:05
https://www.youtube.com/watch?v=QjYmbfGU0qg
Aug 22, 2014 - Uploaded by RepairClinic.com
This video provides step-by-step repair instructions for replacing the oil filter on a Briggs and Stratton small ...
Oil Change- Briggs & Stratton 12.5hp Mower - YouTube
? 5:05
https://www.youtube.com/watch?v=udjoD-mW5ig Aug 15, 2012 - Uploaded by Alex's Bikes and Motors
Oil Change- Briggs & Stratton 12.5hp Mower. Alex's Bikes and ... This is going to sound weird, but I can't ...
Oil Filter 492932S - Briggs & Stratton Parts
https://shop.briggsandstratton.com/us/en/parts-and.../oil-and-oil.../oil-filter-492932s Briggs & Stratton oil filters are engineered to keep your Intek, Vanguard OHV and twin cylinder engine running smooth. Save on costly repairs -- order genuine parts today!
oil filter on 13 5 briggs Google Search
Mar 12, 2018 | Briggs Garden
Cub cadet 30 inch 1450 briggs and stratton
About 625 results (0.89 seconds) Search Results
    Why wont my engine start - Briggs & Stratton
    www.briggsandstratton.com/.../why-wont-my-engine-st...
    Briggs & StrattonThe most common reason an engine will not start is due to an interruption in fuel ...(such as Briggs & Stratton carburetor cleaner to clean carburetor parts and body. ...gasoline be purchased in small quantities, not more than a 30 day supply. ... that canflood the engine, or cut the air supply enough that engine will not run.Missing: inch ‎major
    Information about the Carter, Kohler and Walbro Carburetors
    gardentractorpullingtips.com/carbfuel.htm
    Information about the Kohler Carburetor, Various Fuels and Fuel Systems. ... (Updated 5/23/15); Repairing Various Older Briggs & Stratton Carburetors. ... If used on a smaller engine, due to the larger venturi, the engine will not receive the ... which converts to 1.181 inches (30 ÷ 25.4 = 1.181"), but actually measures 1.200".
    Notes on the Troubleshooting and Repair of small Gasoline ...
    www.repairfaq.org/sam/lmfaq.htm
    May 19, 2015 - Timing; Lawn mower will not start after the blade hit an obstruction; Flywheel ... on Briggs and Stratton repair; Experience with Briggs & Stratton carburetor .... NEVER attempt to run a gasoline engine indoors. ..... For 2 stroke engines, special oil (not the usual 10W-30/40 type motor oil, nor WD40 or 3-In-One!) ...
    Briggs & Stratton - YouTube
Jan 21, 2016 | Garden
Briggs and stratton quantam 6.5 hp fires but will not run
Check for a clogged air filter.Try starting it without the air filter installed. Check for loose wires to the spark plug and ground. I am assuming there is gas in the tank, but does it get to the carb? Check the gas line, is it blocked? Is the carb leaking?
Oct 08, 2014 | Earthquake Rear Tine Rototiller SRT with...
Where do you spray carburetor cleaner in 675 series Briggs & stratton engine
Remove the air cleaner cover and the air filter then spray into the filter box.
Jul 14, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
6.5 briggs and stratton leaking motor oil through the filter area
How does it run? Is it back firing through the air filter box area? And although your stating it is oil is it actually oil or gasoline that is black due to getting dirty? Don't shoot me! I'm going on what information I'm reading what you submitted. If oil is it enough to show up quickly on the dipstick/engine oil level ? Get back to us and we can go further.
Nov 23, 2013 | Briggs & Stratton 491056 492932 Briggs ...
Briggs and Stratton intek 900 Series 205cc It will starts but it wont stay running.
The usual cause for the problem you describe is related to fuel/
carburetion. Today's formulation of gasolines have a shelf life of only 4-6 months before they start gumming carburetor. Other forms of fuel contamination (dirt, water, etc) may also be the culprit. First step is to remove and thoroughly clean both the tank and carburetor. Reinstall. Install a small engine filter in the gas line when you reassemble. Use FRESH gasoline after you are ready to start your engine.
Oct 14, 2013 | Briggs AND Stratton Intek Briggs &...
My 17.5 Briggs & Stratton engine runs fine at idle
replace air filter, check throttle linkage position, take to a pro shop and have governer adjustment checked
Sep 04, 2011 | Briggs & Stratton Garden
White smoke and oil spewing out of troy built briggs and stratton 650 series 190cc mower
Check your oil level. If it is way over full, smell it to see if it smells like gasoline. If it does, you have a carburetor leaking gas into the engine crankcase. If you recently had the mower over on its side for blade changing or inspection, you have gotten oil up on top of the piston and it should burn off in a few minutes of running. Check your air filter to see if it is soaked with oil, replace it if it is.
Sep 19, 2009 | Briggs & Stratton Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
492 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
