Question about Garden
I have a 600 watt Hampton Bay outdoor low voltage transformer that was left in a house that I just bought. It has not instructions, and I am wondering how to hook it up
  • 101ripper Jun 06, 2010
    This worked fine - thanks!
  • 1,511 Answers
Hello and Welcome to FixYa!
Here is the link from where you can have access to all the information regarding hook up, installation, precautions, Trouble shooting e.t.c.
Click here
All you need to read the instructions and act accordingly. Also do save the electronic copy of that manual for future assistance.
Best of Luck,
Please do RATE the solution, If this helps you out,
Concerned.
Posted on Jun 05, 2010
  • 101ripper Jun 05, 2010
    Thanks,this may be the solution I need, but the print is so small I can't read it. I tried enlarging it, but it then is too blurry. Is there a way to make each page a separate 8x11 piece of paper so it is legible?
  • Waqar Hassan
    Waqar Hassan Jun 06, 2010
    You need to click the button shown in the image.... You can also download a larger image, once you had clicked the button shown in the image.
    Hope this will help you out.....
    do Rate the solution, If found helpful.
How do you program a da-150-12w-1?
150 Watt Transformer TDC Power DA-150-12W-1 - eBay
www.ebay.com > ... > Outdoor Lighting > Walkway & Path Lights
eBay150 Watt Transformer TDC Power DA-150-12W-1 in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting, Walkway & Path Lights ' eBay.
New Free SHIP TDC Power Da 150 12W 1 Low ... - eBay
www.ebay.com > ... > Outdoor Lighting > Other Outdoor Lighting
eBayNew, Free Ship, TDC Power DA-150-12W-1 Low Voltage Transformer, 12v 150watt Max in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting ...
[PDF]SECTION H - Etlin
www.etlin.com/pdfs/Outdoor_Transformers.pdf
1-800-661-9610 (Canada) 1-888-762-5384 (USA). OUTDOOR LOW ... DA-XX-12WSeries - 60 to 150VA Small Case Low Voltage Outdoor Transformers.
Da-150-12w-1 Manual ' downloadthingsfast.com
Dec 09, 2015 | Malibu Hardware & Accessories
Plugged in but no juice getting through. Unit appears dead.
Most line voltage transformers have an internal fuse that isn't replaceable... You can measure the line input resistance with a meter to see if that's the problem.
Oct 25, 2015 | Hampton Bay 12V Low Voltage 300 Watt...
How to set the mechanical timer for Intermatic 600 Watt Low Voltage Transformer?
You can go to intermatic.com once you are on there page do a search for your model number, and from there you can download your instructions. Sorry that I could not given you more detailed instructions but with no model number this was as close as I could get you. Good luck!
Oct 03, 2010 | Intermatic 600 Watt Low Voltage...
The timer does not keep accurate time. How to fix?
Hi being these spend most of their life outdoors these tend to accumulate dust and debris inside the mechanism.
Also as moisture corrodes the internal parts they start to fail after a short while.
Couple of solutions use an external timer (pull the set pins out of the onboard timer) or replace the unit.
I recommend making sure that the timer is located somewhere where it is protected such as on or under a porch or deck, where its not getting wet all teh time.
also might be time to upgrade to a 300 or 600 watt unit?
Home depot sells their Hampton bay brand transformers with a photocell for between $50 to $100
Jan 08, 2010 | Intermatic & Malibu& 300 Watt Power/Pack...
Hampton bay ceiling fan
You can probably find outdoor blades at Home Depot, Lowes, etc.
There are ways to reduce the warping of indoor blades, but it's too much for most people. I'd suggest replacing them.
You could also surf the net for Hampton Bay stuff -- might be able to find them there, too.
May 28, 2009 | Hampton Bay 24002 Ceiling Fan
I have a Hampton Bay 300W transformer. I've attached a 12V bulb to it in the low voltage ports. the LED is covered and the unit is in the on position. About every ten seconds the units flashes the light,...
the Hampton Bay 300W transformer requires that at least a 20 watt load for it to function. If you only have one bulb, say a 10 or 15 watt to test it, it wont work - sounds crazy, I know.
If you have an installation brochure it's under "Important Safety Feature". The first sentence reads "In order for this Transformer to operate, a minimum load of 20 watts MUST be installed before plugging the Transformer into the electrical outlet.
Hope that's it - by the way, these transformers can emit a high pitch when running - not sure why, but it's a common complaint.
Jan 13, 2009 | Computers & Internet
Garden Logo
82 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
