Question about Dishwashers
Problem with Kenmore dishwasher model# 15762000
The dishwasher goes through the cycle and seems to be washing, heating, and draining. However as soon as the water to the dishwasher is turned on (from under the sink), water starts flowing into the dishwasher from an inflow "hole" (can't see a valve, just an opening in the side of the dishwasher) in the lower left corner of the left side of the inside of the dishwasher. The water keeps flowing in even if the dishwasher isn't running, resulting in eventual flooding until the water supply is turned off.
  • Anonymous Mar 16, 2014
    I tested water valve and it tested bad--I replaced it--had to modify new one a bit--thought it was just a swap out but I had to turn it a bit and move one screw hole in mounting bracket--all done--started up--died after one minute--
    Genius:
  • 1,073 Answers
Replace the water inlet valve, something is inside the valve holding it open, dirt small grain of sand, ect.
Posted on Apr 10, 2008
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Kenmore 665 Dishwasher
Sound like you have a bad control console, which will need to be replaced.
Apr 08, 2012 | Kenmore 13742 / 13744 / 13749 Built-in...
How to reset control panel on model 587.1517 kenmore dish washer
From what I have read elsewhere, the interrupt *may* have something to do with a thermostat circuit cutting out if the entry hot water is too high ( more than 145F) - it seems like a buggy safety feature i.e. the circuit board thinks that the water heater is overheating. The makers have apparently made changes to the control board to fix this bug but it costs serious $$$ to get a repairman in and buy the new board.
I prefer to use the reset code, and keep my water temp lower when using it.
Feb 20, 2011 | Kenmore Dishwashers
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
I have a kenmore dishwasher. While it was in the
hi...
If the cycle doesn't complete, check these....
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
if still it doesn't fix your problem then see whether any error codes are generated....
F1 Water heating fault, selected temperature not reached within 60 minutes · Incoming water temperature too cool
· Heating element burned out
· Thermostat defective F2 High water level · Plugged/Bad water pump
· Defective water inlet valve F3 Thermistor fault · Open thermistor
· Bad wiring to thermistor F4 Fault with water fill (only on machines with level-controlled fill)
Note: Lights blinking, pump running and controls dead indicates an over fill fault 1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray
*Faults may vary by model. Use this as a general guide.
i think these details would definitely help you.....thank you...
Jul 19, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher not spraying/pumping water in wash cycle
If your dishwasher is filling, draining and the heating element is working then the wash pump motor has probably failed.
You have not provided the manufacturer and model number, so I have no way of knowing if your dishwasher has a separate drain and wash pump motor.
May 03, 2009 | Dishwashers
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Jan 26, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Open Questions:
Brand new dishwasher will not finish washing, it just beeps and the lights flash red - CANDY CDP 1L39W/K I have a brand new Candy dishwasher model CDP 1L39W/K that won't finish it's wash cycle. When I do P5 for a fast 5minute cycle I hear the dishwasher fill up, it begins to wash, and then after it drains the water, then the dishwasher begins beeping repeatedly and flashing the red light under the P5 setting. When I check the detergent slot it hasn't been used yet. When I select a long wash like P3 the same thing happens after it drains the water, so I think the error occurs after the first rinse cycle? When I push down reset all the lights flash and then blink sequentially just like the dishwasher is waiting for a new cycle input, but the water pump to drain the water never turns off. If I push the power button the unit turns off but the water pump keeps running. Only when I disconnect the power cord from the wall will the pump turn off. If I reconnect the power cord the pump turns back on sometimes. I read online that maybe the flood switch was hit and to tilt the unit and drain water, I took off the kick panel and didn't see any water, and tilted the unit back and forth as instructed. The first time I tried this I think it may have helped the water pump turn off after I reconnected the power cord. But when I ran a cycle again nothing changed. I also waited a few days afterwards because I was busy at work enough time for any water to dry up but this didn't help. I'm in Vietnam and the customer support is Vietnamese so I thought I would try this before I have to see about the warranty and shipping the unit far north for repair. Any help is really appreciated, I can post a video of the beeping, blinking lights, and water pump running after I unplug the unit it'd help. I so badly want this dishwasher to just work, it was a big purchase here and a lot people don't understand why I'd buy it so now that it's not working it's really embarrassing! Thanks again!
Jan 22, 2018 | Candy Dishwashers
Dishwashers Logo
476 people viewed this question
Top Dishwashers Experts
