Question about Ovens
HOW TO FIT THE INTERNAL DOOR ON AN AMICA OVEN
I CANNOT WORK OUT HOW TO FIT THE INTERNAL DOOR,THE GLASS KEEPS SLIPPING
  • 1462 Answers
SOURCE: Oven door
open door fully. there is a hinge lock - usually a little arm on the hinge which comes up. engage hinge lock, partially close door and lift off
Posted on Jul 04, 2007
vest6
  • 196 Answers
SOURCE: Remove Outer Glass Of Oven Door
Depending on the unit there should be several screws on the top and bottom of the door. Thesse screws hold the door sections together. Once the screws are removed the inner glass section should slide out (you may have to remove the bracket screws.) From here there should be some small clips that hold the front glass in place.
Posted on Jan 26, 2008
shaggyrat
  • 1224 Answers
SOURCE: Cannot re-fit middle glasss into main oven door
this is a new one too me but ill give a shot
ive never seen an over where the supports were all intack
they should be screwed in at least to of them by what i call the hidden screw or plug either the 2 bottom come out or the 2 top ones come out to where the glass slides into position and just put the supports back into place
i was reading reviews on this particular item and clearly by what there describing this is not a very good functioning machine all out of tune from the older style
Posted on May 09, 2008
SOURCE: siemens microwave oven HB86k.70b
I have the same problem, have you found out the cause?
Regards
Posted on Sep 04, 2008
bozcro
  • 867 Answers
SOURCE: the inside glass needs cleaning on siemens
look for screws around the door, usally phillips, remove them then gently pry the door apart. popping the door off will make work easier.
Posted on Jun 27, 2009
I have a Kuppersbusch microspeed plus (EMWK9600.0M) was in the house when we moved In. whilst using it in microwave mode I heard a bang and the internal glass door has shattered.
The glass will break if the food being heated is not covered and fat/grease heats up to flash point on the glass or there is a cut in the glass or the food banged against the glass or the glass was stressed by an incorrectly fitting door.
A new door is possibly available or glass.
May 17, 2017 | Kuppersbusch Ovens
How to fit the internal glass oven door which I have broken and bought a replacement
Here is a general website on how to change a door glass. Just for information, this would be the best I could do with out any information on the model you currently have. Good Luck
Inner Oven Door Glass Panel
Apr 20, 2016 | Ovens
Please tell me if Electrolux EKG5547XN Cooker Main Oven Glass Door would fit my EOB6632U
Glass oven door is not compatible.
First of all, the oven door EKG5547XN has only two glasses, inner and outer, while the oven door EOB6632U has three glasses; inner, middle and outer.
EKG5547XN
Inner glass oven door, part number: 349 00 30-01/6, silkscreened; dimension: 456 x 323 mm, tempered glass.
Front glass oven door, part number: 349 10 45-14 / 6, stainless.
EOB6632U
Inner glass oven door, part number: 899661 92 68-78 / 3,
silkscreened; dimension: 479 x 391 mm, tempered glass.
Middle glass oven door: dimension: 447 x 380 mm.
Front glass oven door: dimension: 589,5 x 466 mm.
Dado
Mar 28, 2015 | Electrolux Ovens
Amica oven door gets so hot that my child has burnt hes hands and needed medical attention
Amica is a European brand, I recommend you contact the company headquarters or a competant local repair shop. Any oven left at a very high temperature for a long period of time gets pretty hot, though, and an eleven month old baby has pretty tender skin.
Jul 19, 2014 | Ovens
How do I take the glass out my oven door model AP578X-8
Hi, I have pasted the instructions for your Smeg oven you below:
9.4 Removing the internal glass panels
The glass in the door should always be kept thoroughly clean. To facilitate
cleaning, it is possible to remove the door (see 9.2 Removing the door) and
place it on a canvas, or open it and lock the hinges in order to extract the glass
panels.
The glass panels of the door can be completely removed by following the
instructions provided below.
Warning: before removing the glass panels, make sure that at least one of the
door's hinges has been locked in the open position as described in "9.2
Removing the door". This operation may have to be repeated during the glass
removal process if the door is accidentally freed.
Removing the internal glass panel:
• Remove the internal glass panel by
pulling it upwards, following the
movement indicated by the arrows. Doing
this detaches the 4 pins attached to the
glass from their slots in the oven door.
Removing the intermediate glass panels
(on some models only):
• Some multifunction models have an
intermediate glass panel. Remove the
intermediate panel by lifting it upwards.
Cleaning:
• It is now possible to clean the external
glass panel and the panels removed
previously. Use absorbent kitchen roll. In
the case of stubborn dirt, wash with a
damp sponge and neutral detergent.
Replacing the glass panels:
• Replace the panels in the reverse of the
order in which they were removed.
• Reposition the internal glass panel, taking
care to centre and insert the 4 pins
attached to the glass into their slots in the
oven door by applying slight pressure.
You can go to the website for further information: http://www.u-manual.com/download-manual-now-for-free-10/210209/oven-smeg-ap578x-8.html#.UumokD2Sxvg
Jan 29, 2014 | Smeg Ovens
Oven door on a Amica upright oven not closing completely. Where can I obtain door hinges for a Amica Oven..it is still under warranty, less than 24 months old. I have tried a few spare part places...no one...
they are Australian company, What country are you in? The wesite for them is www.cimbre.com.au. I would need to know where you are in order to help you. Also need the model number. Usually manufactures warranty expires after 1 year
May 22, 2011 | Ovens
Broke the glass front to my Dacor CPO230B wall oven. the manufacturer no longer makes the part. What would the solution be to this problem.
If you dig deep enough on Google, you'll find someone who has the part. As with all manufacturers, none of them make the entire product. Bic makes pens for "off brands", Staples products come from a myriad of manufacturers, Kirkland, the house brand for Costco, all come from various sources. Hopefully, the part that's ordered will fit. We've also located the entire door. So just in case the front glass is not available, the door is, and that's an expensive alternative. I've also considered going to a glass company to have a piece of tempered black glass cut to size. My entire dilemma stemmed from changing the interior bulb in the bottom oven, when putting the door back on, it slipped in my hands and the rest is now history.
Dec 01, 2009 | Ovens
The inside glass needs cleaning on siemens
Jun 27, 2009 | Ovens
Loose oven door handle
I had the same problem. We took the door off completely & turned it upside down. There are screws on the bottom of the door, take them out, take off bottom trim piece that holds the outside glass panel in place, remove glass panel and you can access the door handle screws and clean the inside of the glass while you are at it.
Jan 05, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Microwave door shattered
This is not a job you should do. Microwaves are dangerous things and can cause injury. An improperly fitted door will leak. A new door, installed and checked out by a technician is needed here The economics are beyond my area.
Jun 16, 2008 | Ovens
Ovens Logo
178 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
