Question about Lexmark X7170 All-In-One InkJet Printer
I cant find the ink cartrage on this printer to replace help
  • 3,083 Answers
I don't have your model Lexmark, but on my X4530 you have to lift the top scanning bed up, then the cartridges will settle to the middle for changing. Make sure you have the power on when you lift it, and you should see the cartridges in the middle of the printer. Good luck, hope this helps.
Posted on Jun 05, 2010
  • 428 Answers
I have the product's installation guide here.
You have to open the Scanner Unit (Pull up)
Thanks for contacting Fixya!
  • 5 Answers
SOURCE: my cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Posted on Feb 23, 2009
paand
  • 147 Answers
SOURCE: it shows incompatible ink cartrage
i think you have scratched the head of the cartridge while placing it. try another new cartridge or refill the older one.And also check that you are buying the same cartridge
Posted on Jun 23, 2009
male_28_cam
  • 1555 Answers
SOURCE: Empty Ink Cartrage message when cartrage still has a lot of ink.
I'm going to provide you a solution worth many dollars now you can use your left over half filled cartidges and in future also use the cartridges to the extreme.
1. Go to menu and select manual override for toner cartridges and then only replace toner when the print quality starts to suffer. This can save you thousands of dollars over the life of this fine printer.
2. download and read this
http://74.125.153.132/search?q=cache:9mwf_bY_x-AJ:www.refill4.com/refillinstructons/pdf_downloads/Full-RefillInstructions.pdf+brother+mfc+5840+override+cartridge+empty&cd=6&hl=en&ct=clnk&gl=in
Posted on Jul 26, 2009
  • 137 Answers
SOURCE: HP Officejet T45 keeps telling me I have the wrong Ink Cartridge
Clean the cartridge contacts and the printer contacts as shown here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Posted on Sep 19, 2009
SOURCE: I have a Hp photoshop 3210 printer ink cartrage error empty or
I installed new cartriges, but my printer keeps giving me an error msg, Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: Oxc18a0206. What do I do now?
Posted on Mar 04, 2010
My printer is not printing blue ink. we replaced the ink cartrages , all other colors print except blue. what can we do?
they have a excellent customer service dept call if they cant tell you what to do they often will replace it sometimes for free its worth a try.
Feb 23, 2011 | Kodak Office Equipment & Supplies
I put a refurbished cyane ink cartrage in and I get error. It says it cannot read the ink cartrage take out and put back in. I do that and it still will no work.
your printer cant "read" cartridge E-label
you have to replace it or replace cyane cartridge whit new one
Good Luck!
Jun 27, 2010 | HP LaserJet 4700 Printer
How to replace ink cartrages in pixma 310 canon
Follow the link for manual on how to replace Fine Cartridges.
http://www.cybernates.com/manual.pdf
Refer page 69,70, 71
Hope this helps..
May 21, 2010 | Canon PIXMA MX310 All-In-One Printer
I installed new epson ink cartrage, but printer has red x and tells me to change ink again.? Can i just change only the bkack ink?
Yes you should be able to just change the black ink cartrage, A lot of printer wont allow other third party cartrages, is it a genuine epson ink cartridge? if so try cleaning the contacts on the cartrage.
Apr 25, 2010 | Epson NX415 All-In-One Printer
How to refil Cannon LBP2900 cartridge
you do not have to take the whole printer to the shop to fill the ink cartrage if you have the manuel to the printer it should tell you how to remove the ink cartrage and replace it with a new one and also they may have a refill kit at one of your local computer stores or where they sell ink and they should be able to tell you how to get the ink cartrage out to replace it
Sep 02, 2009 | Canon LASER SHOT LBP-2900 Printer
Same problem help
first try to remove the ink cartrages and close the lid after doing it.
after the system recognizes that there are no inks replug the ink cartrages and turn of the printer and PC/NB and after about 10 secs. turn all of the devices on and try to check it again.
Aug 21, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Tried to install a refilled ink cartridge. Then
The printer working does not depend on its cartrage... Cartrage is just like ink in ur pen... If the nib of ur pen breaks then u cant blame on ink... Check whether the gare of ur printer moves if its nt then there is some problem in gare shifting ic or the rotator machine check it by giving it to some computer service shop
Aug 03, 2009 | Office Equipment & Supplies
Regards,
Jan 17, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
Ink will not dry on photos. comes out real wet.
in the printer little sceen go to the settings and and select Clean Print Head
Dec 27, 2008 | HP Photosmart C5280 Printer
Lexmark X7170 All-In-One InkJet Printer Logo
101 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
