Question about Sharp Office Equipment & Supplies
Please i have h2 error problem in my sharp ar 5516
Please when I switched on it displays the error code H2
there is no noise the belt is not running and I do not know what to do.
This problem
Hot the hiter
chenge it
Posted on Jan 12, 2011
My Sharp AR-M256 is displaying Code H2-00, how can i remove this?
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
Jun 07, 2016 | Sharp Office Equipment & Supplies
MAIN CODE H2 SUB CODE OO CONTENT THERMISTOR
H2
Reset the error. (Enter simulation mode by pressing # * C *) display will go off. Press 1 4 Start. The machine will restart automatically. If the error continues, check the thermistor connection and the lamp connection as well. Replace if required. Replacing the PCB is the final step.
Nov 30, 2012 | Sharp AR-M205 Copier
H2 problem sharp AR 5516
sharp ar5516 showing code f2 or h2
Jan 14, 2010 | Sharp AR-5320 Black and White Copier
H2 Error Message on AR M205 Sharp Copier
hi..there is a problem in the thermistor,thats why you
get the error code as H2.
check this out..
thank u..
kindly rate my response..
Jun 23, 2009 | Sharp AR-M205 Copier
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
SHARP AR163 Displaying H2 error code
Dec 11, 2008 | Sharp AR-163 All-In-One Laser Printer
Sharp AR-275 Getting H2-00 Erron on power on
In AR 275 Sharp copier H2 00 is very common problem, U have to only reset the above fuser error code as fallows
press # then intrrupt then c them intrrupt then display will show simulation mode then enter 14 then press ok key
If this is not enough then press press thermostat on fuser unit by removing the unit from machine this requires tech knowledge
OR you can try by replacing thermistor of fusing unit
If by above procedure the prob is not solved then and then you replace the fusing lamp
Even though u can check the lamp by removing back cover and turn on the machine u can observe the light of fusing lamp
pl ask for any difficulty.
Sep 18, 2008 | Sharp AR-5320 Black and White Copier
H2 error
An H2 is an indicator that the temperature sensing device is reading open, preventing the machine to warm up. There is only one way to correct this and that is to replace the thermistor, and that takes a technician. Not a hard job but a novice could get into trouble and make matters worse. Aloha, Bill Monroe
Sep 06, 2007 | Sharp AR-5316 Advanced Digital Imager...
423 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
