Question about Bosch 18 in. SRS56L08 Logixx Slim-Line Built-in Dishwasher
Not cleaning properly, most dirt comes off, but leaves starchy like substance
  • Bosch Master
  • 43,501 Answers
How to clean very sticky exterior?
First of all, have you any idea what substance is causing the stickyness ? A fairly safe start would be to lightly moisten a lint-free cloth, then wring it out until it is almost dry, and try gently rubbing an area of the camera, possibly the base plate.
If there is discoloration on the cloth, the chances are the contamination is water-soluble, so repeat the process until you are satisfied with the results.
WARNING! Do NOT let liquid enter the camera - the cloth must be almost dry.
If it is not water soluble, then you probably need to take it to a repair facility and let the technician clean it, as many solvents are harmful to the paint and plastics used in camera bodies.
Aug 08, 2016 | Nikon COOLPIX Cameras
Tip
HOw to Clean your keyobard effectively
Keyboard cleaningIf you're trying to clean a laptop keyboard see document CH000780 for additional help and information. All of the below information applies to standard desktop computer keyboards.
Why? Dirt, dust and hair can build up causing the keyboard to not function properly.
Procedure: Many people clean the keyboard by turning it upside down and shaking. A more effective method is to use compressed air. Compressed air is pressurized air contained in a can with a very long nozzle. Simply aim the air between the keys and blow away all of the dust and debris that has gathered there. A vacuum cleaner can also be used, but make sure the keyboard doesn't have loose "pop off" keys that could possibly be sucked up by the vacuum.
Why? If the keyboard has anything spilt into it (ie: pop, cola, Pepsi, Coke, beer, wine, coffee, milk, etc.), not taking the proper steps can cause the keyboard to be destroyed.
Procedure: Below are a few recommendations to help prevent a keyboard from becoming bad once a substance has been spilt within it.
If anything is spilt onto the keyboard turn the computer off immediately. Once the computer is turned off, quickly flip the keyboard over helping to prevent the substance from penetrating circuits. While the keyboard is upside down, shake the keyboard over a surface you do not mind getting wet or that can be cleaned up later. While still upside down, use a cloth to help clean out what can be reached. After you you have cleaned the keyboard to the best of your ability leave the keyboard upside down for at least one night allowing it to dry.
If a keyboard does not work after trying it again later it is recommended that it be replaced. If the keyboard works but some of the keys are sticky or cannot be pressed in you can attempt to do additional cleaning in attempt to resolve the issue. Unfortunately many times when any sticky substance such as a non-diet pop is spilt directly onto the keyboard it's usually a loss unless you plan on spending dozens of hours attempting to clean each key.
Why? A keyboard that is used by multiple people, such as students or different employees, may need to be disinfected to help the spread of germs.
Procedure: Turn off the computer. Spray a disinfectant onto a cloth or damp a cloth with alcohol and rub each of the keys on the keyboard. As mentioned in our general cleaning tips, never spray any type of liquid onto the keyboard.
Additional Information: Keyboard Page
on Feb 01, 2010 | Computers & Internet
Dirt like substance coming out from the washine during wash cycle
Possible that there is dirt in the drum that comes up when the drum revolves. This can be due to dirt that had accumulated within and needs to be removed. Please try to watch this link and get some tips to clean the drum.
click on : cleaning the drain
Jan 01, 2013 | Washing Machines
Breville RC3 Rice Cooker and Steamer Leaves starchy mess on work top when cooking rice, am I doing some thing wrong?
Thats normal when cooking rice!
If you dont want these starchy mess, try to cook less rice so that boiling water won't come off from the cover!
Nov 06, 2010 | Breville Kitchen Appliances - Others
There is a grey substance coming out from the steam holes
this is scaling. Just descale it properly if there is a provision in ur press. or just wipe it and leave it
Aug 05, 2009 | Irons
2000 am SE 2.4 L low coolant, cap is always under pressure, dirt like substance in tank, one hose is not connected to anything, what do i do?
Dirt like substance in ratiator ?
That could be oil or trani fluid..
Flush the sysyem.. if it happens again - you have a oil or trani leak..
Not sure what you mean by a hose not conected to anything..
There is a small ovrflow hose that comes off the cooling system and hust hangs.. To relieve overflow..
Jul 08, 2009 | 2000 Pontiac Grand Am GT
Trouble cleaning Sunbeam iron 3983
you can buy an iron cleaner from your hardware store, wallmart sell it.
Jun 09, 2009 | Sunbeam Best Value 3983 Iron
When sending a fax, black lines runs thru entire fax, what to do?
Clean off the glass where the paper runs through.You have some dirt or other substance that is blocking the light for copying or faxing.
Apr 20, 2009 | Canon PIXMA MX310 All-In-One Printer
Just not cleaning
run a cycle thru with no dishes and 2 cups of vingar this will flush out the unit then run a normal load should be ok let me know THERE also is a product called dishwasher magic you can run that thru as well but the vingar is cheaper
Mar 15, 2008 | Maytag 24 in. MDBH955AW Built-in...
Bosch 18 in. SRS56L08 Logixx Slim-Line Built-in Dishwasher Logo
108 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
